RTEMS 6.3
stm32h7xx_hal_pwr_ex.h
1
18
19/* Define to prevent recursive inclusion -------------------------------------*/
20#ifndef STM32H7xx_HAL_PWR_EX_H
21#define STM32H7xx_HAL_PWR_EX_H
22
23#ifdef __cplusplus
24 extern "C" {
25#endif /* __cplusplus */
26
27/* Includes ------------------------------------------------------------------*/
28#include "stm32h7xx_hal_def.h"
29
33
37
38/* Exported types ------------------------------------------------------------*/
46typedef struct
47{
48 uint32_t AVDLevel;
52
53 uint32_t Mode;
58
62typedef struct
63{
64 uint32_t WakeUpPin;
68
69 uint32_t PinPolarity;
73
74 uint32_t PinPull;
79
80#if defined (PWR_CSR1_MMCVDO)
84typedef enum
85{
86 PWR_MMC_VOLTAGE_BELOW_1V2,
87 PWR_MMC_VOLTAGE_EQUAL_ABOVE_1V2
88} PWREx_MMC_VoltageLevel;
89#endif /* defined (PWR_CSR1_MMCVDO) */
90
94
95/* Exported constants --------------------------------------------------------*/
96
105/* High level and No pull (default configuration) */
106#define PWR_WAKEUP_PIN6 PWR_WKUPEPR_WKUPEN6
107#if defined (PWR_WKUPEPR_WKUPEN5)
108#define PWR_WAKEUP_PIN5 PWR_WKUPEPR_WKUPEN5
109#endif /* defined (PWR_WKUPEPR_WKUPEN5) */
110#define PWR_WAKEUP_PIN4 PWR_WKUPEPR_WKUPEN4
111#if defined (PWR_WKUPEPR_WKUPEN3)
112#define PWR_WAKEUP_PIN3 PWR_WKUPEPR_WKUPEN3
113#endif /* defined (PWR_WKUPEPR_WKUPEN3) */
114#define PWR_WAKEUP_PIN2 PWR_WKUPEPR_WKUPEN2
115#define PWR_WAKEUP_PIN1 PWR_WKUPEPR_WKUPEN1
116
117/* High level and No pull */
118#define PWR_WAKEUP_PIN6_HIGH PWR_WKUPEPR_WKUPEN6
119#if defined (PWR_WKUPEPR_WKUPEN5)
120#define PWR_WAKEUP_PIN5_HIGH PWR_WKUPEPR_WKUPEN5
121#endif /* defined (PWR_WKUPEPR_WKUPEN5) */
122#define PWR_WAKEUP_PIN4_HIGH PWR_WKUPEPR_WKUPEN4
123#if defined (PWR_WKUPEPR_WKUPEN3)
124#define PWR_WAKEUP_PIN3_HIGH PWR_WKUPEPR_WKUPEN3
125#endif /* defined (PWR_WKUPEPR_WKUPEN3) */
126#define PWR_WAKEUP_PIN2_HIGH PWR_WKUPEPR_WKUPEN2
127#define PWR_WAKEUP_PIN1_HIGH PWR_WKUPEPR_WKUPEN1
128
129/* Low level and No pull */
130#define PWR_WAKEUP_PIN6_LOW (PWR_WKUPEPR_WKUPP6 | PWR_WKUPEPR_WKUPEN6)
131#if defined (PWR_WKUPEPR_WKUPP5)
132#define PWR_WAKEUP_PIN5_LOW (PWR_WKUPEPR_WKUPP5 | PWR_WKUPEPR_WKUPEN5)
133#endif /* defined (PWR_WKUPEPR_WKUPP5) */
134#define PWR_WAKEUP_PIN4_LOW (PWR_WKUPEPR_WKUPP4 | PWR_WKUPEPR_WKUPEN4)
135#if defined (PWR_WKUPEPR_WKUPP3)
136#define PWR_WAKEUP_PIN3_LOW (PWR_WKUPEPR_WKUPP3 | PWR_WKUPEPR_WKUPEN3)
137#endif /* defined (PWR_WKUPEPR_WKUPP3) */
138#define PWR_WAKEUP_PIN2_LOW (PWR_WKUPEPR_WKUPP2 | PWR_WKUPEPR_WKUPEN2)
139#define PWR_WAKEUP_PIN1_LOW (PWR_WKUPEPR_WKUPP1 | PWR_WKUPEPR_WKUPEN1)
