RTEMS 6.3
Test context for spec:/rtems/io/req/put-char test case. More...
struct  [struct].Map
int output [2]
 This member contains the character output.
size_t output_count
 This member contains the character output count.
int character
 This member specifies if the c parameter value.
struct  Map
