RTEMS 6.3
Test context for spec:/rtems/scheduler/req/ident test case. More...
| struct | [struct].Map |
Data Fields | |
| rtems_id | id_value |
| This member provides the object referenced by the id parameter. | |
| rtems_status_code | status |
| This member contains the return value of the rtems_scheduler_ident() call. | |
| rtems_name | name |
| This member specifies if the name parameter value. | |
| rtems_id * | id |
| This member specifies if the id parameter value. | |
| struct | Map |
