RTEMS 6.3
stm32h7xx_hal_exti.h
1
18
19/* Define to prevent recursive inclusion -------------------------------------*/
20#ifndef STM32H7xx_HAL_EXTI_H
21#define STM32H7xx_HAL_EXTI_H
22
23#ifdef __cplusplus
24extern "C" {
25#endif
26
27/* Includes ------------------------------------------------------------------*/
28#include "stm32h7xx_hal_def.h"
29
33
39
40/* Exported types ------------------------------------------------------------*/
41
46typedef enum
47{
48 HAL_EXTI_COMMON_CB_ID = 0x00U,
49} EXTI_CallbackIDTypeDef;
50
51
55typedef struct
56{
57 uint32_t Line;
58 void (* PendingCallback)(void);
60
64typedef struct
65{
66 uint32_t Line;
68 uint32_t Mode;
70 uint32_t Trigger;
72 uint32_t GPIOSel;
75
76 uint32_t PendClearSource;
79
81
85
86/* Exported constants --------------------------------------------------------*/
91
96#define EXTI_LINE_0 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x00U)
97#define EXTI_LINE_1 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x01U)
98#define EXTI_LINE_2 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x02U)
99#define EXTI_LINE_3 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x03U)
100#define EXTI_LINE_4 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x04U)
101#define EXTI_LINE_5 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x05U)
102#define EXTI_LINE_6 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x06U)
103#define EXTI_LINE_7 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x07U)
104#define EXTI_LINE_8 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x08U)
105#define EXTI_LINE_9 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x09U)
106#define EXTI_LINE_10 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0AU)
107#define EXTI_LINE_11 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0BU)
108#define EXTI_LINE_12 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0CU)
109#define EXTI_LINE_13 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0DU)
110#define EXTI_LINE_14 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0EU)
111#define EXTI_LINE_15 (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0FU)
112#define EXTI_LINE_16 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x10U)
113#define EXTI_LINE_17 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x11U)
114#define EXTI_LINE_18 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x12U)
115#define EXTI_LINE_19 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x13U)
116#define EXTI_LINE_20 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x14U)
117#define EXTI_LINE_21 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x15U)
118#define EXTI_LINE_22 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x16U)
119#define EXTI_LINE_23 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x17U)
120#define EXTI_LINE_24 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x18U)
121#define EXTI_LINE_25 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x19U)
122#define EXTI_LINE_26 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1AU)
123#define EXTI_LINE_27 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1BU)
124#define EXTI_LINE_28 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1CU)
125#define EXTI_LINE_29 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1DU)
126#define EXTI_LINE_30 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1EU)
127#define EXTI_LINE_31 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1FU)
128#define EXTI_LINE_32 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x00U)
129#define EXTI_LINE_33 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x01U)
130#define EXTI_LINE_34 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x02U)
131#define EXTI_LINE_35 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x03U)
132#define EXTI_LINE_36 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x04U)
