RTEMS 6.3
Test context for spec:/rtems/status/req/is-successful test case. More...
struct  [struct].Map
bool result
 This member contains the return value of the rtems_is_status_successful() call.
rtems_status_code status
 This member specifies if the status_code parameter value.
struct  Map