143
148#define PWR_PIN_POLARITY_HIGH (0x00000000U)
149#define PWR_PIN_POLARITY_LOW (0x00000001U)
153
158#define PWR_PIN_NO_PULL (0x00000000U)
159#define PWR_PIN_PULL_UP (0x00000001U)
160#define PWR_PIN_PULL_DOWN (0x00000002U)
164
169#define PWR_WAKEUP_FLAG1 PWR_WKUPFR_WKUPF1
170#define PWR_WAKEUP_FLAG2 PWR_WKUPFR_WKUPF2
171#if defined (PWR_WKUPFR_WKUPF3)
172#define PWR_WAKEUP_FLAG3 PWR_WKUPFR_WKUPF3
173#endif /* defined (PWR_WKUPFR_WKUPF3) */
174#define PWR_WAKEUP_FLAG4 PWR_WKUPFR_WKUPF4
175#if defined (PWR_WKUPFR_WKUPF5)
176#define PWR_WAKEUP_FLAG5 PWR_WKUPFR_WKUPF5
177#endif /* defined (PWR_WKUPFR_WKUPF5) */
178#define PWR_WAKEUP_FLAG6 PWR_WKUPFR_WKUPF6
179#if defined (PWR_WKUPFR_WKUPF3)
180#define PWR_WAKEUP_FLAG_ALL (PWR_WKUPFR_WKUPF1 | PWR_WKUPFR_WKUPF2 |\
181 PWR_WKUPFR_WKUPF3 | PWR_WKUPFR_WKUPF4 |\
182 PWR_WKUPFR_WKUPF5 | PWR_WKUPFR_WKUPF6)
183#else
184#define PWR_WAKEUP_FLAG_ALL (PWR_WKUPFR_WKUPF1 | PWR_WKUPFR_WKUPF2 |\
185 PWR_WKUPFR_WKUPF4 | PWR_WKUPFR_WKUPF6)
186#endif /* defined (PWR_WKUPFR_WKUPF3) */
190
191#if defined (DUAL_CORE)
196#define PWR_CORE_CPU1 (0x00000000U)
197#define PWR_CORE_CPU2 (0x00000001U)
201#endif /* defined (DUAL_CORE) */
202
207#define PWR_D1_DOMAIN (0x00000000U)
208#if defined (PWR_CPUCR_PDDS_D2)
209#define PWR_D2_DOMAIN (0x00000001U)
210#endif /* defined (PWR_CPUCR_PDDS_D2) */
211#define PWR_D3_DOMAIN (0x00000002U)
215
220#if defined (DUAL_CORE)
221#define PWR_D1_DOMAIN_FLAGS (0x00000000U)
222#define PWR_D2_DOMAIN_FLAGS (0x00000001U)
223#define PWR_ALL_DOMAIN_FLAGS (0x00000002U)
224#else
225#define PWR_CPU_FLAGS (0x00000000U)
226#endif /* defined (DUAL_CORE) */
230
235#define PWR_D3_DOMAIN_STOP (0x00000000U)
236#define PWR_D3_DOMAIN_RUN (0x00000800U)
237
241
246#define PWR_LDO_SUPPLY PWR_CR3_LDOEN
247#if defined (SMPS)
248#define PWR_DIRECT_SMPS_SUPPLY PWR_CR3_SMPSEN
249#define PWR_SMPS_1V8_SUPPLIES_LDO (PWR_CR3_SMPSLEVEL_0 | PWR_CR3_SMPSEN | PWR_CR3_LDOEN)
250#define PWR_SMPS_2V5_SUPPLIES_LDO (PWR_CR3_SMPSLEVEL_1 | PWR_CR3_SMPSEN | PWR_CR3_LDOEN)
251#define PWR_SMPS_1V8_SUPPLIES_EXT_AND_LDO (PWR_CR3_SMPSLEVEL_0 | PWR_CR3_SMPSEXTHP | PWR_CR3_SMPSEN | PWR_CR3_LDOEN)
252#define PWR_SMPS_2V5_SUPPLIES_EXT_AND_LDO (PWR_CR3_SMPSLEVEL_1 | PWR_CR3_SMPSEXTHP | PWR_CR3_SMPSEN | PWR_CR3_LDOEN)
253#define PWR_SMPS_1V8_SUPPLIES_EXT (PWR_CR3_SMPSLEVEL_0 | PWR_CR3_SMPSEXTHP | PWR_CR3_SMPSEN | PWR_CR3_BYPASS)
254#define PWR_SMPS_2V5_SUPPLIES_EXT (PWR_CR3_SMPSLEVEL_1 | PWR_CR3_SMPSEXTHP | PWR_CR3_SMPSEN | PWR_CR3_BYPASS)
255#endif /* defined (SMPS) */
256#define PWR_EXTERNAL_SOURCE_SUPPLY PWR_CR3_BYPASS
