RTEMS 6.3
| #define | __HAL_FLASH_CALC_BOOT_BASE_ADR(__ADDRESS__) |
| Calculate the FLASH Boot Base Address (BOOT_ADD0 or BOOT_ADD1). | |
| #define | __HAL_FLASH_SET_PROGRAM_DELAY(__DELAY__) |
| Set the FLASH Programming Delay. | |
| #define | __HAL_FLASH_GET_PROGRAM_DELAY() |
| Get the FLASH Programming Delay. | |
| #define __HAL_FLASH_CALC_BOOT_BASE_ADR | ( | __ADDRESS__ | ) |
| __ADDRESS__ | FLASH Boot Address (in the range 0x0000 0000 to 0x2004 FFFF with a granularity of 16KB) |
| The | FLASH Boot Base Address |
| #define __HAL_FLASH_GET_PROGRAM_DELAY | ( | ) |
| FLASH | Programming Delay This return value can be a value of FLASH Programming Delay |
| #define __HAL_FLASH_SET_PROGRAM_DELAY | ( | __DELAY__ | ) |
| __DELAY__ | FLASH Programming Delay This parameter can be a value of FLASH Programming Delay |
| none |
