RTEMS 6.3
UTILS LL module driver. More...
| void | LL_Init1msTick (uint32_t CPU_Frequency) |
| This function configures the Cortex-M SysTick source to have 1ms time base. | |
| void | LL_mDelay (uint32_t Delay) |
| This function provides accurate delay (in milliseconds) based on SysTick counter flag. | |
| void | LL_SetSystemCoreClock (uint32_t CPU_Frequency) |
| This function sets directly SystemCoreClock CMSIS variable. | |
| ErrorStatus | LL_PLL_ConfigSystemClock_HSI (LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct) |
| This function configures system clock at maximum frequency with HSI as clock source of the PLL. | |
| ErrorStatus | LL_PLL_ConfigSystemClock_HSE (uint32_t HSEFrequency, uint32_t HSEBypass, LL_UTILS_PLLInitTypeDef *UTILS_PLLInitStruct, LL_UTILS_ClkInitTypeDef *UTILS_ClkInitStruct) |
| This function configures system clock with HSE as clock source of the PLL. | |
| ErrorStatus | LL_SetFlashLatency (uint32_t HCLK_Frequency) |
| Update number of Flash wait states in line with new frequency and current voltage range. | |
| #define assert_param | ( | expr | ) |
