RTEMS 6.3
file  testsuites/validation/tc-io-put-char.c
struct  RtemsIoReqPutChar_Entry
struct  RtemsIoReqPutChar_Context
 Test context for spec:/rtems/io/req/put-char test case. More...
struct  RtemsIoReqPutChar_Context::[struct].Map
typedef RtemsIoReqPutChar_Context Context
enum  RtemsIoReqPutChar_Pre_Char { RtemsIoReqPutChar_Pre_Char_Nl , RtemsIoReqPutChar_Pre_Char_Other , RtemsIoReqPutChar_Pre_Char_NA }
enum  RtemsIoReqPutChar_Post_Output { RtemsIoReqPutChar_Post_Output_CrNl , RtemsIoReqPutChar_Post_Output_Other , RtemsIoReqPutChar_Post_Output_NA }
 T_TEST_CASE_FIXTURE (RtemsIoReqPutChar, &RtemsIoReqPutChar_Fixture)
