RTEMS 6.3
Test context for spec:/rtems/scheduler/req/get-maximum-priority test case. More...
| struct | [struct].Map |
Data Fields | |
| rtems_id | scheduler_id |
| This member contains the identifier of a scheduler. | |
| rtems_task_priority | priority_obj |
| This member provides the object referenced by the priority parameter. | |
| rtems_status_code | status |
| This member contains the return value of the rtems_scheduler_get_maximum_priority() call. | |
| rtems_id | id |
| This member specifies if the scheduler_id parameter value. | |
| rtems_task_priority * | priority |
| This member specifies if the priority parameter value. | |
| struct | Map |
