RTEMS 6.3
stm32h7xx_ll_fmc.h File Reference
Header file of FMC HAL module. More...
struct  FMC_NORSRAM_InitTypeDef
 FMC NORSRAM Configuration Structure definition. More...
struct  FMC_NORSRAM_TimingTypeDef
 FMC NORSRAM Timing parameters structure definition. More...
struct  FMC_NAND_InitTypeDef
 FMC NAND Configuration Structure definition. More...
struct  FMC_NAND_PCC_TimingTypeDef
 FMC NAND Timing parameters structure definition. More...
struct  FMC_SDRAM_InitTypeDef
 FMC SDRAM Configuration Structure definition. More...
struct  FMC_SDRAM_TimingTypeDef
 FMC SDRAM Timing parameters structure definition. More...
struct  FMC_SDRAM_CommandTypeDef
 SDRAM command parameters structure definition. More...
#define IS_FMC_NORSRAM_BANK(__BANK__)
#define IS_FMC_MUX(__MUX__)
#define IS_FMC_MEMORY(__MEMORY__)
#define IS_FMC_NORSRAM_MEMORY_WIDTH(__WIDTH__)
#define IS_FMC_PAGESIZE(__SIZE__)
#define IS_FMC_WRITE_FIFO(__FIFO__)
#define IS_FMC_ACCESS_MODE(__MODE__)
#define IS_FMC_BURSTMODE(__STATE__)
#define IS_FMC_WAIT_POLARITY(__POLARITY__)
#define IS_FMC_WAIT_SIGNAL_ACTIVE(__ACTIVE__)
#define IS_FMC_WRITE_OPERATION(__OPERATION__)
#define IS_FMC_WAITE_SIGNAL(__SIGNAL__)
#define IS_FMC_EXTENDED_MODE(__MODE__)
#define IS_FMC_ASYNWAIT(__STATE__)
#define IS_FMC_DATA_LATENCY(__LATENCY__)
#define IS_FMC_WRITE_BURST(__BURST__)
#define IS_FMC_CONTINOUS_CLOCK(__CCLOCK__)
#define IS_FMC_ADDRESS_SETUP_TIME(__TIME__)
#define IS_FMC_ADDRESS_HOLD_TIME(__TIME__)
#define IS_FMC_DATASETUP_TIME(__TIME__)
#define IS_FMC_DATAHOLD_DURATION(__DATAHOLD__)
#define IS_FMC_TURNAROUND_TIME(__TIME__)
#define IS_FMC_CLK_DIV(__DIV__)
#define IS_FMC_NORSRAM_DEVICE(__INSTANCE__)
#define IS_FMC_NORSRAM_EXTENDED_DEVICE(__INSTANCE__)
#define IS_FMC_NAND_BANK(__BANK__)
#define IS_FMC_WAIT_FEATURE(__FEATURE__)
#define IS_FMC_NAND_MEMORY_WIDTH(__WIDTH__)
#define IS_FMC_ECC_STATE(__STATE__)
#define IS_FMC_ECCPAGE_SIZE(__SIZE__)
#define IS_FMC_TCLR_TIME(__TIME__)
#define IS_FMC_TAR_TIME(__TIME__)
#define IS_FMC_SETUP_TIME(__TIME__)
#define IS_FMC_WAIT_TIME(__TIME__)
#define IS_FMC_HOLD_TIME(__TIME__)
#define IS_FMC_HIZ_TIME(__TIME__)
#define IS_FMC_NAND_DEVICE(__INSTANCE__)
#define IS_FMC_SDMEMORY_WIDTH(__WIDTH__)
#define IS_FMC_WRITE_PROTECTION(__WRITE__)
#define IS_FMC_SDCLOCK_PERIOD(__PERIOD__)
#define IS_FMC_READ_BURST(__RBURST__)
#define IS_FMC_READPIPE_DELAY(__DELAY__)
#define IS_FMC_COMMAND_MODE(__COMMAND__)
#define IS_FMC_COMMAND_TARGET(__TARGET__)
