RTEMS 6.3
Test context for spec:/rtems/status/req/is-equal test case. More...
| struct | [struct].Map |
Data Fields | |
| bool | result |
| This member contains the return value of the rtems_are_statuses_equal() call. | |
| rtems_status_code | status_0 |
| This member specifies if the left_status_code parameter value. | |
| rtems_status_code | status_1 |
| This member specifies if the right_status_code parameter value. | |
| struct | Map |
