RTEMS 6.3
stm32h7xx_hal.h File Reference
This file contains all the functions prototypes for the HAL module driver. More...
#include "stm32h7xx_hal_conf.h"
#define REV_ID_Y   ((uint32_t)0x1003)
#define REV_ID_B   ((uint32_t)0x2000)
#define REV_ID_X   ((uint32_t)0x2001)
#define REV_ID_V   ((uint32_t)0x2003)
#define SYSCFG_VREFBUF_VOLTAGE_SCALE0   VREFBUF_CSR_VRS_OUT1
#define SYSCFG_VREFBUF_VOLTAGE_SCALE1   VREFBUF_CSR_VRS_OUT2
#define SYSCFG_VREFBUF_VOLTAGE_SCALE2   VREFBUF_CSR_VRS_OUT3
#define SYSCFG_VREFBUF_VOLTAGE_SCALE3   VREFBUF_CSR_VRS_OUT4
#define IS_SYSCFG_VREFBUF_VOLTAGE_SCALE(__SCALE__)
#define SYSCFG_VREFBUF_HIGH_IMPEDANCE_DISABLE   ((uint32_t)0x00000000)
#define SYSCFG_VREFBUF_HIGH_IMPEDANCE_ENABLE   VREFBUF_CSR_HIZ
#define IS_SYSCFG_VREFBUF_HIGH_IMPEDANCE(__VALUE__)
#define IS_SYSCFG_VREFBUF_TRIMMING(__VALUE__)
#define SYSCFG_FASTMODEPLUS_PB6   SYSCFG_PMCR_I2C_PB6_FMP
 Fast-mode Plus driving capability on a specific GPIO.
#define SYSCFG_FASTMODEPLUS_PB7   SYSCFG_PMCR_I2C_PB7_FMP
#define SYSCFG_FASTMODEPLUS_PB8   SYSCFG_PMCR_I2C_PB8_FMP
#define SYSCFG_FASTMODEPLUS_PB9   SYSCFG_PMCR_I2C_PB9_FMP
#define IS_SYSCFG_FASTMODEPLUS(__PIN__)
#define SYSCFG_ETH_MII   ((uint32_t)0x00000000)
#define SYSCFG_ETH_RMII   SYSCFG_PMCR_EPIS_SEL_2
#define IS_SYSCFG_ETHERNET_CONFIG(CONFIG)
#define SYSCFG_SWITCH_PA0   SYSCFG_PMCR_PA0SO
#define SYSCFG_SWITCH_PA1   SYSCFG_PMCR_PA1SO
#define SYSCFG_SWITCH_PC2   SYSCFG_PMCR_PC2SO
#define SYSCFG_SWITCH_PC3   SYSCFG_PMCR_PC3SO
#define SYSCFG_SWITCH_PA0_OPEN   SYSCFG_PMCR_PA0SO
#define SYSCFG_SWITCH_PA0_CLOSE   ((uint32_t)0x00000000)
#define SYSCFG_SWITCH_PA1_OPEN   SYSCFG_PMCR_PA1SO
#define SYSCFG_SWITCH_PA1_CLOSE   ((uint32_t)0x00000000)
#define SYSCFG_SWITCH_PC2_OPEN   SYSCFG_PMCR_PC2SO
#define SYSCFG_SWITCH_PC2_CLOSE   ((uint32_t)0x00000000)
#define SYSCFG_SWITCH_PC3_OPEN   SYSCFG_PMCR_PC3SO
#define SYSCFG_SWITCH_PC3_CLOSE   ((uint32_t)0x00000000)
#define IS_SYSCFG_ANALOG_SWITCH(SWITCH)
#define IS_SYSCFG_SWITCH_STATE(STATE)
#define SYSCFG_BOOT_ADDR0   ((uint32_t)0x00000000)
#define SYSCFG_BOOT_ADDR1   ((uint32_t)0x00000001)
#define IS_SYSCFG_BOOT_REGISTER(REGISTER)
#define IS_SYSCFG_BOOT_ADDRESS(ADDRESS)
#define SYSCFG_CELL_CODE   ((uint32_t)0x00000000)
#define SYSCFG_REGISTER_CODE   SYSCFG_CCCSR_CS
#define IS_SYSCFG_CODE_SELECT(SELECT)
#define IS_SYSCFG_CODE_CONFIG(CONFIG)
#define EXTI_MODE_IT   ((uint32_t)0x00010000)
#define EXTI_MODE_EVT   ((uint32_t)0x00020000)
#define EXTI_RISING_EDGE   ((uint32_t)0x00100000)
#define EXTI_FALLING_EDGE   ((uint32_t)0x00200000)
#define IS_EXTI_EDGE_LINE(EDGE)
#define IS_EXTI_MODE_LINE(MODE)
#define EXTI_LINE0   ((uint32_t)0x00)
