RTEMS 6.3
Test context for spec:/rtems/req/ident-local test case. More...
struct  [struct].Map
rtems_status_code status
rtems_name name
rtems_id * id
rtems_id id_value
rtems_id id_local_object
 This member contains a copy of the corresponding RtemsReqIdentLocal_Run() parameter.
rtems_name name_local_object
rtems_status_code(*) action (rtems_name, rtems_id *)
struct  Map
