RTEMS 6.3
stm32h7xx_hal_uart_ex.h File Reference
Header file of UART HAL Extended module. More...
struct  UART_WakeUpTypeDef
 UART wake up from stop mode parameters. More...
#define UART_WORDLENGTH_7B   USART_CR1_M1
#define UART_WORDLENGTH_8B   0x00000000U
#define UART_WORDLENGTH_9B   USART_CR1_M0
#define UART_ADDRESS_DETECT_4B   0x00000000U
#define UART_ADDRESS_DETECT_7B   USART_CR2_ADDM7
#define UART_FIFOMODE_DISABLE   0x00000000U
#define UART_FIFOMODE_ENABLE   USART_CR1_FIFOEN
#define UART_TXFIFO_THRESHOLD_1_8   0x00000000U
#define UART_TXFIFO_THRESHOLD_1_4   USART_CR3_TXFTCFG_0
#define UART_TXFIFO_THRESHOLD_1_2   USART_CR3_TXFTCFG_1
#define UART_TXFIFO_THRESHOLD_3_4   (USART_CR3_TXFTCFG_0|USART_CR3_TXFTCFG_1)
#define UART_TXFIFO_THRESHOLD_7_8   USART_CR3_TXFTCFG_2
#define UART_TXFIFO_THRESHOLD_8_8   (USART_CR3_TXFTCFG_2|USART_CR3_TXFTCFG_0)
#define UART_RXFIFO_THRESHOLD_1_8   0x00000000U
#define UART_RXFIFO_THRESHOLD_1_4   USART_CR3_RXFTCFG_0
#define UART_RXFIFO_THRESHOLD_1_2   USART_CR3_RXFTCFG_1
#define UART_RXFIFO_THRESHOLD_3_4   (USART_CR3_RXFTCFG_0|USART_CR3_RXFTCFG_1)
#define UART_RXFIFO_THRESHOLD_7_8   USART_CR3_RXFTCFG_2
#define UART_RXFIFO_THRESHOLD_8_8   (USART_CR3_RXFTCFG_2|USART_CR3_RXFTCFG_0)
#define UART_GETCLOCKSOURCE(__HANDLE__, __CLOCKSOURCE__)
 Report the UART clock source.
#define UART_MASK_COMPUTATION(__HANDLE__)
 Report the UART mask to apply to retrieve the received data according to the word length and to the parity bits activation.
#define IS_UART_WORD_LENGTH(__LENGTH__)
 Ensure that UART frame length is valid.
#define IS_UART_ADDRESSLENGTH_DETECT(__ADDRESS__)
 Ensure that UART wake-up address length is valid.
#define IS_UART_TXFIFO_THRESHOLD(__THRESHOLD__)
 Ensure that UART TXFIFO threshold level is valid.
#define IS_UART_RXFIFO_THRESHOLD(__THRESHOLD__)
 Ensure that UART RXFIFO threshold level is valid.
HAL_StatusTypeDef HAL_RS485Ex_Init (UART_HandleTypeDef *huart, uint32_t Polarity, uint32_t AssertionTime, uint32_t DeassertionTime)
void HAL_UARTEx_WakeupCallback (UART_HandleTypeDef *huart)
void HAL_UARTEx_RxFifoFullCallback (UART_HandleTypeDef *huart)
void HAL_UARTEx_TxFifoEmptyCallback (UART_HandleTypeDef *huart)
HAL_StatusTypeDef HAL_UARTEx_StopModeWakeUpSourceConfig (UART_HandleTypeDef *huart, UART_WakeUpTypeDef WakeUpSelection)
HAL_StatusTypeDef HAL_UARTEx_EnableStopMode (UART_HandleTypeDef *huart)
HAL_StatusTypeDef HAL_UARTEx_DisableStopMode (UART_HandleTypeDef *huart)
HAL_StatusTypeDef HAL_MultiProcessorEx_AddressLength_Set (UART_HandleTypeDef *huart, uint32_t AddressLength)
HAL_StatusTypeDef HAL_UARTEx_EnableFifoMode (UART_HandleTypeDef *huart)
HAL_StatusTypeDef HAL_UARTEx_DisableFifoMode (UART_HandleTypeDef *huart)
HAL_StatusTypeDef HAL_UARTEx_SetTxFifoThreshold (UART_HandleTypeDef *huart, uint32_t Threshold)
HAL_StatusTypeDef HAL_UARTEx_SetRxFifoThreshold (UART_HandleTypeDef *huart, uint32_t Threshold)
HAL_StatusTypeDef HAL_UARTEx_ReceiveToIdle (UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size, uint16_t *RxLen, uint32_t Timeout)
HAL_StatusTypeDef HAL_UARTEx_ReceiveToIdle_IT (UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size)
HAL_StatusTypeDef HAL_UARTEx_ReceiveToIdle_DMA (UART_HandleTypeDef *huart, uint8_t *pData, uint16_t Size)
HAL_UART_RxEventTypeTypeDef HAL_UARTEx_GetRxEventType (const UART_HandleTypeDef *huart)
Author
MCD Application Team
Attention
