RTEMS 6.3
Test context for spec:/rtems/intr/req/set-priority test case. More...
struct  [struct].Map
bool valid_vector
 If this member is true, then the vector parameter shall be valid.
bool valid_priority
 If this member is true, then the priority parameter shall be valid.
bool can_set_priority
 If this member is true, then setting the priority shall be supported.
rtems_status_code expected_status
 This member specifies the expected status.
struct  Map
