RTEMS 6.3
Test context for spec:/rtems/scheduler/req/get-processor-set test case. More...
struct  [struct].Map
rtems_id scheduler_id
 This member contains the identifier of a scheduler.
cpu_set_t cpuset_value
 This member provides the object referenced by the cpusetsize parameter.
rtems_status_code status
 This member contains the return value of the rtems_scheduler_get_processor_set() call.
rtems_id id
 This member specifies if the scheduler_id parameter value.
size_t cpusetsize
 This member specifies if the cpusetsize parameter value.
cpu_set_t * cpuset
 This member specifies if the cpuset parameter value.
struct  Map
