RTEMS 6.3
macros to handle SDRAM interrupts More...
| #define | __FMC_SDRAM_ENABLE_IT(__INSTANCE__, __INTERRUPT__) |
| Enable the SDRAM device interrupt. | |
| #define | __FMC_SDRAM_DISABLE_IT(__INSTANCE__, __INTERRUPT__) |
| Disable the SDRAM device interrupt. | |
| #define | __FMC_SDRAM_GET_FLAG(__INSTANCE__, __FLAG__) |
| Get flag status of the SDRAM device. | |
| #define | __FMC_SDRAM_CLEAR_FLAG(__INSTANCE__, __FLAG__) |
| Clear flag status of the SDRAM device. | |
| #define __FMC_SDRAM_CLEAR_FLAG | ( | __INSTANCE__, | |
| __FLAG__ ) |
| __INSTANCE__ | FMC_SDRAM instance |
| __FLAG__ | FMC_SDRAM flag This parameter can be any combination of the following values:
| None |
| #define __FMC_SDRAM_DISABLE_IT | ( | __INSTANCE__, | |
| __INTERRUPT__ ) |
| __INTERRUPT__ | FMC_SDRAM interrupt This parameter can be any combination of the following values:
| None |
| #define __FMC_SDRAM_ENABLE_IT | ( | __INSTANCE__, | |
| __INTERRUPT__ ) |
| None |
| #define __FMC_SDRAM_GET_FLAG | ( | __INSTANCE__, | |
| __FLAG__ ) |
| The | state of FLAG (SET or RESET). |