#define IS_FMC_LOADTOACTIVE_DELAY(__DELAY__)
#define IS_FMC_EXITSELFREFRESH_DELAY(__DELAY__)
#define IS_FMC_SELFREFRESH_TIME(__TIME__)
#define IS_FMC_ROWCYCLE_DELAY(__DELAY__)
#define IS_FMC_WRITE_RECOVERY_TIME(__TIME__)
#define IS_FMC_RP_DELAY(__DELAY__)
#define IS_FMC_RCD_DELAY(__DELAY__)
#define IS_FMC_AUTOREFRESH_NUMBER(__NUMBER__)
#define IS_FMC_MODE_REGISTER(__CONTENT__)
#define IS_FMC_REFRESH_RATE(__RATE__)
#define IS_FMC_SDRAM_DEVICE(__INSTANCE__)
#define IS_FMC_SDRAM_BANK(__BANK__)
#define IS_FMC_COLUMNBITS_NUMBER(__COLUMN__)
#define IS_FMC_ROWBITS_NUMBER(__ROW__)
#define IS_FMC_INTERNALBANK_NUMBER(__NUMBER__)
#define IS_FMC_CAS_LATENCY(__LATENCY__)
#define FMC_NORSRAM_TypeDef   FMC_Bank1_TypeDef
#define FMC_NORSRAM_EXTENDED_TypeDef   FMC_Bank1E_TypeDef
#define FMC_NAND_TypeDef   FMC_Bank3_TypeDef
#define FMC_SDRAM_TypeDef   FMC_Bank5_6_TypeDef
#define FMC_NORSRAM_DEVICE   FMC_Bank1_R
#define FMC_NORSRAM_EXTENDED_DEVICE   FMC_Bank1E_R
#define FMC_NAND_DEVICE   FMC_Bank3_R
#define FMC_SDRAM_DEVICE   FMC_Bank5_6_R
#define FMC_NORSRAM_BANK1   (0x00000000U)
#define FMC_NORSRAM_BANK2   (0x00000002U)
#define FMC_NORSRAM_BANK3   (0x00000004U)
#define FMC_NORSRAM_BANK4   (0x00000006U)
#define FMC_DATA_ADDRESS_MUX_DISABLE   (0x00000000U)
#define FMC_DATA_ADDRESS_MUX_ENABLE   (0x00000002U)
#define FMC_MEMORY_TYPE_SRAM   (0x00000000U)
#define FMC_MEMORY_TYPE_PSRAM   (0x00000004U)
#define FMC_MEMORY_TYPE_NOR   (0x00000008U)
#define FMC_NORSRAM_MEM_BUS_WIDTH_8   (0x00000000U)
#define FMC_NORSRAM_MEM_BUS_WIDTH_16   (0x00000010U)
#define FMC_NORSRAM_MEM_BUS_WIDTH_32   (0x00000020U)
#define FMC_NORSRAM_FLASH_ACCESS_ENABLE   (0x00000040U)
#define FMC_NORSRAM_FLASH_ACCESS_DISABLE   (0x00000000U)
#define FMC_BURST_ACCESS_MODE_DISABLE   (0x00000000U)
#define FMC_BURST_ACCESS_MODE_ENABLE   (0x00000100U)
#define FMC_WAIT_SIGNAL_POLARITY_LOW   (0x00000000U)
#define FMC_WAIT_SIGNAL_POLARITY_HIGH   (0x00000200U)
#define FMC_WAIT_TIMING_BEFORE_WS   (0x00000000U)
#define FMC_WAIT_TIMING_DURING_WS   (0x00000800U)
#define FMC_WRITE_OPERATION_DISABLE   (0x00000000U)
#define FMC_WRITE_OPERATION_ENABLE   (0x00001000U)
#define FMC_WAIT_SIGNAL_DISABLE   (0x00000000U)
#define FMC_WAIT_SIGNAL_ENABLE   (0x00002000U)
#define FMC_EXTENDED_MODE_DISABLE   (0x00000000U)
#define FMC_EXTENDED_MODE_ENABLE   (0x00004000U)
#define FMC_ASYNCHRONOUS_WAIT_DISABLE   (0x00000000U)
#define FMC_ASYNCHRONOUS_WAIT_ENABLE   (0x00008000U)
