RTEMS 6.3
stm32h7xx_hal_flash_ex.h File Reference
Header file of FLASH HAL module. More...
struct  FLASH_EraseInitTypeDef
 FLASH Erase structure definition. More...
struct  FLASH_OBProgramInitTypeDef
 FLASH Option Bytes Program structure definition. More...
struct  FLASH_CRCInitTypeDef
#define FLASH_TYPEERASE_SECTORS   0x00U
#define FLASH_TYPEERASE_MASSERASE   0x01U
#define OB_WRPSTATE_DISABLE   0x00000000U
#define OB_WRPSTATE_ENABLE   0x00000001U
#define OPTIONBYTE_WRP   0x01U
#define OPTIONBYTE_RDP   0x02U
#define OPTIONBYTE_USER   0x04U
#define OPTIONBYTE_PCROP   0x08U
#define OPTIONBYTE_BOR   0x10U
#define OPTIONBYTE_SECURE_AREA   0x20U
#define OPTIONBYTE_BOOTADD   0x40U
#define OPTIONBYTE_ALL
#define OB_RDP_LEVEL_0   0xAA00U
#define OB_RDP_LEVEL_1   0x5500U
#define OB_RDP_LEVEL_2   0xCC00U
#define OB_IWDG_SW   OB_IWDG1_SW
#define OB_IWDG_HW   OB_IWDG1_HW
#define OB_STOP_NO_RST   0x40U
#define OB_STOP_RST   0x00U
#define OB_STDBY_NO_RST   0x80U
#define OB_STDBY_RST   0x00U
#define OB_IWDG_STOP_FREEZE   0x00000000U
#define OB_IWDG_STOP_ACTIVE   FLASH_OPTSR_FZ_IWDG_STOP
#define OB_IWDG_STDBY_FREEZE   0x00000000U
#define OB_IWDG_STDBY_ACTIVE   FLASH_OPTSR_FZ_IWDG_SDBY
#define OB_BOR_LEVEL0   0x00000000U
#define OB_BOR_LEVEL1   FLASH_OPTSR_BOR_LEV_0
#define OB_BOR_LEVEL2   FLASH_OPTSR_BOR_LEV_1
#define OB_BOR_LEVEL3   (FLASH_OPTSR_BOR_LEV_1 | FLASH_OPTSR_BOR_LEV_0)
#define OB_BOOTADDR_ITCM_RAM   0x0000U
#define OB_BOOTADDR_SYSTEM   0x0040U
#define OB_BOOTADDR_ITCM_FLASH   0x0080U
#define OB_BOOTADDR_AXIM_FLASH   0x2000U
#define OB_BOOTADDR_DTCM_RAM   0x8000U
#define OB_BOOTADDR_SRAM1   0x8004U
#define OB_BOOTADDR_SRAM2   0x8013U
#define FLASH_LATENCY_0   FLASH_ACR_LATENCY_0WS
#define FLASH_LATENCY_1   FLASH_ACR_LATENCY_1WS
#define FLASH_LATENCY_2   FLASH_ACR_LATENCY_2WS
#define FLASH_LATENCY_3   FLASH_ACR_LATENCY_3WS
#define FLASH_LATENCY_4   FLASH_ACR_LATENCY_4WS
#define FLASH_LATENCY_5   FLASH_ACR_LATENCY_5WS
#define FLASH_LATENCY_6   FLASH_ACR_LATENCY_6WS
#define FLASH_LATENCY_7   FLASH_ACR_LATENCY_7WS
#define FLASH_LATENCY_8   FLASH_ACR_LATENCY_8WS
#define FLASH_LATENCY_9   FLASH_ACR_LATENCY_9WS
#define FLASH_LATENCY_10   FLASH_ACR_LATENCY_10WS
#define FLASH_LATENCY_11   FLASH_ACR_LATENCY_11WS
#define FLASH_LATENCY_12   FLASH_ACR_LATENCY_12WS
#define FLASH_LATENCY_13   FLASH_ACR_LATENCY_13WS
#define FLASH_LATENCY_14   FLASH_ACR_LATENCY_14WS
#define FLASH_LATENCY_15   FLASH_ACR_LATENCY_15WS
#define FLASH_BANK_1   0x01U
#define OB_PCROP_RDP_NOT_ERASE   0x00000000U
#define OB_PCROP_RDP_ERASE   FLASH_PRAR_DMEP
#define OB_WRP_SECTOR_0   0x00000001U
#define OB_WRP_SECTOR_1   0x00000002U
#define OB_WRP_SECTOR_2   0x00000004U
#define OB_WRP_SECTOR_3   0x00000008U
#define OB_WRP_SECTOR_4   0x00000010U
#define OB_WRP_SECTOR_5   0x00000020U
#define OB_WRP_SECTOR_6   0x00000040U
#define OB_WRP_SECTOR_7   0x00000080U
#define OB_WRP_SECTOR_ALL   0x000000FFU
#define OB_SECURITY_DISABLE   0x00000000U
#define OB_SECURITY_ENABLE   FLASH_OPTSR_SECURITY
#define OB_ST_RAM_SIZE_2KB   0x00000000U
#define OB_ST_RAM_SIZE_4KB   FLASH_OPTSR_ST_RAM_SIZE_0
#define OB_ST_RAM_SIZE_8KB   FLASH_OPTSR_ST_RAM_SIZE_1
#define OB_ST_RAM_SIZE_16KB   FLASH_OPTSR_ST_RAM_SIZE
#define OB_IWDG1_SW   FLASH_OPTSR_IWDG1_SW
