RTEMS 6.3
UTILS Private Constants
#define UTILS_PLLVCO_INPUT_MIN1   1000000U
#define UTILS_PLLVCO_INPUT_MAX1   2000000U
#define UTILS_PLLVCO_INPUT_MIN2   2000000U
#define UTILS_PLLVCO_INPUT_MAX2   4000000U
#define UTILS_PLLVCO_INPUT_MIN3   4000000U
#define UTILS_PLLVCO_INPUT_MAX3   8000000U
#define UTILS_PLLVCO_INPUT_MIN4   8000000U
#define UTILS_PLLVCO_INPUT_MAX4   16000000U
#define UTILS_PLLVCO_MEDIUM_OUTPUT_MIN   150000000U
#define UTILS_PLLVCO_WIDE_OUTPUT_MIN   128000000U
#define UTILS_PLLVCO_MEDIUM_OUTPUT_MAX   420000000U
#define UTILS_PLLVCO_WIDE_OUTPUT_MAX   560000000U
#define UTILS_HSE_FREQUENCY_MIN   4000000U
#define UTILS_HSE_FREQUENCY_MAX   48000000U
#define LL_MAX_DELAY   0xFFFFFFFFU
#define UID_BASE_ADDRESS   UID_BASE
 Unique device ID register base address.
#define FLASHSIZE_BASE_ADDRESS   FLASHSIZE_BASE
 Flash size data register base address.
#define PACKAGE_BASE_ADDRESS   PACKAGE_BASE
 Package data register base address.
◆ UTILS_HSE_FREQUENCY_MAX
Frequency max for HSE frequency, in Hz
◆ UTILS_HSE_FREQUENCY_MIN
Frequency min for HSE frequency, in Hz
◆ UTILS_PLLVCO_INPUT_MAX1
Frequency max for the wide range PLLVCO input, in Hz
◆ UTILS_PLLVCO_INPUT_MAX2
◆ UTILS_PLLVCO_INPUT_MAX3
◆ UTILS_PLLVCO_INPUT_MAX4
◆ UTILS_PLLVCO_INPUT_MIN1
Frequency min for the low range PLLVCO input, in Hz
◆ UTILS_PLLVCO_INPUT_MIN2
◆ UTILS_PLLVCO_INPUT_MIN3
◆ UTILS_PLLVCO_INPUT_MIN4
◆ UTILS_PLLVCO_MEDIUM_OUTPUT_MAX
Frequency max for the medium range PLLVCO output, in Hz
◆ UTILS_PLLVCO_MEDIUM_OUTPUT_MIN
Frequency min for the medium range PLLVCO output, in Hz
◆ UTILS_PLLVCO_WIDE_OUTPUT_MAX
Frequency max for the wide range PLLVCO output, in Hz
◆ UTILS_PLLVCO_WIDE_OUTPUT_MIN
Frequency min for the wide range PLLVCO output, in Hz