133#define EXTI_LINE_37 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x05U)
134#define EXTI_LINE_38 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x06U)
135#define EXTI_LINE_39 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x07U)
136#define EXTI_LINE_40 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x08U)
137#define EXTI_LINE_41 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x09U)
138#define EXTI_LINE_42 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0AU)
139#define EXTI_LINE_43 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0BU)
140#if !defined(USB2_OTG_FS)
141#define EXTI_LINE_44 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x0CU)
142#else
143#define EXTI_LINE_44 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0CU)
144#endif /* USB2_OTG_FS */
145#define EXTI_LINE_45 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x0DU)
146#if defined(DSI)
147#define EXTI_LINE_46 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0EU)
148#else
149#define EXTI_LINE_46 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x0EU)
150#endif /* DSI */
151#define EXTI_LINE_47 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0FU)
152#define EXTI_LINE_48 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x10U)
153#define EXTI_LINE_49 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x11U)
154#define EXTI_LINE_50 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x12U)
155#define EXTI_LINE_51 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x13U)
156#if defined(LPTIM4)
157#define EXTI_LINE_52 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x14U)
158#else
159#define EXTI_LINE_52 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x14U)
160#endif /*LPTIM4*/
161#if defined(LPTIM5)
162#define EXTI_LINE_53 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x15U)
163#else
164#define EXTI_LINE_53 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x15U)
165#endif /*LPTIM5*/
166#define EXTI_LINE_54 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x16U)
167#define EXTI_LINE_55 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x17U)
168#define EXTI_LINE_56 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x18U)
169#if defined(EXTI_IMR2_IM57)
170#define EXTI_LINE_57 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x19U)
171#else
172#define EXTI_LINE_57 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x19U)
173#endif /*EXTI_IMR2_IM57*/
174#define EXTI_LINE_58 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1AU)
175#if defined(EXTI_IMR2_IM59)
176#define EXTI_LINE_59 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1BU)
177#else
178#define EXTI_LINE_59 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x1BU)
179#endif /*EXTI_IMR2_IM59*/
180#define EXTI_LINE_60 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1CU)
181#define EXTI_LINE_61 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1DU)
182#define EXTI_LINE_62 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1EU)
183#define EXTI_LINE_63 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1FU)
184#define EXTI_LINE_64 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x00U)
185#define EXTI_LINE_65 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x01U)
186#define EXTI_LINE_66 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x02U)
187#define EXTI_LINE_67 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x03U)
188#define EXTI_LINE_68 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x04U)
189#define EXTI_LINE_69 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x05U)
190#define EXTI_LINE_70 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x06U)
191#define EXTI_LINE_71 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x07U)
192#define EXTI_LINE_72 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x08U)
193#define EXTI_LINE_73 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x09U)
