RTEMS 6.3
Test context for spec:/rtems/intr/req/vector-is-enabled test case. More...
struct  [struct].Map
bool interrupt_occurred
 If this member is true, then an interrupt occurred.
rtems_vector_number vector
 This member contains the current vector number.
bool is_enabled
 If this member is true, then the interrupt vector shall be enabled before the rtems_interrupt_vector_is_enabled() call.
bool enabled_obj
 This member provides the bool object.
bool valid_vector
 If this member is true, then the vector parameter shall be valid.
bool * enabled
 This member specifies if the enabled parameter value.
rtems_status_code status
 This member contains the return value of the rtems_interrupt_vector_is_enabled() call.
struct  Map
