RTEMS 6.3
Test context for spec:/rtems/intr/req/get-attributes test case. More...
struct  [struct].Map
rtems_interrupt_attributes attributes_obj
 This member provides the rtems_interrupt_attributes object.
bool valid_vector
 If this member is true, then the vector parameter shall be valid.
rtems_interrupt_attributes * attributes
 This member specifies if the attributes parameter value.
rtems_status_code status
 This member contains the return value of the rtems_interrupt_get_attributes() call.
struct  Map
