RTEMS 6.3
stm32h7xx_hal_exti.h File Reference
Header file of EXTI HAL module. More...
struct  EXTI_HandleTypeDef
 EXTI Handle structure definition. More...
struct  EXTI_ConfigTypeDef
 EXTI Configuration structure definition. More...
#define EXTI_LINE_0   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x00U)
#define EXTI_LINE_1   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x01U)
#define EXTI_LINE_2   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x02U)
#define EXTI_LINE_3   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x03U)
#define EXTI_LINE_4   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x04U)
#define EXTI_LINE_5   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x05U)
#define EXTI_LINE_6   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x06U)
#define EXTI_LINE_7   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x07U)
#define EXTI_LINE_8   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x08U)
#define EXTI_LINE_9   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x09U)
#define EXTI_LINE_10   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0AU)
#define EXTI_LINE_11   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0BU)
#define EXTI_LINE_12   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0CU)
#define EXTI_LINE_13   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0DU)
#define EXTI_LINE_14   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0EU)
#define EXTI_LINE_15   (EXTI_GPIO | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x0FU)
#define EXTI_LINE_16   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x10U)
#define EXTI_LINE_17   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x11U)
#define EXTI_LINE_18   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x12U)
#define EXTI_LINE_19   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x13U)
#define EXTI_LINE_20   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x14U)
#define EXTI_LINE_21   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x15U)
#define EXTI_LINE_22   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x16U)
#define EXTI_LINE_23   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x17U)
#define EXTI_LINE_24   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x18U)
#define EXTI_LINE_25   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL | 0x19U)
#define EXTI_LINE_26   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1AU)
#define EXTI_LINE_27   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1BU)
#define EXTI_LINE_28   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1CU)
#define EXTI_LINE_29   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1DU)
#define EXTI_LINE_30   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1EU)
#define EXTI_LINE_31   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG1 | EXTI_TARGET_MSK_ALL_CPU | 0x1FU)
#define EXTI_LINE_32   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x00U)
#define EXTI_LINE_33   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x01U)
#define EXTI_LINE_34   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x02U)
#define EXTI_LINE_35   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x03U)
#define EXTI_LINE_36   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x04U)
#define EXTI_LINE_37   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x05U)
#define EXTI_LINE_38   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x06U)
#define EXTI_LINE_39   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x07U)
#define EXTI_LINE_40   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x08U)
#define EXTI_LINE_41   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x09U)
#define EXTI_LINE_42   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0AU)
#define EXTI_LINE_43   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0BU)
#define EXTI_LINE_44   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x0CU)
#define EXTI_LINE_45   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x0DU)
#define EXTI_LINE_46   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x0EU)
#define EXTI_LINE_47   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x0FU)
#define EXTI_LINE_48   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x10U)
#define EXTI_LINE_49   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x11U)
#define EXTI_LINE_50   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x12U)
#define EXTI_LINE_51   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL | 0x13U)
#define EXTI_LINE_52   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x14U)
#define EXTI_LINE_53   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x15U)
#define EXTI_LINE_54   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x16U)
#define EXTI_LINE_55   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x17U)
#define EXTI_LINE_56   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x18U)
#define EXTI_LINE_57   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x19U)
#define EXTI_LINE_58   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1AU)
#define EXTI_LINE_59   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_NONE | 0x1BU)
#define EXTI_LINE_60   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1CU)
#define EXTI_LINE_61   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1DU)
#define EXTI_LINE_62   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1EU)
#define EXTI_LINE_63   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG2 | EXTI_TARGET_MSK_ALL_CPU | 0x1FU)
#define EXTI_LINE_64   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x00U)
#define EXTI_LINE_65   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x01U)
#define EXTI_LINE_66   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x02U)
#define EXTI_LINE_67   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x03U)
#define EXTI_LINE_68   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x04U)
#define EXTI_LINE_69   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x05U)
#define EXTI_LINE_70   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x06U)
#define EXTI_LINE_71   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x07U)
#define EXTI_LINE_72   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x08U)
#define EXTI_LINE_73   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x09U)
#define EXTI_LINE_74   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x0AU)
#define EXTI_LINE_75   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE | 0x0BU)
#define EXTI_LINE_76   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE | 0x0CU)
#define EXTI_LINE_77   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x0DU)
#define EXTI_LINE_78   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x0EU)
#define EXTI_LINE_79   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x0FU)
#define EXTI_LINE_80   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x10U)
#define EXTI_LINE_81   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x11U)
#define EXTI_LINE_82   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x12U)
#define EXTI_LINE_83   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x13U)
#define EXTI_LINE_84   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x14U)
#define EXTI_LINE_85   (EXTI_CONFIG | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x15U)
#define EXTI_LINE_86   (EXTI_RESERVED | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_NONE| 0x16U)
#define EXTI_LINE_87   (EXTI_DIRECT | EXTI_EVENT | EXTI_REG3 | EXTI_TARGET_MSK_ALL_CPU | 0x17U)
#define EXTI_MODE_NONE   0x00000000U
#define EXTI_MODE_INTERRUPT   0x00000001U
#define EXTI_MODE_EVENT   0x00000002U
#define EXTI_TRIGGER_NONE   0x00000000U
#define EXTI_TRIGGER_RISING   0x00000001U
#define EXTI_TRIGGER_FALLING   0x00000002U
#define EXTI_TRIGGER_RISING_FALLING   (EXTI_TRIGGER_RISING | EXTI_TRIGGER_FALLING)
#define EXTI_GPIOA   0x00000000U
#define EXTI_GPIOB   0x00000001U
#define EXTI_GPIOC   0x00000002U
#define EXTI_GPIOD   0x00000003U
#define EXTI_GPIOE   0x00000004U
#define EXTI_GPIOF   0x00000005U
#define EXTI_GPIOG   0x00000006U
#define EXTI_GPIOH   0x00000007U
#define EXTI_GPIOJ   0x00000009U
#define EXTI_GPIOK   0x0000000AU
#define EXTI_D3_PENDCLR_SRC_NONE   0x00000000U
#define EXTI_D3_PENDCLR_SRC_DMACH6   0x00000001U
#define EXTI_D3_PENDCLR_SRC_DMACH7   0x00000002U
#define EXTI_D3_PENDCLR_SRC_LPTIM2   0x00000003U
#define EXTI_D3_PENDCLR_SRC_LPTIM3   0x00000004U
#define EXTI_PROPERTY_SHIFT   24U
 EXTI Line property definition.
