RTEMS 6.3
Test context for spec:/rtems/intr/req/raise test case. More...
struct  [struct].Map
volatile uint32_t interrupt_count
 This member contains the count of serviced interrupts.
bool do_clear
 If this member is true, then the interrupt shall be cleared.
rtems_vector_number vector
 This member contains the current vector number.
bool valid_vector
 If this member is true, then the vector parameter shall be valid.
rtems_status_code status
 This member contains the return value of the rtems_interrupt_raise() call.
struct  Map
