RTEMS 6.3
Test context for spec:/rtems/intr/req/get-affinity test case. More...
| struct | [struct].Map |
Data Fields | |
| rtems_vector_number | vector |
| This member contains the current vector number. | |
| rtems_vector_number | some_vector |
| This member contains some valid vector number. | |
| cpu_set_t | cpuset_obj [2] |
| This member provides the object referenced by the affinity parameter. | |
| rtems_status_code | status |
| This member contains the return value of the rtems_interrupt_get_affinity() call. | |
| bool | valid_vector |
| If this member is true, then the vector parameter shall be valid. | |
| size_t | cpusetsize |
| This member specifies if the affinity_size parameter value. | |
| cpu_set_t * | cpuset |
| This member specifies if the affinity parameter value. | |
| struct | Map |
