RTEMS 6.3
Test context for spec:/rtems/intr/req/set-affinity test case. More...
struct  [struct].Map
rtems_vector_number vector
 This member contains the current vector number.
rtems_vector_number some_vector
 This member contains some valid vector number.
cpu_set_t cpuset_obj [2]
 This member provides the object referenced by the affinity parameter.
rtems_status_code status
 This member contains the return value of the rtems_interrupt_set_affinity() call.
bool valid_vector
 If this member is true, then the vector parameter shall be valid.
size_t cpusetsize
 This member specifies if the affinity_size parameter value.
cpu_set_t * cpuset
 This member specifies if the affinity parameter value.
struct  Map
