RTEMS 6.3
Test context for spec:/rtems/sem/req/set-priority test case. More...
| struct | [struct].Map |
Data Fields | |
| rtems_id | runner_scheduler_id |
| This member contains the scheduler identifier of the runner task. | |
| rtems_id | other_scheduler_id |
| This member contains the scheduler identifier of a scheduler not used by the runner task. | |
| uint32_t | count |
| This member specifies the initial count of the semaphore. | |
| rtems_attribute | attribute_set |
| This member specifies the attribute set of the semaphore. | |
| rtems_id | the_semaphore_id |
| This member contains the semaphore identifier. | |
| bool | valid_id |
| If this member is true, then the semaphore_id parameter value shall be associated with the semaphore, otherwise it shall be not associated with a semaphore. | |
| rtems_task_priority | old_priority_value |
| This member may contain the task priority returned by rtems_semaphore_set_priority(). | |
| rtems_id | semaphore_id |
| This member specifies the semaphore_id parameter for the rtems_semaphore_set_priority() call. | |
| rtems_id | scheduler_id |
| This member specifies the scheduler_id parameter for the rtems_semaphore_set_priority() call. | |
| rtems_task_priority | new_priority |
| This member specifies the new_priority parameter for the rtems_semaphore_set_priority() call. | |
| rtems_task_priority * | old_priority |
| This member specifies the old_priority parameter for the rtems_semaphore_set_priority() call. | |
| rtems_status_code | status |
| This member contains the status of the rtems_semaphore_set_priority() call. | |
| struct | Map |