194#define EXTI_LINE_74 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x0AU)
195#if defined(ADC3)
196#define EXTI_LINE_75 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x0BU)
197#else
198#define EXTI_LINE_75 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE | 0x0BU)
199#endif /* ADC3 */
200#if defined(SAI4)
201#define EXTI_LINE_76 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x0CU)
202#else
203#define EXTI_LINE_76 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE | 0x0CU)
204#endif /* SAI4 */
205#if defined (DUAL_CORE)
206#define EXTI_LINE_77 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_CPU1| 0x0DU)
207#define EXTI_LINE_78 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_CPU2| 0x0EU)
208#define EXTI_LINE_79 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_CPU1| 0x0FU)
209#define EXTI_LINE_80 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_CPU2| 0x10U)
210#else
211#define EXTI_LINE_77 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x0DU)
212#define EXTI_LINE_78 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x0EU)
213#define EXTI_LINE_79 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x0FU)
214#define EXTI_LINE_80 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x10U)
215#endif /* DUAL_CORE */
216#define EXTI_LINE_81 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x11U)
217#if defined (DUAL_CORE)
218#define EXTI_LINE_82 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_CPU2| 0x12U)
219#else
220#define EXTI_LINE_82 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x12U)
221#endif /* DUAL_CORE */
222#define EXTI_LINE_83 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x13U)
223#if defined (DUAL_CORE)
224#define EXTI_LINE_84 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_CPU1| 0x14U)
225#else
226#define EXTI_LINE_84 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x14U)
227#endif /* DUAL_CORE */
228#define EXTI_LINE_85 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x15U)
229#if defined(ETH)
230#define EXTI_LINE_86 (EXTI_CONFIG | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x16U)
231#else
232#define EXTI_LINE_86 (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x16U)
233#endif /* ETH */
234#define EXTI_LINE_87 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x17U)
235#if defined(DTS)
236#define EXTI_LINE_88 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL | 0x18U)
237#endif /* DTS */
238#if defined(EXTI_IMR3_IM89)
239#define EXTI_LINE_89 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x19U)
240#endif /*EXTI_IMR3_IM89*/
241#if defined(EXTI_IMR3_IM90)
242#define EXTI_LINE_90 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x1AU)
243#endif /*EXTI_IMR3_IM90*/
244#if defined(I2C5)
245#define EXTI_LINE_91 (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x1BU)
246#endif /*I2C5*/
247
251
256#define EXTI_MODE_NONE 0x00000000U
257#define EXTI_MODE_INTERRUPT 0x00000001U
258#define EXTI_MODE_EVENT 0x00000002U
259#if defined(DUAL_CORE)
260#define EXTI_MODE_CORE1_INTERRUPT EXTI_MODE_INTERRUPT
261#define EXTI_MODE_CORE1_EVENT EXTI_MODE_EVENT
262#define EXTI_MODE_CORE2_INTERRUPT 0x00000010U
263#define EXTI_MODE_CORE2_EVENT 0x00000020U
264#endif /* DUAL_CORE */
268
273#define EXTI_TRIGGER_NONE 0x00000000U
274#define EXTI_TRIGGER_RISING 0x00000001U
275#define EXTI_TRIGGER_FALLING 0x00000002U
276#define EXTI_TRIGGER_RISING_FALLING (EXTI_TRIGGER_RISING | EXTI_TRIGGER_FALLING)
280
286#define EXTI_GPIOA 0x00000000U
287#define EXTI_GPIOB 0x00000001U
288#define EXTI_GPIOC 0x00000002U
289#define EXTI_GPIOD 0x00000003U
290#define EXTI_GPIOE 0x00000004U
291#define EXTI_GPIOF 0x00000005U
292#define EXTI_GPIOG 0x00000006U
293#define EXTI_GPIOH 0x00000007U
294#if defined(GPIOI)
295#define EXTI_GPIOI 0x00000008U
296#endif /*GPIOI*/
297#define EXTI_GPIOJ 0x00000009U
298#define EXTI_GPIOK 0x0000000AU
299
303