#define EXTI_LINE1   ((uint32_t)0x01)
#define EXTI_LINE2   ((uint32_t)0x02)
#define EXTI_LINE3   ((uint32_t)0x03)
#define EXTI_LINE4   ((uint32_t)0x04)
#define EXTI_LINE5   ((uint32_t)0x05)
#define EXTI_LINE6   ((uint32_t)0x06)
#define EXTI_LINE7   ((uint32_t)0x07)
#define EXTI_LINE8   ((uint32_t)0x08)
#define EXTI_LINE9   ((uint32_t)0x09)
#define EXTI_LINE10   ((uint32_t)0x0A)
#define EXTI_LINE11   ((uint32_t)0x0B)
#define EXTI_LINE12   ((uint32_t)0x0C)
#define EXTI_LINE13   ((uint32_t)0x0D)
#define EXTI_LINE14   ((uint32_t)0x0E)
#define EXTI_LINE15   ((uint32_t)0x0F)
#define EXTI_LINE16   ((uint32_t)0x10)
#define EXTI_LINE17   ((uint32_t)0x11)
#define EXTI_LINE18   ((uint32_t)0x12)
#define EXTI_LINE19   ((uint32_t)0x13)
#define EXTI_LINE20   ((uint32_t)0x14)
#define EXTI_LINE21   ((uint32_t)0x15)
#define EXTI_LINE22   ((uint32_t)0x16)
#define EXTI_LINE23   ((uint32_t)0x17)
#define EXTI_LINE24   ((uint32_t)0x18)
#define EXTI_LINE25   ((uint32_t)0x19)
#define EXTI_LINE26   ((uint32_t)0x1A)
#define EXTI_LINE27   ((uint32_t)0x1B)
#define EXTI_LINE28   ((uint32_t)0x1C)
#define EXTI_LINE29   ((uint32_t)0x1D)
#define EXTI_LINE30   ((uint32_t)0x1E)
#define EXTI_LINE31   ((uint32_t)0x1F)
#define EXTI_LINE32   ((uint32_t)0x20)
#define EXTI_LINE33   ((uint32_t)0x21)
#define EXTI_LINE34   ((uint32_t)0x22)
#define EXTI_LINE35   ((uint32_t)0x23)
#define EXTI_LINE36   ((uint32_t)0x24)
#define EXTI_LINE37   ((uint32_t)0x25)
#define EXTI_LINE38   ((uint32_t)0x26)
#define EXTI_LINE39   ((uint32_t)0x27)
#define EXTI_LINE40   ((uint32_t)0x28)
#define EXTI_LINE41   ((uint32_t)0x29)
#define EXTI_LINE42   ((uint32_t)0x2A)
#define EXTI_LINE43   ((uint32_t)0x2B)
#define EXTI_LINE44   ((uint32_t)0x2C)
#define EXTI_LINE47   ((uint32_t)0x2F)
#define EXTI_LINE48   ((uint32_t)0x30)
#define EXTI_LINE49   ((uint32_t)0x31)
#define EXTI_LINE50   ((uint32_t)0x32)
#define EXTI_LINE51   ((uint32_t)0x33)
#define EXTI_LINE52   ((uint32_t)0x34)
#define EXTI_LINE53   ((uint32_t)0x35)
#define EXTI_LINE54   ((uint32_t)0x36)
#define EXTI_LINE55   ((uint32_t)0x37)
#define EXTI_LINE56   ((uint32_t)0x38)
#define EXTI_LINE57   ((uint32_t)0x39)
#define EXTI_LINE58   ((uint32_t)0x3A)
#define EXTI_LINE59   ((uint32_t)0x3B)
#define EXTI_LINE60   ((uint32_t)0x3C)
#define EXTI_LINE61   ((uint32_t)0x3D)
#define EXTI_LINE62   ((uint32_t)0x3E)
#define EXTI_LINE63   ((uint32_t)0x3F)
#define EXTI_LINE64   ((uint32_t)0x40)
#define EXTI_LINE65   ((uint32_t)0x41)
#define EXTI_LINE66   ((uint32_t)0x42)
#define EXTI_LINE67   ((uint32_t)0x43)
#define EXTI_LINE68   ((uint32_t)0x44)
#define EXTI_LINE69   ((uint32_t)0x45)
#define EXTI_LINE70   ((uint32_t)0x46)
#define EXTI_LINE71   ((uint32_t)0x47)
