RTEMS 6.3
Test context for spec:/rtems/part/req/create test case. More...
| struct | [struct].Map |
Data Fields | |
| void * | seized_objects |
| rtems_status_code | status |
| rtems_name | name |
| void * | starting_address |
| uintptr_t | length |
| size_t | buffer_size |
| rtems_attribute | attribute_set |
| rtems_id * | id |
| rtems_id | id_value |
| struct | Map |
