RTEMS 6.3
Test context for spec:/rtems/intr/req/get-priority test case. More...
| struct | [struct].Map |
Data Fields | |
| uint32_t | priority_obj |
| This member provides the object referenced by the priority parameter. | |
| bool | valid_vector |
| If this member is true, then the vector parameter shall be valid. | |
| bool | can_get_priority |
| If this member is true, then getting the priority shall be supported. | |
| uint32_t * | priority |
| This member specifies the priority parameter value. | |
| rtems_status_code | expected_status |
| This member specifies the expected status. | |
| void(*) | expected_priority (uint32_t) |
| This member specifies the expected value of the priority object. | |
| struct | Map |
