RTEMS 6.3
Test context for spec:/rtems/task/req/create-errors test case. More...
| struct | [struct].Map |
Data Fields | |
| rtems_status_code | status |
| rtems_id * | id |
| rtems_id | id_value |
| bool | create_extension_status |
| uint32_t | create_extension_calls |
| uint32_t | delete_extension_calls |
| rtems_name | name |
| rtems_task_priority | initial_priority |
| size_t | stack_size |
| rtems_attribute | attributes |
| rtems_id | extension_id |
| void * | seized_objects |
| struct | Map |