309#define EXTI_D3_PENDCLR_SRC_NONE 0x00000000U
310#define EXTI_D3_PENDCLR_SRC_DMACH6 0x00000001U
311#define EXTI_D3_PENDCLR_SRC_DMACH7 0x00000002U
312#if defined (LPTIM4)
313#define EXTI_D3_PENDCLR_SRC_LPTIM4 0x00000003U
314#else
315#define EXTI_D3_PENDCLR_SRC_LPTIM2 0x00000003U
316#endif
317#if defined (LPTIM5)
318#define EXTI_D3_PENDCLR_SRC_LPTIM5 0x00000004U
319#else
320#define EXTI_D3_PENDCLR_SRC_LPTIM3 0x00000004U
321#endif
325
329
330/* Exported macro ------------------------------------------------------------*/
335
339
340/* Private constants --------------------------------------------------------*/
348#define EXTI_PROPERTY_SHIFT 24U
349#define EXTI_DIRECT (0x01UL << EXTI_PROPERTY_SHIFT)
350#define EXTI_CONFIG (0x02UL << EXTI_PROPERTY_SHIFT)
351#define EXTI_GPIO ((0x04UL << EXTI_PROPERTY_SHIFT) | EXTI_CONFIG)
352#define EXTI_RESERVED (0x08UL << EXTI_PROPERTY_SHIFT)
353#define EXTI_PROPERTY_MASK (EXTI_DIRECT | EXTI_CONFIG | EXTI_GPIO)
354
358#define EXTI_EVENT_PRESENCE_SHIFT 28U
359#define EXTI_EVENT (0x01UL << EXTI_EVENT_PRESENCE_SHIFT)
360#define EXTI_EVENT_PRESENCE_MASK (EXTI_EVENT)
361
365#define EXTI_REG_SHIFT 16U
366#define EXTI_REG1 (0x00UL << EXTI_REG_SHIFT)
367#define EXTI_REG2 (0x01UL << EXTI_REG_SHIFT)
368#define EXTI_REG3 (0x02UL << EXTI_REG_SHIFT)
369#define EXTI_REG_MASK (EXTI_REG1 | EXTI_REG2 | EXTI_REG3)
370#define EXTI_PIN_MASK 0x0000001FUL
371
375#define EXTI_TARGET_SHIFT 20U
376#define EXTI_TARGET_MSK_NONE (0x00UL << EXTI_TARGET_SHIFT)
377#define EXTI_TARGET_MSK_D3SRD (0x01UL << EXTI_TARGET_SHIFT)
378#define EXTI_TARGET_MSK_CPU1 (0x02UL << EXTI_TARGET_SHIFT)
379#if defined (DUAL_CORE)
380#define EXTI_TARGET_MSK_CPU2 (0x04UL << EXTI_TARGET_SHIFT)
381#define EXTI_TARGET_MASK (EXTI_TARGET_MSK_D3SRD | EXTI_TARGET_MSK_CPU1 | EXTI_TARGET_MSK_CPU2)
382#define EXTI_TARGET_MSK_ALL_CPU (EXTI_TARGET_MSK_CPU1 | EXTI_TARGET_MSK_CPU2)
383#else
384#define EXTI_TARGET_MASK (EXTI_TARGET_MSK_D3SRD | EXTI_TARGET_MSK_CPU1)
385#define EXTI_TARGET_MSK_ALL_CPU EXTI_TARGET_MSK_CPU1
386#endif /* DUAL_CORE */
387#define EXTI_TARGET_MSK_ALL EXTI_TARGET_MASK
388
392#if defined (DUAL_CORE)
393#define EXTI_MODE_MASK (EXTI_MODE_CORE1_EVENT | EXTI_MODE_CORE1_INTERRUPT | EXTI_MODE_CORE2_INTERRUPT | EXTI_MODE_CORE2_EVENT)
394#else
395#define EXTI_MODE_MASK (EXTI_MODE_EVENT | EXTI_MODE_INTERRUPT)
396#endif /* DUAL_CORE */
397
401#define EXTI_TRIGGER_MASK (EXTI_TRIGGER_RISING | EXTI_TRIGGER_FALLING)
402
406#if (STM32H7_DEV_ID == 0x483UL)
407#define EXTI_LINE_NB 92UL
408#elif (STM32H7_DEV_ID == 0x480UL)
409#define EXTI_LINE_NB 89UL
410#else
411#define EXTI_LINE_NB 88UL
412#endif /* EXTI_LINE_91 */
413
417
418/* Private macros ------------------------------------------------------------*/
423#define IS_EXTI_PROPERTY(__EXTI_LINE__) ((((__EXTI_LINE__) & EXTI_PROPERTY_MASK) == EXTI_DIRECT) || \
424 (((__EXTI_LINE__) & EXTI_PROPERTY_MASK) == EXTI_CONFIG) || \
425 (((__EXTI_LINE__) & EXTI_PROPERTY_MASK) == EXTI_GPIO))
426#if defined (DUAL_CORE)
427#define IS_EXTI_TARGET(__EXTI_LINE__) ((((__EXTI_LINE__) & EXTI_TARGET_MASK) == EXTI_TARGET_MSK_CPU1) || \
428 (((__EXTI_LINE__) & EXTI_TARGET_MASK) == EXTI_TARGET_MSK_CPU2) || \
429 (((__EXTI_LINE__) & EXTI_TARGET_MASK) == EXTI_TARGET_MSK_ALL_CPU) || \
430 (((__EXTI_LINE__) & EXTI_TARGET_MASK) == EXTI_TARGET_MSK_ALL))
431#else
432#define IS_EXTI_TARGET(__EXTI_LINE__) ((((__EXTI_LINE__) & EXTI_TARGET_MASK) == EXTI_TARGET_MSK_CPU1) || \
433 (((__EXTI_LINE__) & EXTI_TARGET_MASK) == EXTI_TARGET_MSK_ALL))
434#endif
435
436#define IS_EXTI_LINE(__EXTI_LINE__) ((((__EXTI_LINE__) & ~(EXTI_PROPERTY_MASK | EXTI_EVENT_PRESENCE_MASK |\
437 EXTI_REG_MASK | EXTI_PIN_MASK | EXTI_TARGET_MASK)) == 0x00UL) && \
438 IS_EXTI_PROPERTY(__EXTI_LINE__) && IS_EXTI_TARGET(__EXTI_LINE__) && \
439 (((__EXTI_LINE__) & (EXTI_REG_MASK | EXTI_PIN_MASK)) < \
440 (((EXTI_LINE_NB / 32UL) << EXTI_REG_SHIFT) | (EXTI_LINE_NB % 32UL))))