257
258#if defined (SMPS)
259#define PWR_SUPPLY_CONFIG_MASK (PWR_CR3_SMPSLEVEL | PWR_CR3_SMPSEXTHP | \
260 PWR_CR3_SMPSEN | PWR_CR3_LDOEN | PWR_CR3_BYPASS)
261#else
262#define PWR_SUPPLY_CONFIG_MASK (PWR_CR3_SCUEN | PWR_CR3_LDOEN | PWR_CR3_BYPASS)
263#endif /* defined (SMPS) */
267
268
273#define PWR_AVDLEVEL_0 PWR_CR1_ALS_LEV0
275#define PWR_AVDLEVEL_1 PWR_CR1_ALS_LEV1
277#define PWR_AVDLEVEL_2 PWR_CR1_ALS_LEV2
279#define PWR_AVDLEVEL_3 PWR_CR1_ALS_LEV3
284
289#define PWR_AVD_MODE_NORMAL (0x00000000U)
290#define PWR_AVD_MODE_IT_RISING (0x00010001U)
291#define PWR_AVD_MODE_IT_FALLING (0x00010002U)
292#define PWR_AVD_MODE_IT_RISING_FALLING (0x00010003U)
293#define PWR_AVD_MODE_EVENT_RISING (0x00020001U)
294#define PWR_AVD_MODE_EVENT_FALLING (0x00020002U)
295#define PWR_AVD_MODE_EVENT_RISING_FALLING (0x00020003U)
299
304#define PWR_REGULATOR_SVOS_SCALE5 (PWR_CR1_SVOS_0)
305#define PWR_REGULATOR_SVOS_SCALE4 (PWR_CR1_SVOS_1)
306#define PWR_REGULATOR_SVOS_SCALE3 (PWR_CR1_SVOS_0 | PWR_CR1_SVOS_1)
310
315#define PWR_BATTERY_CHARGING_RESISTOR_5 (0x00000000U)
316#define PWR_BATTERY_CHARGING_RESISTOR_1_5 PWR_CR3_VBRS
320
325#define PWR_VBAT_BETWEEN_HIGH_LOW_THRESHOLD (0x00000000U)
326#define PWR_VBAT_BELOW_LOW_THRESHOLD PWR_CR2_VBATL
327#define PWR_VBAT_ABOVE_HIGH_THRESHOLD PWR_CR2_VBATH
331
336#define PWR_TEMP_BETWEEN_HIGH_LOW_THRESHOLD (0x00000000U)
337#define PWR_TEMP_BELOW_LOW_THRESHOLD PWR_CR2_TEMPL
338#define PWR_TEMP_ABOVE_HIGH_THRESHOLD PWR_CR2_TEMPH
346#define PWR_EXTI_LINE_AVD EXTI_IMR1_IM16
351
352#if defined (PWR_CR1_SRDRAMSO)
357#define PWR_SRD_AHB_MEMORY_BLOCK PWR_CR1_SRDRAMSO
358#define PWR_USB_FDCAN_MEMORY_BLOCK PWR_CR1_HSITFSO
359#define PWR_GFXMMU_JPEG_MEMORY_BLOCK PWR_CR1_GFXSO
360#define PWR_TCM_ECM_MEMORY_BLOCK PWR_CR1_ITCMSO
361#define PWR_RAM1_AHB_MEMORY_BLOCK PWR_CR1_AHBRAM1SO
362#define PWR_RAM2_AHB_MEMORY_BLOCK PWR_CR1_AHBRAM2SO
363#define PWR_RAM1_AXI_MEMORY_BLOCK PWR_CR1_AXIRAM1SO
364#define PWR_RAM2_AXI_MEMORY_BLOCK PWR_CR1_AXIRAM2SO
365#define PWR_RAM3_AXI_MEMORY_BLOCK PWR_CR1_AXIRAM3SO
366#define PWR_MEMORY_BLOCK_KEEP_ON 0U
367#define PWR_MEMORY_BLOCK_SHUT_OFF 1U
371#endif /* defined (PWR_CR1_SRDRAMSO) */
375
376/* Exported macro ------------------------------------------------------------*/
377
382
387#define __HAL_PWR_AVD_EXTI_ENABLE_IT() SET_BIT(EXTI->IMR1, PWR_EXTI_LINE_AVD)
388
389#if defined (DUAL_CORE)
394#define __HAL_PWR_AVD_EXTID2_ENABLE_IT() SET_BIT(EXTI_D2->IMR1, PWR_EXTI_LINE_AVD)
395#endif /* defined (DUAL_CORE) */
396
401#define __HAL_PWR_AVD_EXTI_DISABLE_IT() CLEAR_BIT(EXTI->IMR1, PWR_EXTI_LINE_AVD)
