RTEMS 6.3
#define __HAL_PWR_AVD_EXTI_ENABLE_IT()
 Enable the AVD EXTI Line 16.
#define __HAL_PWR_AVD_EXTI_DISABLE_IT()
 Disable the AVD EXTI Line 16.
#define __HAL_PWR_AVD_EXTI_ENABLE_EVENT()
 Enable event on AVD EXTI Line 16.
#define __HAL_PWR_AVD_EXTI_DISABLE_EVENT()
 Disable event on AVD EXTI Line 16.
#define __HAL_PWR_AVD_EXTI_ENABLE_RISING_EDGE()
 Enable the AVD Extended Interrupt Rising Trigger.
#define __HAL_PWR_AVD_EXTI_DISABLE_RISING_EDGE()
 Disable the AVD Extended Interrupt Rising Trigger.
#define __HAL_PWR_AVD_EXTI_ENABLE_FALLING_EDGE()
 Enable the AVD Extended Interrupt Falling Trigger.
#define __HAL_PWR_AVD_EXTI_DISABLE_FALLING_EDGE()
 Disable the AVD Extended Interrupt Falling Trigger.
#define __HAL_PWR_AVD_EXTI_ENABLE_RISING_FALLING_EDGE()
 Enable the AVD Extended Interrupt Rising and Falling Trigger.
#define __HAL_PWR_AVD_EXTI_DISABLE_RISING_FALLING_EDGE()
 Disable the AVD Extended Interrupt Rising & Falling Trigger.
#define __HAL_PWR_AVD_EXTI_GET_FLAG()
 Check whether the specified AVD EXTI interrupt flag is set or not.
#define __HAL_PWR_AVD_EXTI_CLEAR_FLAG()
 Clear the AVD EXTI flag.
#define __HAL_PWR_AVD_EXTI_GENERATE_SWIT()
 Generates a Software interrupt on AVD EXTI line.
◆ __HAL_PWR_AVD_EXTI_CLEAR_FLAG
#define __HAL_PWR_AVD_EXTI_CLEAR_FLAG ( )
Value:
SET_BIT(EXTI->PR1, PWR_EXTI_LINE_AVD)
#define PWR_EXTI_LINE_AVD
Definition stm32h7xx_hal_pwr_ex.h:346
Return values
None.
◆ __HAL_PWR_AVD_EXTI_DISABLE_EVENT
#define __HAL_PWR_AVD_EXTI_DISABLE_EVENT ( )
Value:
CLEAR_BIT(EXTI->EMR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_DISABLE_FALLING_EDGE
#define __HAL_PWR_AVD_EXTI_DISABLE_FALLING_EDGE ( )
Value:
CLEAR_BIT(EXTI->FTSR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_DISABLE_IT
#define __HAL_PWR_AVD_EXTI_DISABLE_IT ( )
Value:
CLEAR_BIT(EXTI->IMR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_DISABLE_RISING_EDGE
#define __HAL_PWR_AVD_EXTI_DISABLE_RISING_EDGE ( )
Value:
CLEAR_BIT(EXTI->RTSR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_DISABLE_RISING_FALLING_EDGE
#define __HAL_PWR_AVD_EXTI_DISABLE_RISING_FALLING_EDGE ( )
Value:
do { \
__HAL_PWR_AVD_EXTI_DISABLE_RISING_EDGE(); \
__HAL_PWR_AVD_EXTI_DISABLE_FALLING_EDGE(); \
} while(0);
Return values
None.
◆ __HAL_PWR_AVD_EXTI_ENABLE_EVENT
#define __HAL_PWR_AVD_EXTI_ENABLE_EVENT ( )
Value:
SET_BIT(EXTI->EMR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_ENABLE_FALLING_EDGE
#define __HAL_PWR_AVD_EXTI_ENABLE_FALLING_EDGE ( )
Value:
SET_BIT(EXTI->FTSR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_ENABLE_IT
#define __HAL_PWR_AVD_EXTI_ENABLE_IT ( )
Value:
SET_BIT(EXTI->IMR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_ENABLE_RISING_EDGE
#define __HAL_PWR_AVD_EXTI_ENABLE_RISING_EDGE ( )
Value:
SET_BIT(EXTI->RTSR1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_ENABLE_RISING_FALLING_EDGE
#define __HAL_PWR_AVD_EXTI_ENABLE_RISING_FALLING_EDGE ( )
Value:
do { \
__HAL_PWR_AVD_EXTI_ENABLE_RISING_EDGE(); \
__HAL_PWR_AVD_EXTI_ENABLE_FALLING_EDGE(); \
} while(0);
Return values
None.
◆ __HAL_PWR_AVD_EXTI_GENERATE_SWIT
#define __HAL_PWR_AVD_EXTI_GENERATE_SWIT ( )
Value:
SET_BIT(EXTI->SWIER1, PWR_EXTI_LINE_AVD)
Return values
None.
◆ __HAL_PWR_AVD_EXTI_GET_FLAG
#define __HAL_PWR_AVD_EXTI_GET_FLAG ( )
Value:
((READ_BIT(EXTI->PR1, PWR_EXTI_LINE_AVD) == PWR_EXTI_LINE_AVD) ? 1UL : 0UL)
Return values
EXTIAVD Line Status.
