RTEMS 6.3
Test context for spec:/rtems/scheduler/req/add-processor test case. More...
| struct | [struct].Map |
Data Fields | |
| rtems_id | scheduler_id |
| This member specifies the scheduler used to add the processor. | |
| rtems_id | scheduler_a_id |
| This member contains the identifier of scheduler A. | |
| rtems_id | scheduler_b_id |
| This member contains the identifier of scheduler B. | |
| rtems_id | scheduler_c_id |
| This member contains the identifier of scheduler C. | |
| Per_CPU_Control * | cpu |
| This member references the processor control of the processor to add. | |
| bool | online |
| This member contains the online status of the processor to add before the rtems_scheduler_add_processor() call is prepared. | |
| bool | add_cpu_to_scheduler_b |
| If this member is true, then the processor should be added to the scheduler B during cleanup. | |
| T_scheduler_log_2 | scheduler_log |
| This member provides the scheduler operation records. | |
| rtems_status_code | status |
| This member contains the return value of the rtems_scheduler_add_processor() call. | |
| rtems_id | id |
| This member specifies if the scheduler_id parameter value. | |
| uint32_t | cpu_index |
| This member specifies if the cpu_index parameter value. | |
| struct | Map |