402
403#if defined (DUAL_CORE)
408#define __HAL_PWR_AVD_EXTID2_DISABLE_IT() CLEAR_BIT(EXTI_D2->IMR1, PWR_EXTI_LINE_AVD)
409#endif /* defined (DUAL_CORE) */
410
415#define __HAL_PWR_AVD_EXTI_ENABLE_EVENT() SET_BIT(EXTI->EMR1, PWR_EXTI_LINE_AVD)
416
417#if defined (DUAL_CORE)
422#define __HAL_PWR_AVD_EXTID2_ENABLE_EVENT() SET_BIT(EXTI_D2->EMR1, PWR_EXTI_LINE_AVD)
423#endif /* defined (DUAL_CORE) */
424
429#define __HAL_PWR_AVD_EXTI_DISABLE_EVENT() CLEAR_BIT(EXTI->EMR1, PWR_EXTI_LINE_AVD)
430
431#if defined (DUAL_CORE)
436#define __HAL_PWR_AVD_EXTID2_DISABLE_EVENT() CLEAR_BIT(EXTI_D2->EMR1, PWR_EXTI_LINE_AVD)
437#endif /* defined (DUAL_CORE) */
438
443#define __HAL_PWR_AVD_EXTI_ENABLE_RISING_EDGE() SET_BIT(EXTI->RTSR1, PWR_EXTI_LINE_AVD)
444
449#define __HAL_PWR_AVD_EXTI_DISABLE_RISING_EDGE() CLEAR_BIT(EXTI->RTSR1, PWR_EXTI_LINE_AVD)
450
455#define __HAL_PWR_AVD_EXTI_ENABLE_FALLING_EDGE() SET_BIT(EXTI->FTSR1, PWR_EXTI_LINE_AVD)
456
461#define __HAL_PWR_AVD_EXTI_DISABLE_FALLING_EDGE() CLEAR_BIT(EXTI->FTSR1, PWR_EXTI_LINE_AVD)
462
467#define __HAL_PWR_AVD_EXTI_ENABLE_RISING_FALLING_EDGE() \
468do { \
469 __HAL_PWR_AVD_EXTI_ENABLE_RISING_EDGE(); \
470 __HAL_PWR_AVD_EXTI_ENABLE_FALLING_EDGE(); \
471} while(0);
472
477#define __HAL_PWR_AVD_EXTI_DISABLE_RISING_FALLING_EDGE() \
478do { \
479 __HAL_PWR_AVD_EXTI_DISABLE_RISING_EDGE(); \
480 __HAL_PWR_AVD_EXTI_DISABLE_FALLING_EDGE(); \
481} while(0);
482
487#define __HAL_PWR_AVD_EXTI_GET_FLAG() ((READ_BIT(EXTI->PR1, PWR_EXTI_LINE_AVD) == PWR_EXTI_LINE_AVD) ? 1UL : 0UL)
488
489#if defined (DUAL_CORE)
494#define __HAL_PWR_AVD_EXTID2_GET_FLAG() ((READ_BIT(EXTI_D2->PR1, PWR_EXTI_LINE_AVD) == PWR_EXTI_LINE_AVD) ? 1UL : 0UL)
495#endif /* defined (DUAL_CORE) */
496
501#define __HAL_PWR_AVD_EXTI_CLEAR_FLAG() SET_BIT(EXTI->PR1, PWR_EXTI_LINE_AVD)
502
503#if defined (DUAL_CORE)
508#define __HAL_PWR_AVD_EXTID2_CLEAR_FLAG() SET_BIT(EXTI_D2->PR1, PWR_EXTI_LINE_AVD)
509#endif /* defined (DUAL_CORE) */
510
515#define __HAL_PWR_AVD_EXTI_GENERATE_SWIT() SET_BIT(EXTI->SWIER1, PWR_EXTI_LINE_AVD)
519
520/* Exported functions --------------------------------------------------------*/
521
525
529HAL_StatusTypeDef HAL_PWREx_ConfigSupply (uint32_t SupplySource);
530uint32_t HAL_PWREx_GetSupplyConfig (void);
531HAL_StatusTypeDef HAL_PWREx_ControlVoltageScaling (uint32_t VoltageScaling);
532uint32_t HAL_PWREx_GetVoltageRange (void);
533HAL_StatusTypeDef HAL_PWREx_ControlStopModeVoltageScaling (uint32_t VoltageScaling);
534uint32_t HAL_PWREx_GetStopModeVoltageRange (void);