#define FMC_PAGE_SIZE_NONE   (0x00000000U)
#define FMC_PAGE_SIZE_128   FMC_BCRx_CPSIZE_0
#define FMC_PAGE_SIZE_256   FMC_BCRx_CPSIZE_1
#define FMC_PAGE_SIZE_512
#define FMC_PAGE_SIZE_1024   FMC_BCRx_CPSIZE_2
#define FMC_WRITE_BURST_DISABLE   (0x00000000U)
#define FMC_WRITE_BURST_ENABLE   (0x00080000U)
#define FMC_CONTINUOUS_CLOCK_SYNC_ONLY   (0x00000000U)
#define FMC_CONTINUOUS_CLOCK_SYNC_ASYNC   (0x00100000U)
#define FMC_ACCESS_MODE_A   (0x00000000U)
#define FMC_ACCESS_MODE_B   (0x10000000U)
#define FMC_ACCESS_MODE_C   (0x20000000U)
#define FMC_ACCESS_MODE_D   (0x30000000U)
#define FMC_NAND_BANK3   (0x00000100U)
#define FMC_NAND_WAIT_FEATURE_DISABLE   (0x00000000U)
#define FMC_NAND_WAIT_FEATURE_ENABLE   (0x00000002U)
#define FMC_PCR_MEMORY_TYPE_NAND   (0x00000008U)
#define FMC_NAND_MEM_BUS_WIDTH_8   (0x00000000U)
#define FMC_NAND_MEM_BUS_WIDTH_16   (0x00000010U)
#define FMC_NAND_ECC_DISABLE   (0x00000000U)
#define FMC_NAND_ECC_ENABLE   (0x00000040U)
#define FMC_NAND_ECC_PAGE_SIZE_256BYTE   (0x00000000U)
#define FMC_NAND_ECC_PAGE_SIZE_512BYTE   (0x00020000U)
#define FMC_NAND_ECC_PAGE_SIZE_1024BYTE   (0x00040000U)
#define FMC_NAND_ECC_PAGE_SIZE_2048BYTE   (0x00060000U)
#define FMC_NAND_ECC_PAGE_SIZE_4096BYTE   (0x00080000U)
#define FMC_NAND_ECC_PAGE_SIZE_8192BYTE   (0x000A0000U)
#define FMC_SDRAM_BANK1   (0x00000000U)
#define FMC_SDRAM_BANK2   (0x00000001U)
#define FMC_SDRAM_COLUMN_BITS_NUM_8   (0x00000000U)
#define FMC_SDRAM_COLUMN_BITS_NUM_9   (0x00000001U)
#define FMC_SDRAM_COLUMN_BITS_NUM_10   (0x00000002U)
#define FMC_SDRAM_COLUMN_BITS_NUM_11   (0x00000003U)
#define FMC_SDRAM_ROW_BITS_NUM_11   (0x00000000U)
#define FMC_SDRAM_ROW_BITS_NUM_12   (0x00000004U)
#define FMC_SDRAM_ROW_BITS_NUM_13   (0x00000008U)
#define FMC_SDRAM_MEM_BUS_WIDTH_8   (0x00000000U)
#define FMC_SDRAM_MEM_BUS_WIDTH_16   (0x00000010U)
#define FMC_SDRAM_MEM_BUS_WIDTH_32   (0x00000020U)
#define FMC_SDRAM_INTERN_BANKS_NUM_2   (0x00000000U)
#define FMC_SDRAM_INTERN_BANKS_NUM_4   (0x00000040U)
#define FMC_SDRAM_CAS_LATENCY_1   (0x00000080U)
#define FMC_SDRAM_CAS_LATENCY_2   (0x00000100U)
#define FMC_SDRAM_CAS_LATENCY_3   (0x00000180U)
#define FMC_SDRAM_WRITE_PROTECTION_DISABLE   (0x00000000U)
#define FMC_SDRAM_WRITE_PROTECTION_ENABLE   (0x00000200U)
#define FMC_SDRAM_CLOCK_DISABLE   (0x00000000U)
#define FMC_SDRAM_CLOCK_PERIOD_2   (0x00000800U)
#define FMC_SDRAM_CLOCK_PERIOD_3   (0x00000C00U)
#define FMC_SDRAM_RBURST_DISABLE   (0x00000000U)
