RTEMS 6.3
Data Fields | |
| struct drvmgr_dev * | dev |
| char | devName [49] |
| LEON3_SPACEWIRE_Regs_Map * | regs |
| spw_config | config |
| unsigned int | tx_all_in_use |
| unsigned int | tx_sent |
| unsigned int | tx_cur |
| unsigned int | rxcur |
| unsigned int | rxbufcur |
| unsigned int | txdbufsize |
| unsigned int | txhbufsize |
| unsigned int | rxbufsize |
| unsigned int | txbufcnt |
| unsigned int | rxbufcnt |
| unsigned int | rx_dma_area |
| unsigned int | tx_data_dma_area |
| unsigned int | tx_hdr_dma_area |
| unsigned int | bd_dma_area |
| spw_stats | stat |
| unsigned int | _ptr_rxbuf0 |
| char * | ptr_rxbuf0 |
| char * | ptr_txdbuf0 |
| char * | ptr_txhbuf0 |
| char * | _ptr_bd0 |
| char * | ptr_bd0 |
| char * | ptr_rxbuf0_remote |
| char * | ptr_txdbuf0_remote |
| char * | ptr_txhbuf0_remote |
| char * | ptr_bd0_remote |
| unsigned int | irq |
| int | minor |
| int | core_ver |
| int | open |
| int | running |
| unsigned int | core_freq_khz |
| unsigned int | rtimeout |
| rtems_id | txsp |
| rtems_id | rxsp |
| SPACEWIRE_RXBD * | rx |
| SPACEWIRE_TXBD * | tx |
| unsigned int | rx_remote |
| unsigned int | tx_remote |