538
542/* System low power control functions */
543#if defined (PWR_CPUCR_RETDS_CD)
544void HAL_PWREx_EnterSTOP2Mode (uint32_t Regulator, uint8_t STOPEntry);
545#endif /* defined (PWR_CPUCR_RETDS_CD) */
546void HAL_PWREx_EnterSTOPMode (uint32_t Regulator, uint8_t STOPEntry, uint32_t Domain);
547void HAL_PWREx_EnterSTANDBYMode (uint32_t Domain);
548void HAL_PWREx_ConfigD3Domain (uint32_t D3State);
549/* Clear Cortex-Mx pending flag */
550void HAL_PWREx_ClearPendingEvent (void);
551#if defined (DUAL_CORE)
552/* Clear domain flags */
553void HAL_PWREx_ClearDomainFlags (uint32_t DomainFlags);
554/* Core Hold/Release functions */
555HAL_StatusTypeDef HAL_PWREx_HoldCore (uint32_t CPU);
556void HAL_PWREx_ReleaseCore (uint32_t CPU);
557#endif /* defined (DUAL_CORE) */
558/* Flash low power control functions */
559void HAL_PWREx_EnableFlashPowerDown (void);
560void HAL_PWREx_DisableFlashPowerDown (void);
561#if defined (PWR_CR1_SRDRAMSO)
562/* Memory shut-off functions */
563void HAL_PWREx_EnableMemoryShutOff (uint32_t MemoryBlock);
564void HAL_PWREx_DisableMemoryShutOff (uint32_t MemoryBlock);
565#endif /* defined(PWR_CR1_SRDRAMSO) */
566/* Wakeup Pins control functions */
567void HAL_PWREx_EnableWakeUpPin (PWREx_WakeupPinTypeDef *sPinParams);
568void HAL_PWREx_DisableWakeUpPin (uint32_t WakeUpPin);
569uint32_t HAL_PWREx_GetWakeupFlag (uint32_t WakeUpFlag);
570HAL_StatusTypeDef HAL_PWREx_ClearWakeupFlag (uint32_t WakeUpFlag);
571/* Power Wakeup PIN IRQ Handler */
572void HAL_PWREx_WAKEUP_PIN_IRQHandler (void);
573void HAL_PWREx_WKUP1_Callback (void);
574void HAL_PWREx_WKUP2_Callback (void);
575#if defined (PWR_WKUPEPR_WKUPEN3)
576void HAL_PWREx_WKUP3_Callback (void);
577#endif /* defined (PWR_WKUPEPR_WKUPEN3) */
578void HAL_PWREx_WKUP4_Callback (void);
579#if defined (PWR_WKUPEPR_WKUPEN5)
580void HAL_PWREx_WKUP5_Callback (void);
581#endif /* defined (PWR_WKUPEPR_WKUPEN5) */
582void HAL_PWREx_WKUP6_Callback (void);
586
590/* Backup regulator control functions */
591HAL_StatusTypeDef HAL_PWREx_EnableBkUpReg (void);
592HAL_StatusTypeDef HAL_PWREx_DisableBkUpReg (void);
593/* USB regulator control functions */
594HAL_StatusTypeDef HAL_PWREx_EnableUSBReg (void);
595HAL_StatusTypeDef HAL_PWREx_DisableUSBReg (void);
596void HAL_PWREx_EnableUSBVoltageDetector (void);
597void HAL_PWREx_DisableUSBVoltageDetector (void);
598/* Battery control functions */
599void HAL_PWREx_EnableBatteryCharging (uint32_t ResistorValue);
600void HAL_PWREx_DisableBatteryCharging (void);
601#if defined (PWR_CR1_BOOSTE)
602/* Analog Booster functions */