#define FMC_SDRAM_RBURST_ENABLE   (0x00001000U)
#define FMC_SDRAM_RPIPE_DELAY_0   (0x00000000U)
#define FMC_SDRAM_RPIPE_DELAY_1   (0x00002000U)
#define FMC_SDRAM_RPIPE_DELAY_2   (0x00004000U)
#define FMC_SDRAM_CMD_NORMAL_MODE   (0x00000000U)
#define FMC_SDRAM_CMD_CLK_ENABLE   (0x00000001U)
#define FMC_SDRAM_CMD_PALL   (0x00000002U)
#define FMC_SDRAM_CMD_AUTOREFRESH_MODE   (0x00000003U)
#define FMC_SDRAM_CMD_LOAD_MODE   (0x00000004U)
#define FMC_SDRAM_CMD_SELFREFRESH_MODE   (0x00000005U)
#define FMC_SDRAM_CMD_POWERDOWN_MODE   (0x00000006U)
#define FMC_SDRAM_CMD_TARGET_BANK2   FMC_SDCMR_CTB2
#define FMC_SDRAM_CMD_TARGET_BANK1   FMC_SDCMR_CTB1
#define FMC_SDRAM_CMD_TARGET_BANK1_2   (0x00000018U)
#define FMC_SDRAM_NORMAL_MODE   (0x00000000U)
#define FMC_SDRAM_SELF_REFRESH_MODE   FMC_SDSR_MODES1_0
#define FMC_SDRAM_POWER_DOWN_MODE   FMC_SDSR_MODES1_1
#define FMC_IT_RISING_EDGE   (0x00000008U)
#define FMC_IT_LEVEL   (0x00000010U)
#define FMC_IT_FALLING_EDGE   (0x00000020U)
#define FMC_IT_REFRESH_ERROR   (0x00004000U)
#define FMC_FLAG_RISING_EDGE   (0x00000001U)
#define FMC_FLAG_LEVEL   (0x00000002U)
#define FMC_FLAG_FALLING_EDGE   (0x00000004U)
#define FMC_FLAG_FEMPT   (0x00000040U)
#define FMC_SDRAM_FLAG_REFRESH_IT   FMC_SDSR_RE
#define FMC_SDRAM_FLAG_BUSY   FMC_SDSR_BUSY
#define FMC_SDRAM_FLAG_REFRESH_ERROR   FMC_SDRTR_CRE
#define __FMC_ENABLE()
 Enable the FMC Peripheral.
#define __FMC_DISABLE()
 Disable the FMC Peripheral.
#define __FMC_NORSRAM_ENABLE(__INSTANCE__, __BANK__)
 Enable the NORSRAM device access.
#define __FMC_NORSRAM_DISABLE(__INSTANCE__, __BANK__)
 Disable the NORSRAM device access.
#define __FMC_NAND_ENABLE(__INSTANCE__)
 Enable the NAND device access.
#define __FMC_NAND_DISABLE(__INSTANCE__, __BANK__)
 Disable the NAND device access.
#define __FMC_NAND_ENABLE_IT(__INSTANCE__, __INTERRUPT__)
 Enable the NAND device interrupt.
#define __FMC_NAND_DISABLE_IT(__INSTANCE__, __INTERRUPT__)
 Disable the NAND device interrupt.
#define __FMC_NAND_GET_FLAG(__INSTANCE__, __BANK__, __FLAG__)
 Get flag status of the NAND device.
#define __FMC_NAND_CLEAR_FLAG(__INSTANCE__, __FLAG__)
 Clear flag status of the NAND device.
#define __FMC_SDRAM_ENABLE_IT(__INSTANCE__, __INTERRUPT__)
 Enable the SDRAM device interrupt.
#define __FMC_SDRAM_DISABLE_IT(__INSTANCE__, __INTERRUPT__)
 Disable the SDRAM device interrupt.
#define __FMC_SDRAM_GET_FLAG(__INSTANCE__, __FLAG__)
 Get flag status of the SDRAM device.