441
442#define IS_EXTI_MODE(__MODE__) (((__MODE__) & ~EXTI_MODE_MASK) == 0x00UL)
443
444#define IS_EXTI_TRIGGER(__EXTI_LINE__) (((__EXTI_LINE__) & ~EXTI_TRIGGER_MASK) == 0x00UL)
445
446#define IS_EXTI_PENDING_EDGE(__EXTI_LINE__) (((__EXTI_LINE__) == EXTI_TRIGGER_RISING) || \
447 ((__EXTI_LINE__) == EXTI_TRIGGER_FALLING)|| \
448 ((__EXTI_LINE__) == EXTI_TRIGGER_RISING_FALLING))
449
450#define IS_EXTI_CONFIG_LINE(__EXTI_LINE__) (((__EXTI_LINE__) & EXTI_CONFIG) != 0x00UL)
451
452#if defined(GPIOI)
453#define IS_EXTI_GPIO_PORT(__PORT__) (((__PORT__) == EXTI_GPIOA) || \
454 ((__PORT__) == EXTI_GPIOB) || \
455 ((__PORT__) == EXTI_GPIOC) || \
456 ((__PORT__) == EXTI_GPIOD) || \
457 ((__PORT__) == EXTI_GPIOE) || \
458 ((__PORT__) == EXTI_GPIOF) || \
459 ((__PORT__) == EXTI_GPIOG) || \
460 ((__PORT__) == EXTI_GPIOH) || \
461 ((__PORT__) == EXTI_GPIOI) || \
462 ((__PORT__) == EXTI_GPIOJ) || \
463 ((__PORT__) == EXTI_GPIOK))
464#else
465#define IS_EXTI_GPIO_PORT(__PORT__) (((__PORT__) == EXTI_GPIOA) || \
466 ((__PORT__) == EXTI_GPIOB) || \
467 ((__PORT__) == EXTI_GPIOC) || \
468 ((__PORT__) == EXTI_GPIOD) || \
469 ((__PORT__) == EXTI_GPIOE) || \
470 ((__PORT__) == EXTI_GPIOF) || \
471 ((__PORT__) == EXTI_GPIOG) || \
472 ((__PORT__) == EXTI_GPIOH) || \
473 ((__PORT__) == EXTI_GPIOJ) || \
474 ((__PORT__) == EXTI_GPIOK))
475#endif /*GPIOI*/
476
477#define IS_EXTI_GPIO_PIN(__PIN__) ((__PIN__) < 16UL)
478#if defined (LPTIM4) && defined (LPTIM5)
479#define IS_EXTI_D3_PENDCLR_SRC(__SRC__) (((__SRC__) == EXTI_D3_PENDCLR_SRC_NONE) || \
480 ((__SRC__) == EXTI_D3_PENDCLR_SRC_DMACH6) || \
481 ((__SRC__) == EXTI_D3_PENDCLR_SRC_DMACH7) || \
482 ((__SRC__) == EXTI_D3_PENDCLR_SRC_LPTIM4) || \
483 ((__SRC__) == EXTI_D3_PENDCLR_SRC_LPTIM5))
484#else
485#define IS_EXTI_D3_PENDCLR_SRC(__SRC__) (((__SRC__) == EXTI_D3_PENDCLR_SRC_NONE) || \
486 ((__SRC__) == EXTI_D3_PENDCLR_SRC_DMACH6) || \
487 ((__SRC__) == EXTI_D3_PENDCLR_SRC_DMACH7) || \
488 ((__SRC__) == EXTI_D3_PENDCLR_SRC_LPTIM2) || \
489 ((__SRC__) == EXTI_D3_PENDCLR_SRC_LPTIM3))
490#endif /* LPTIM4 && LPTIM5 */
491
495
496
497/* Exported functions --------------------------------------------------------*/
503
509/* Configuration functions ****************************************************/
510HAL_StatusTypeDef HAL_EXTI_SetConfigLine(EXTI_HandleTypeDef *hexti, EXTI_ConfigTypeDef *pExtiConfig);
511HAL_StatusTypeDef HAL_EXTI_GetConfigLine(EXTI_HandleTypeDef *hexti, EXTI_ConfigTypeDef *pExtiConfig);
512HAL_StatusTypeDef HAL_EXTI_ClearConfigLine(EXTI_HandleTypeDef *hexti);
513HAL_StatusTypeDef HAL_EXTI_RegisterCallback(EXTI_HandleTypeDef *hexti, EXTI_CallbackIDTypeDef CallbackID, void (*pPendingCbfn)(void));
514HAL_StatusTypeDef HAL_EXTI_GetHandle(EXTI_HandleTypeDef *hexti, uint32_t ExtiLine);
518
524/* IO operation functions *****************************************************/
525void HAL_EXTI_IRQHandler(EXTI_HandleTypeDef *hexti);
526uint32_t HAL_EXTI_GetPending(EXTI_HandleTypeDef *hexti, uint32_t Edge);
527void HAL_EXTI_ClearPending(EXTI_HandleTypeDef *hexti, uint32_t Edge);
528void HAL_EXTI_GenerateSWI(EXTI_HandleTypeDef *hexti);
529
533
537
541
545
546#ifdef __cplusplus
547}
548#endif
549
550#endif /* STM32H7xx_HAL_EXTI_H */
551
This file contains HAL common defines, enumeration, macros and structures definitions.
HAL_StatusTypeDef
HAL Status structures definition.
Definition stm32h7xx_hal_def.h:47
EXTI Configuration structure definition.
Definition stm32h7xx_hal_exti.h:65
uint32_t Line
Definition stm32h7xx_hal_exti.h:66
uint32_t Mode
Definition stm32h7xx_hal_exti.h:68
Definition stm32h7xx_hal_exti.h:76
uint32_t GPIOSel
Definition stm32h7xx_hal_exti.h:72
uint32_t Trigger
Definition stm32h7xx_hal_exti.h:70
EXTI Handle structure definition.
Definition stm32h7xx_hal_exti.h:56
uint32_t Line
Definition stm32h7xx_hal_exti.h:57
void(*) PendingCallback(void)
Definition stm32h7xx_hal_exti.h:58