603void HAL_PWREx_EnableAnalogBooster (void);
604void HAL_PWREx_DisableAnalogBooster (void);
605#endif /* PWR_CR1_BOOSTE */
609
613/* Power VBAT/Temperature monitoring functions */
614void HAL_PWREx_EnableMonitoring (void);
615void HAL_PWREx_DisableMonitoring (void);
616uint32_t HAL_PWREx_GetTemperatureLevel (void);
617uint32_t HAL_PWREx_GetVBATLevel (void);
618#if defined (PWR_CSR1_MMCVDO)
619PWREx_MMC_VoltageLevel HAL_PWREx_GetMMCVoltage (void);
620#endif /* PWR_CSR1_MMCVDO */
621/* Power AVD configuration functions */
622void HAL_PWREx_ConfigAVD (PWREx_AVDTypeDef *sConfigAVD);
623void HAL_PWREx_EnableAVD (void);
624void HAL_PWREx_DisableAVD (void);
625/* Power PVD/AVD IRQ Handler */
626void HAL_PWREx_PVD_AVD_IRQHandler (void);
627void HAL_PWREx_AVDCallback (void);
631
635/* Private types -------------------------------------------------------------*/
636/* Private variables ---------------------------------------------------------*/
637/* Private constants ---------------------------------------------------------*/
638/* Private macros ------------------------------------------------------------*/
643
648/* Check PWR regulator configuration parameter */
649#if defined (SMPS)
650#define IS_PWR_SUPPLY(PWR_SOURCE) (((PWR_SOURCE) == PWR_LDO_SUPPLY) ||\
651 ((PWR_SOURCE) == PWR_DIRECT_SMPS_SUPPLY) ||\
652 ((PWR_SOURCE) == PWR_SMPS_1V8_SUPPLIES_LDO) ||\
653 ((PWR_SOURCE) == PWR_SMPS_2V5_SUPPLIES_LDO) ||\
654 ((PWR_SOURCE) == PWR_SMPS_1V8_SUPPLIES_EXT_AND_LDO) ||\
655 ((PWR_SOURCE) == PWR_SMPS_2V5_SUPPLIES_EXT_AND_LDO) ||\
656 ((PWR_SOURCE) == PWR_SMPS_1V8_SUPPLIES_EXT) ||\
657 ((PWR_SOURCE) == PWR_SMPS_2V5_SUPPLIES_EXT) ||\
658 ((PWR_SOURCE) == PWR_EXTERNAL_SOURCE_SUPPLY))
659
660#else
661#define IS_PWR_SUPPLY(PWR_SOURCE) (((PWR_SOURCE) == PWR_LDO_SUPPLY) ||\
662 ((PWR_SOURCE) == PWR_EXTERNAL_SOURCE_SUPPLY))
663#endif /* defined (SMPS) */
664
665/* Check PWR regulator configuration in STOP mode parameter */
666#define IS_PWR_STOP_MODE_REGULATOR_VOLTAGE(VOLTAGE) (((VOLTAGE) == PWR_REGULATOR_SVOS_SCALE3) ||\
667 ((VOLTAGE) == PWR_REGULATOR_SVOS_SCALE4) ||\
668 ((VOLTAGE) == PWR_REGULATOR_SVOS_SCALE5))
669
670/* Check PWR domain parameter */
671#if defined (PWR_CPUCR_PDDS_D2)
672#define IS_PWR_DOMAIN(DOMAIN) (((DOMAIN) == PWR_D1_DOMAIN) ||\
673 ((DOMAIN) == PWR_D2_DOMAIN) ||\
674 ((DOMAIN) == PWR_D3_DOMAIN))
675#else
676#define IS_PWR_DOMAIN(DOMAIN) (((DOMAIN) == PWR_D1_DOMAIN) ||\
677 ((DOMAIN) == PWR_D3_DOMAIN))
678#endif /* defined (PWR_CPUCR_PDDS_D2) */
679
680/* Check D3/SRD domain state parameter */