#define EXTI_LINE72   ((uint32_t)0x48)
#define EXTI_LINE73   ((uint32_t)0x49)
#define EXTI_LINE74   ((uint32_t)0x4A)
#define EXTI_LINE75   ((uint32_t)0x4B)
#define EXTI_LINE76   ((uint32_t)0x4C)
#define EXTI_LINE85   ((uint32_t)0x55)
#define EXTI_LINE86   ((uint32_t)0x56)
#define EXTI_LINE87   ((uint32_t)0x57)
#define EXTI_LINE88   ((uint32_t)0x58)
#define EXTI_LINE89   ((uint32_t)0x59)
#define EXTI_LINE90   ((uint32_t)0x5A)
#define EXTI_LINE91   ((uint32_t)0x5B)
#define IS_HAL_EXTI_CONFIG_LINE(LINE)
#define IS_EXTI_ALL_LINE(LINE)
#define IS_EXTI_D1_LINE(LINE)
#define IS_EXTI_D3_LINE(LINE)
#define BDMA_CH6_CLEAR   ((uint32_t)0x00000000)
#define BDMA_CH7_CLEAR   ((uint32_t)0x00000001)
#define LPTIM2_OUT_CLEAR   ((uint32_t)0x00000002)
#define LPTIM3_OUT_CLEAR   ((uint32_t)0x00000003)
#define IS_EXTI_D3_CLEAR(SOURCE)
#define FMC_SWAPBMAP_DISABLE   (0x00000000U)
#define FMC_SWAPBMAP_SDRAM_SRAM   FMC_BCR1_BMAP_0
#define FMC_SWAPBMAP_SDRAMB2   FMC_BCR1_BMAP_1
#define IS_FMC_SWAPBMAP_MODE(__MODE__)
#define __HAL_SYSCFG_BREAK_AXISRAM_DBL_ECC_LOCK()
 SYSCFG Break AXIRAM double ECC lock. Enable and lock the connection of AXIRAM double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_ITCM_DBL_ECC_LOCK()
 SYSCFG Break ITCM double ECC lock. Enable and lock the connection of ITCM double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_DTCM_DBL_ECC_LOCK()
 SYSCFG Break DTCM double ECC lock. Enable and lock the connection of DTCM double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_SRAM1_DBL_ECC_LOCK()
 SYSCFG Break SRAM1 double ECC lock. Enable and lock the connection of SRAM1 double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_SRAM2_DBL_ECC_LOCK()
 SYSCFG Break SRAM2 double ECC lock. Enable and lock the connection of SRAM2 double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_SRAM3_DBL_ECC_LOCK()
 SYSCFG Break SRAM3 double ECC lock. Enable and lock the connection of SRAM3 double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_SRAM4_DBL_ECC_LOCK()
 SYSCFG Break SRAM4 double ECC lock. Enable and lock the connection of SRAM4 double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_BKRAM_DBL_ECC_LOCK()
 SYSCFG Break Backup SRAM double ECC lock. Enable and lock the connection of Backup SRAM double ECC error to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_CM7_LOCKUP_LOCK()
 SYSCFG Break Cortex-M7 Lockup lock. Enable and lock the connection of Cortex-M7 LOCKUP output to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_FLASH_DBL_ECC_LOCK()
 SYSCFG Break FLASH double ECC lock. Enable and lock the connection of Flash double ECC error connection to TIM1/8/15/16/17 and HRTIMER Break input.