#define EXTI_DIRECT   (0x01UL << EXTI_PROPERTY_SHIFT)
#define EXTI_CONFIG   (0x02UL << EXTI_PROPERTY_SHIFT)
#define EXTI_GPIO   ((0x04UL << EXTI_PROPERTY_SHIFT) | EXTI_CONFIG)
#define EXTI_RESERVED   (0x08UL << EXTI_PROPERTY_SHIFT)
#define EXTI_PROPERTY_MASK   (EXTI_DIRECT | EXTI_CONFIG | EXTI_GPIO)
#define EXTI_EVENT_PRESENCE_SHIFT   28U
 EXTI Event presence definition.
#define EXTI_EVENT   (0x01UL << EXTI_EVENT_PRESENCE_SHIFT)
#define EXTI_EVENT_PRESENCE_MASK   (EXTI_EVENT)
#define EXTI_REG_SHIFT   16U
 EXTI Register and bit usage.
#define EXTI_REG1   (0x00UL << EXTI_REG_SHIFT)
#define EXTI_REG2   (0x01UL << EXTI_REG_SHIFT)
#define EXTI_REG3   (0x02UL << EXTI_REG_SHIFT)
#define EXTI_REG_MASK   (EXTI_REG1 | EXTI_REG2 | EXTI_REG3)
#define EXTI_PIN_MASK   0x0000001FUL
#define EXTI_TARGET_SHIFT   20U
 EXTI Target and bit usage.
#define EXTI_TARGET_MSK_NONE   (0x00UL << EXTI_TARGET_SHIFT)
#define EXTI_TARGET_MSK_D3SRD   (0x01UL << EXTI_TARGET_SHIFT)
#define EXTI_TARGET_MSK_CPU1   (0x02UL << EXTI_TARGET_SHIFT)
#define EXTI_TARGET_MASK   (EXTI_TARGET_MSK_D3SRD | EXTI_TARGET_MSK_CPU1)
#define EXTI_TARGET_MSK_ALL_CPU   EXTI_TARGET_MSK_CPU1
#define EXTI_TARGET_MSK_ALL   EXTI_TARGET_MASK
#define EXTI_MODE_MASK   (EXTI_MODE_EVENT | EXTI_MODE_INTERRUPT)
 EXTI Mask for interrupt & event mode.
#define EXTI_TRIGGER_MASK   (EXTI_TRIGGER_RISING | EXTI_TRIGGER_FALLING)
 EXTI Mask for trigger possibilities.
#define EXTI_LINE_NB   88UL
 EXTI Line number.
#define IS_EXTI_PROPERTY(__EXTI_LINE__)
#define IS_EXTI_TARGET(__EXTI_LINE__)
#define IS_EXTI_LINE(__EXTI_LINE__)
#define IS_EXTI_MODE(__MODE__)
#define IS_EXTI_TRIGGER(__EXTI_LINE__)
#define IS_EXTI_PENDING_EDGE(__EXTI_LINE__)
#define IS_EXTI_CONFIG_LINE(__EXTI_LINE__)
#define IS_EXTI_GPIO_PORT(__PORT__)
#define IS_EXTI_GPIO_PIN(__PIN__)
#define IS_EXTI_D3_PENDCLR_SRC(__SRC__)
enum  EXTI_CallbackIDTypeDef { HAL_EXTI_COMMON_CB_ID = 0x00U }
HAL_StatusTypeDef HAL_EXTI_SetConfigLine (EXTI_HandleTypeDef *hexti, EXTI_ConfigTypeDef *pExtiConfig)
HAL_StatusTypeDef HAL_EXTI_GetConfigLine (EXTI_HandleTypeDef *hexti, EXTI_ConfigTypeDef *pExtiConfig)
HAL_StatusTypeDef HAL_EXTI_ClearConfigLine (EXTI_HandleTypeDef *hexti)
HAL_StatusTypeDef HAL_EXTI_RegisterCallback (EXTI_HandleTypeDef *hexti, EXTI_CallbackIDTypeDef CallbackID, void(*pPendingCbfn)(void))
HAL_StatusTypeDef HAL_EXTI_GetHandle (EXTI_HandleTypeDef *hexti, uint32_t ExtiLine)
void HAL_EXTI_IRQHandler (EXTI_HandleTypeDef *hexti)
uint32_t HAL_EXTI_GetPending (EXTI_HandleTypeDef *hexti, uint32_t Edge)
void HAL_EXTI_ClearPending (EXTI_HandleTypeDef *hexti, uint32_t Edge)
void HAL_EXTI_GenerateSWI (EXTI_HandleTypeDef *hexti)
Author
MCD Application Team
Attention