681#define IS_D3_STATE(STATE) (((STATE) == PWR_D3_DOMAIN_STOP) ||\
682 ((STATE) == PWR_D3_DOMAIN_RUN))
683
684/* Check wake up pin parameter */
685#if defined (PWR_WKUPEPR_WKUPEN3)
686#define IS_PWR_WAKEUP_PIN(PIN) (((PIN) == PWR_WAKEUP_PIN1) ||\
687 ((PIN) == PWR_WAKEUP_PIN2) ||\
688 ((PIN) == PWR_WAKEUP_PIN3) ||\
689 ((PIN) == PWR_WAKEUP_PIN4) ||\
690 ((PIN) == PWR_WAKEUP_PIN5) ||\
691 ((PIN) == PWR_WAKEUP_PIN6) ||\
692 ((PIN) == PWR_WAKEUP_PIN1_HIGH) ||\
693 ((PIN) == PWR_WAKEUP_PIN2_HIGH) ||\
694 ((PIN) == PWR_WAKEUP_PIN3_HIGH) ||\
695 ((PIN) == PWR_WAKEUP_PIN4_HIGH) ||\
696 ((PIN) == PWR_WAKEUP_PIN5_HIGH) ||\
697 ((PIN) == PWR_WAKEUP_PIN6_HIGH) ||\
698 ((PIN) == PWR_WAKEUP_PIN1_LOW) ||\
699 ((PIN) == PWR_WAKEUP_PIN2_LOW) ||\
700 ((PIN) == PWR_WAKEUP_PIN3_LOW) ||\
701 ((PIN) == PWR_WAKEUP_PIN4_LOW) ||\
702 ((PIN) == PWR_WAKEUP_PIN5_LOW) ||\
703 ((PIN) == PWR_WAKEUP_PIN6_LOW))
704#else
705#define IS_PWR_WAKEUP_PIN(PIN) (((PIN) == PWR_WAKEUP_PIN1) ||\
706 ((PIN) == PWR_WAKEUP_PIN2) ||\
707 ((PIN) == PWR_WAKEUP_PIN4) ||\
708 ((PIN) == PWR_WAKEUP_PIN6) ||\
709 ((PIN) == PWR_WAKEUP_PIN1_HIGH) ||\
710 ((PIN) == PWR_WAKEUP_PIN2_HIGH) ||\
711 ((PIN) == PWR_WAKEUP_PIN4_HIGH) ||\
712 ((PIN) == PWR_WAKEUP_PIN6_HIGH) ||\
713 ((PIN) == PWR_WAKEUP_PIN1_LOW) ||\
714 ((PIN) == PWR_WAKEUP_PIN2_LOW) ||\
715 ((PIN) == PWR_WAKEUP_PIN4_LOW) ||\
716 ((PIN) == PWR_WAKEUP_PIN6_LOW))
717#endif /* defined (PWR_WKUPEPR_WKUPEN3) */
718
719/* Check wake up pin polarity parameter */
720#define IS_PWR_WAKEUP_PIN_POLARITY(POLARITY) (((POLARITY) == PWR_PIN_POLARITY_HIGH) ||\
721 ((POLARITY) == PWR_PIN_POLARITY_LOW))
722
723/* Check wake up pin pull configuration parameter */
724#define IS_PWR_WAKEUP_PIN_PULL(PULL) (((PULL) == PWR_PIN_NO_PULL) ||\
725 ((PULL) == PWR_PIN_PULL_UP) ||\
726 ((PULL) == PWR_PIN_PULL_DOWN))
727
728/* Check wake up flag parameter */
729#if defined (PWR_WKUPEPR_WKUPEN3)
730#define IS_PWR_WAKEUP_FLAG(FLAG) (((FLAG) == PWR_WAKEUP_FLAG1) ||\
731 ((FLAG) == PWR_WAKEUP_FLAG2) ||\
732 ((FLAG) == PWR_WAKEUP_FLAG3) ||\
733 ((FLAG) == PWR_WAKEUP_FLAG4) ||\
734 ((FLAG) == PWR_WAKEUP_FLAG5) ||\
735 ((FLAG) == PWR_WAKEUP_FLAG6) ||\
736 ((FLAG) == PWR_WAKEUP_FLAG_ALL))
737#else
738#define IS_PWR_WAKEUP_FLAG(FLAG) (((FLAG) == PWR_WAKEUP_FLAG1) ||\
739 ((FLAG) == PWR_WAKEUP_FLAG2) ||\
740 ((FLAG) == PWR_WAKEUP_FLAG4) ||\
741 ((FLAG) == PWR_WAKEUP_FLAG6) ||\
742 ((FLAG) == PWR_WAKEUP_FLAG_ALL))
743#endif /* defined (PWR_WKUPEPR_WKUPEN3) */
744
745/* Check wake up flag parameter */
746#define IS_PWR_AVD_LEVEL(LEVEL) (((LEVEL) == PWR_AVDLEVEL_0) ||\
