RTEMS 6.3
Test context for spec:/rtems/ratemon/req/timeout test case. More...
struct  [struct].Map
rtems_id period_id
 This member contains the period identifier.
Rate_monotonic_Control * period
 This member references the period control block.
rtems_id other_period_id
 This member contains another period identifier.
rtems_id worker_id
 This member contains the worker task identifier.
CallWithinISRRequest request
 This member contains the call within ISR request.
bool wait_for_period
 If this member is true, then the worker shall wait for a period.
bool period_is_other
 If this member is true, then the worker shall wait for another period.
bool intend_to_block
 If this member is true, then the worker shall intend to block for a period.
uint32_t postponed_jobs
 This member contains the postponed jobs count before the timeout.
Timestamp_Control uptime_before
 This member contains the uptime of the period before the timeout.
Timestamp_Control cpu_usage_before
 This member contains the CPU usage of the period before the timeout.
uint32_t release_job_counter
 This member contains the release job counter.
uint32_t unblock_counter
 This member contains the unblock counter.
struct  Map