#define __FMC_SDRAM_CLEAR_FLAG(__INSTANCE__, __FLAG__)
 Clear flag status of the SDRAM device.
HAL_StatusTypeDef FMC_NORSRAM_Init (FMC_NORSRAM_TypeDef *Device, FMC_NORSRAM_InitTypeDef *Init)
HAL_StatusTypeDef FMC_NORSRAM_Timing_Init (FMC_NORSRAM_TypeDef *Device, FMC_NORSRAM_TimingTypeDef *Timing, uint32_t Bank)
HAL_StatusTypeDef FMC_NORSRAM_Extended_Timing_Init (FMC_NORSRAM_EXTENDED_TypeDef *Device, FMC_NORSRAM_TimingTypeDef *Timing, uint32_t Bank, uint32_t ExtendedMode)
HAL_StatusTypeDef FMC_NORSRAM_DeInit (FMC_NORSRAM_TypeDef *Device, FMC_NORSRAM_EXTENDED_TypeDef *ExDevice, uint32_t Bank)
HAL_StatusTypeDef FMC_NORSRAM_WriteOperation_Enable (FMC_NORSRAM_TypeDef *Device, uint32_t Bank)
HAL_StatusTypeDef FMC_NORSRAM_WriteOperation_Disable (FMC_NORSRAM_TypeDef *Device, uint32_t Bank)
HAL_StatusTypeDef FMC_NAND_Init (FMC_NAND_TypeDef *Device, FMC_NAND_InitTypeDef *Init)
HAL_StatusTypeDef FMC_NAND_CommonSpace_Timing_Init (FMC_NAND_TypeDef *Device, FMC_NAND_PCC_TimingTypeDef *Timing, uint32_t Bank)
HAL_StatusTypeDef FMC_NAND_AttributeSpace_Timing_Init (FMC_NAND_TypeDef *Device, FMC_NAND_PCC_TimingTypeDef *Timing, uint32_t Bank)
HAL_StatusTypeDef FMC_NAND_DeInit (FMC_NAND_TypeDef *Device, uint32_t Bank)
HAL_StatusTypeDef FMC_NAND_ECC_Enable (FMC_NAND_TypeDef *Device, uint32_t Bank)
HAL_StatusTypeDef FMC_NAND_ECC_Disable (FMC_NAND_TypeDef *Device, uint32_t Bank)
HAL_StatusTypeDef FMC_NAND_GetECC (FMC_NAND_TypeDef *Device, uint32_t *ECCval, uint32_t Bank, uint32_t Timeout)
HAL_StatusTypeDef FMC_SDRAM_Init (FMC_SDRAM_TypeDef *Device, FMC_SDRAM_InitTypeDef *Init)
HAL_StatusTypeDef FMC_SDRAM_Timing_Init (FMC_SDRAM_TypeDef *Device, FMC_SDRAM_TimingTypeDef *Timing, uint32_t Bank)
HAL_StatusTypeDef FMC_SDRAM_DeInit (FMC_SDRAM_TypeDef *Device, uint32_t Bank)
HAL_StatusTypeDef FMC_SDRAM_WriteProtection_Enable (FMC_SDRAM_TypeDef *Device, uint32_t Bank)
HAL_StatusTypeDef FMC_SDRAM_WriteProtection_Disable (FMC_SDRAM_TypeDef *Device, uint32_t Bank)
HAL_StatusTypeDef FMC_SDRAM_SendCommand (FMC_SDRAM_TypeDef *Device, FMC_SDRAM_CommandTypeDef *Command, uint32_t Timeout)
HAL_StatusTypeDef FMC_SDRAM_ProgramRefreshRate (FMC_SDRAM_TypeDef *Device, uint32_t RefreshRate)
HAL_StatusTypeDef FMC_SDRAM_SetAutoRefreshNumber (FMC_SDRAM_TypeDef *Device, uint32_t AutoRefreshNumber)
uint32_t FMC_SDRAM_GetModeStatus (const FMC_SDRAM_TypeDef *Device, uint32_t Bank)
Author
MCD Application Team
Attention