747 ((LEVEL) == PWR_AVDLEVEL_1) ||\
748 ((LEVEL) == PWR_AVDLEVEL_2) ||\
749 ((LEVEL) == PWR_AVDLEVEL_3))
750
751/* Check AVD mode parameter */
752#define IS_PWR_AVD_MODE(MODE) (((MODE) == PWR_AVD_MODE_IT_RISING) ||\
753 ((MODE) == PWR_AVD_MODE_IT_FALLING) ||\
754 ((MODE) == PWR_AVD_MODE_IT_RISING_FALLING) ||\
755 ((MODE) == PWR_AVD_MODE_EVENT_RISING) ||\
756 ((MODE) == PWR_AVD_MODE_EVENT_FALLING) ||\
757 ((MODE) == PWR_AVD_MODE_NORMAL) ||\
758 ((MODE) == PWR_AVD_MODE_EVENT_RISING_FALLING))
759
760/* Check resistor battery parameter */
761#define IS_PWR_BATTERY_RESISTOR_SELECT(RESISTOR) (((RESISTOR) == PWR_BATTERY_CHARGING_RESISTOR_5) ||\
762 ((RESISTOR) == PWR_BATTERY_CHARGING_RESISTOR_1_5))
763/* Check D1/CD CPU ID parameter */
764#define IS_PWR_D1_CPU(CPU) ((CPU) == CM7_CPUID)
765
766#if defined (DUAL_CORE)
767/* Check CPU parameter */
768#define IS_PWR_CORE(CPU) (((CPU) == PWR_CORE_CPU1) || ((CPU) == PWR_CORE_CPU2))
769
770/* Check D2 CPU ID parameter */
771#define IS_PWR_D2_CPU(CPU) ((CPU) == CM4_CPUID)
772
773/* Check PWR domain flag parameter */
774#define IS_PWR_DOMAIN_FLAG(FLAG) (((FLAG) == PWR_D1_DOMAIN_FLAGS) || \
775 ((FLAG) == PWR_D2_DOMAIN_FLAGS) || \
776 ((FLAG) == PWR_ALL_DOMAIN_FLAGS))
777#endif /* defined (DUAL_CORE) */
778
779#if defined (PWR_CR1_SRDRAMSO)
780/* Check memory block parameter */
781#define IS_PWR_MEMORY_BLOCK(BLOCK) (((BLOCK) == PWR_SRD_AHB_MEMORY_BLOCK) || \
782 ((BLOCK) == PWR_USB_FDCAN_MEMORY_BLOCK) || \
783 ((BLOCK) == PWR_GFXMMU_JPEG_MEMORY_BLOCK) || \
784 ((BLOCK) == PWR_TCM_ECM_MEMORY_BLOCK) || \
785 ((BLOCK) == PWR_RAM1_AHB_MEMORY_BLOCK) || \
786 ((BLOCK) == PWR_RAM2_AHB_MEMORY_BLOCK) || \
787 ((BLOCK) == PWR_RAM1_AXI_MEMORY_BLOCK) || \
788 ((BLOCK) == PWR_RAM2_AXI_MEMORY_BLOCK) || \
789 ((BLOCK) == PWR_RAM3_AXI_MEMORY_BLOCK))
790#endif /* defined (PWR_CR1_SRDRAMSO) */
797
801
805#ifdef __cplusplus
806}
807#endif /* __cplusplus */
808
809
810#endif /* STM32H7xx_HAL_PWR_EX_H */
811
This file contains HAL common defines, enumeration, macros and structures definitions.
HAL_StatusTypeDef
HAL Status structures definition.
Definition stm32h7xx_hal_def.h:47
PWREx AVD configuration structure definition.
Definition stm32h7xx_hal_pwr_ex.h:47
uint32_t Mode
Definition stm32h7xx_hal_pwr_ex.h:53
uint32_t AVDLevel
Definition stm32h7xx_hal_pwr_ex.h:48
PWREx Wakeup pin configuration structure definition.
Definition stm32h7xx_hal_pwr_ex.h:63
uint32_t WakeUpPin
Definition stm32h7xx_hal_pwr_ex.h:64
Definition stm32h7xx_hal_pwr_ex.h:69
uint32_t PinPull
Definition stm32h7xx_hal_pwr_ex.h:74