#define OB_IWDG1_HW   0x00000000U
#define OB_STOP_RST_D1   0x00000000U
#define OB_STOP_NO_RST_D1   FLASH_OPTSR_NRST_STOP_D1
#define OB_STDBY_RST_D1   0x00000000U
#define OB_STDBY_NO_RST_D1   FLASH_OPTSR_NRST_STBY_D1
#define OB_IOHSLV_DISABLE   0x00000000U
#define OB_IOHSLV_ENABLE   FLASH_OPTSR_IO_HSLV
#define OB_USER_IWDG1_SW   0x0001U
#define OB_USER_NRST_STOP_D1   0x0002U
#define OB_USER_NRST_STDBY_D1   0x0004U
#define OB_USER_IWDG_STOP   0x0008U
#define OB_USER_IWDG_STDBY   0x0010U
#define OB_USER_ST_RAM_SIZE   0x0020U
#define OB_USER_SECURITY   0x0040U
#define OB_USER_IOHSLV   0x0080U
#define OB_USER_ALL
#define OB_BOOT_ADD0   0x01U
#define OB_BOOT_ADD1   0x02U
#define OB_BOOT_ADD_BOTH   0x03U
#define OB_SECURE_RDP_NOT_ERASE   0x00000000U
#define OB_SECURE_RDP_ERASE   FLASH_SCAR_DMES
#define FLASH_CRC_ADDR   0x00000000U
#define FLASH_CRC_SECTORS   FLASH_CRCCR_CRC_BY_SECT
#define FLASH_CRC_BANK   (FLASH_CRCCR_ALL_BANK | FLASH_CRCCR_CRC_BY_SECT)
#define FLASH_CRC_BURST_SIZE_4   0x00000000U
#define FLASH_CRC_BURST_SIZE_16   FLASH_CRCCR_CRC_BURST_0
#define FLASH_CRC_BURST_SIZE_64   FLASH_CRCCR_CRC_BURST_1
#define FLASH_CRC_BURST_SIZE_256   FLASH_CRCCR_CRC_BURST
#define FLASH_PROGRAMMING_DELAY_0   0x00000000U
#define FLASH_PROGRAMMING_DELAY_1   FLASH_ACR_WRHIGHFREQ_0
#define FLASH_PROGRAMMING_DELAY_2   FLASH_ACR_WRHIGHFREQ_1
#define FLASH_PROGRAMMING_DELAY_3   FLASH_ACR_WRHIGHFREQ
#define __HAL_FLASH_CALC_BOOT_BASE_ADR(__ADDRESS__)
 Calculate the FLASH Boot Base Address (BOOT_ADD0 or BOOT_ADD1).
#define __HAL_FLASH_SET_PROGRAM_DELAY(__DELAY__)
 Set the FLASH Programming Delay.
#define __HAL_FLASH_GET_PROGRAM_DELAY()
 Get the FLASH Programming Delay.
#define IS_FLASH_TYPEERASE(VALUE)
#define IS_WRPSTATE(VALUE)
#define IS_OPTIONBYTE(VALUE)
#define IS_OB_BOOT_ADDRESS(ADDRESS)
#define IS_OB_RDP_LEVEL(LEVEL)
#define IS_OB_IWDG_SOURCE(SOURCE)
#define IS_OB_STOP_SOURCE(SOURCE)
#define IS_OB_STDBY_SOURCE(SOURCE)
#define IS_OB_IWDG_STOP_FREEZE(FREEZE)
#define IS_OB_IWDG_STDBY_FREEZE(FREEZE)
#define IS_OB_BOR_LEVEL(LEVEL)
#define IS_FLASH_LATENCY(LATENCY)
#define IS_FLASH_SECTOR(SECTOR)
#define IS_OB_WRP_SECTOR(SECTOR)
#define IS_OB_PCROP_RDP(CONFIG)
#define IS_OB_SECURE_RDP(CONFIG)
#define IS_OB_USER_IOHSLV(VALUE)
#define IS_OB_IWDG1_SOURCE(SOURCE)
#define IS_OB_STOP_D1_RESET(VALUE)
#define IS_OB_STDBY_D1_RESET(VALUE)
#define IS_OB_USER_IWDG_STOP(VALUE)
#define IS_OB_USER_IWDG_STDBY(VALUE)
#define IS_OB_USER_ST_RAM_SIZE(VALUE)
#define IS_OB_USER_SECURITY(VALUE)
#define IS_OB_USER_TYPE(TYPE)
#define IS_OB_BOOT_ADD_OPTION(VALUE)
#define IS_FLASH_TYPECRC(VALUE)
HAL_StatusTypeDef HAL_FLASHEx_Erase (FLASH_EraseInitTypeDef *pEraseInit, uint32_t *SectorError)
HAL_StatusTypeDef HAL_FLASHEx_Erase_IT (FLASH_EraseInitTypeDef *pEraseInit)
HAL_StatusTypeDef HAL_FLASHEx_OBProgram (FLASH_OBProgramInitTypeDef *pOBInit)
void HAL_FLASHEx_OBGetConfig (FLASH_OBProgramInitTypeDef *pOBInit)
HAL_StatusTypeDef HAL_FLASHEx_Unlock_Bank1 (void)
HAL_StatusTypeDef HAL_FLASHEx_Lock_Bank1 (void)
HAL_StatusTypeDef HAL_FLASHEx_ComputeCRC (FLASH_CRCInitTypeDef *pCRCInit, uint32_t *CRC_Result)
void FLASH_Erase_Sector (uint32_t Sector, uint32_t Banks, uint32_t VoltageRange)
Author
MCD Application Team
Attention
