RTEMS 6.3
#define UART_GETCLOCKSOURCE(__HANDLE__, __CLOCKSOURCE__)
 Report the UART clock source.
#define UART_MASK_COMPUTATION(__HANDLE__)
 Report the UART mask to apply to retrieve the received data according to the word length and to the parity bits activation.
#define IS_UART_WORD_LENGTH(__LENGTH__)
 Ensure that UART frame length is valid.
#define IS_UART_ADDRESSLENGTH_DETECT(__ADDRESS__)
 Ensure that UART wake-up address length is valid.
#define IS_UART_TXFIFO_THRESHOLD(__THRESHOLD__)
 Ensure that UART TXFIFO threshold level is valid.
#define IS_UART_RXFIFO_THRESHOLD(__THRESHOLD__)
 Ensure that UART RXFIFO threshold level is valid.
◆ IS_UART_ADDRESSLENGTH_DETECT
#define IS_UART_ADDRESSLENGTH_DETECT ( __ADDRESS__)
Value:
(((__ADDRESS__) == UART_ADDRESS_DETECT_4B) || \
((__ADDRESS__) == UART_ADDRESS_DETECT_7B))
#define UART_ADDRESS_DETECT_7B
Definition stm32h7xx_hal_uart_ex.h:86
#define UART_ADDRESS_DETECT_4B
Definition stm32h7xx_hal_uart_ex.h:85
Parameters
__ADDRESS__UART wake-up address length.
Return values
SET(ADDRESS is valid) or RESET (ADDRESS is invalid)
◆ IS_UART_RXFIFO_THRESHOLD
#define IS_UART_RXFIFO_THRESHOLD ( __THRESHOLD__)
Value:
(((__THRESHOLD__) == UART_RXFIFO_THRESHOLD_1_8) || \
((__THRESHOLD__) == UART_RXFIFO_THRESHOLD_1_4) || \
((__THRESHOLD__) == UART_RXFIFO_THRESHOLD_1_2) || \
((__THRESHOLD__) == UART_RXFIFO_THRESHOLD_3_4) || \
((__THRESHOLD__) == UART_RXFIFO_THRESHOLD_7_8) || \
((__THRESHOLD__) == UART_RXFIFO_THRESHOLD_8_8))
#define UART_RXFIFO_THRESHOLD_1_2
Definition stm32h7xx_hal_uart_ex.h:124
#define UART_RXFIFO_THRESHOLD_1_4
Definition stm32h7xx_hal_uart_ex.h:123
#define UART_RXFIFO_THRESHOLD_3_4
Definition stm32h7xx_hal_uart_ex.h:125
#define UART_RXFIFO_THRESHOLD_1_8
Definition stm32h7xx_hal_uart_ex.h:122
#define UART_RXFIFO_THRESHOLD_7_8
Definition stm32h7xx_hal_uart_ex.h:126
#define UART_RXFIFO_THRESHOLD_8_8
Definition stm32h7xx_hal_uart_ex.h:127
Parameters
__THRESHOLD__UART RXFIFO threshold level.
Return values
SET(THRESHOLD is valid) or RESET (THRESHOLD is invalid)
◆ IS_UART_TXFIFO_THRESHOLD
#define IS_UART_TXFIFO_THRESHOLD ( __THRESHOLD__)
Value:
(((__THRESHOLD__) == UART_TXFIFO_THRESHOLD_1_8) || \
((__THRESHOLD__) == UART_TXFIFO_THRESHOLD_1_4) || \
((__THRESHOLD__) == UART_TXFIFO_THRESHOLD_1_2) || \
((__THRESHOLD__) == UART_TXFIFO_THRESHOLD_3_4) || \
((__THRESHOLD__) == UART_TXFIFO_THRESHOLD_7_8) || \
((__THRESHOLD__) == UART_TXFIFO_THRESHOLD_8_8))
#define UART_TXFIFO_THRESHOLD_3_4
Definition stm32h7xx_hal_uart_ex.h:110
#define UART_TXFIFO_THRESHOLD_8_8
Definition stm32h7xx_hal_uart_ex.h:112
#define UART_TXFIFO_THRESHOLD_1_2
Definition stm32h7xx_hal_uart_ex.h:109
#define UART_TXFIFO_THRESHOLD_1_4
Definition stm32h7xx_hal_uart_ex.h:108
#define UART_TXFIFO_THRESHOLD_7_8
Definition stm32h7xx_hal_uart_ex.h:111
#define UART_TXFIFO_THRESHOLD_1_8
Definition stm32h7xx_hal_uart_ex.h:107
Parameters
__THRESHOLD__UART TXFIFO threshold level.
Return values
◆ IS_UART_WORD_LENGTH
#define IS_UART_WORD_LENGTH ( __LENGTH__)
Value:
(((__LENGTH__) == UART_WORDLENGTH_7B) || \
((__LENGTH__) == UART_WORDLENGTH_8B) || \
((__LENGTH__) == UART_WORDLENGTH_9B))
#define UART_WORDLENGTH_7B
Definition stm32h7xx_hal_uart_ex.h:74
#define UART_WORDLENGTH_8B
Definition stm32h7xx_hal_uart_ex.h:75
#define UART_WORDLENGTH_9B
Definition stm32h7xx_hal_uart_ex.h:76
Parameters
__LENGTH__UART frame length.
Return values
SET(LENGTH is valid) or RESET (LENGTH is invalid)
◆ UART_GETCLOCKSOURCE
#define UART_GETCLOCKSOURCE ( __HANDLE__,
__CLOCKSOURCE__ )
Parameters
__HANDLE__specifies the UART Handle.
__CLOCKSOURCE__output variable.
Return values
UART Driver APIclocking source, written in CLOCKSOURCE.
◆ UART_MASK_COMPUTATION
#define UART_MASK_COMPUTATION ( __HANDLE__)
Note
If PCE = 1, the parity bit is not included in the data extracted by the reception API(). This masking operation is not carried out in the case of DMA transfers.
Parameters
Return values
None,themask to apply to UART RDR register is stored in (HANDLE)->Mask field.