#define __HAL_SYSCFG_BREAK_PVD_LOCK()
 SYSCFG Break PVD lock. Enable and lock the PVD connection to Timer1/8/15/16/17 and HRTIMER Break input, as well as the PVDE and PLS[2:0] in the PWR_CR1 register.
#define __HAL_SYSCFG_FASTMODEPLUS_ENABLE(__FASTMODEPLUS__)
 Fast-mode Plus driving capability enable/disable macros.
#define __HAL_SYSCFG_FASTMODEPLUS_DISABLE(__FASTMODEPLUS__)
#define __HAL_DBGMCU_FREEZE_WWDG1()
 Freeze/Unfreeze Peripherals in Debug mode.
#define __HAL_DBGMCU_FREEZE_TIM2()
#define __HAL_DBGMCU_FREEZE_TIM3()
#define __HAL_DBGMCU_FREEZE_TIM4()
#define __HAL_DBGMCU_FREEZE_TIM5()
#define __HAL_DBGMCU_FREEZE_TIM6()
#define __HAL_DBGMCU_FREEZE_TIM7()
#define __HAL_DBGMCU_FREEZE_TIM12()
#define __HAL_DBGMCU_FREEZE_TIM13()
#define __HAL_DBGMCU_FREEZE_TIM14()
#define __HAL_DBGMCU_FREEZE_LPTIM1()
#define __HAL_DBGMCU_FREEZE_I2C1()
#define __HAL_DBGMCU_FREEZE_I2C2()
#define __HAL_DBGMCU_FREEZE_I2C3()
#define __HAL_DBGMCU_FREEZE_TIM1()
#define __HAL_DBGMCU_FREEZE_TIM8()
#define __HAL_DBGMCU_FREEZE_TIM15()
#define __HAL_DBGMCU_FREEZE_TIM16()
#define __HAL_DBGMCU_FREEZE_TIM17()
#define __HAL_DBGMCU_FREEZE_HRTIM()
#define __HAL_DBGMCU_FREEZE_I2C4()
#define __HAL_DBGMCU_FREEZE_LPTIM2()
#define __HAL_DBGMCU_FREEZE_LPTIM3()
#define __HAL_DBGMCU_FREEZE_LPTIM4()
#define __HAL_DBGMCU_FREEZE_LPTIM5()
#define __HAL_DBGMCU_FREEZE_RTC()
#define __HAL_DBGMCU_FREEZE_IWDG1()
#define __HAL_DBGMCU_UnFreeze_WWDG1()
#define __HAL_DBGMCU_UnFreeze_TIM2()
#define __HAL_DBGMCU_UnFreeze_TIM3()
#define __HAL_DBGMCU_UnFreeze_TIM4()
#define __HAL_DBGMCU_UnFreeze_TIM5()
#define __HAL_DBGMCU_UnFreeze_TIM6()
#define __HAL_DBGMCU_UnFreeze_TIM7()
#define __HAL_DBGMCU_UnFreeze_TIM12()
#define __HAL_DBGMCU_UnFreeze_TIM13()
#define __HAL_DBGMCU_UnFreeze_TIM14()
#define __HAL_DBGMCU_UnFreeze_LPTIM1()
#define __HAL_DBGMCU_UnFreeze_I2C1()
#define __HAL_DBGMCU_UnFreeze_I2C2()
#define __HAL_DBGMCU_UnFreeze_I2C3()
#define __HAL_DBGMCU_UnFreeze_TIM1()
#define __HAL_DBGMCU_UnFreeze_TIM8()
#define __HAL_DBGMCU_UnFreeze_TIM15()
#define __HAL_DBGMCU_UnFreeze_TIM16()
#define __HAL_DBGMCU_UnFreeze_TIM17()
#define __HAL_DBGMCU_UnFreeze_HRTIM()
#define __HAL_DBGMCU_UnFreeze_I2C4()
#define __HAL_DBGMCU_UnFreeze_LPTIM2()
#define __HAL_DBGMCU_UnFreeze_LPTIM3()
#define __HAL_DBGMCU_UnFreeze_LPTIM4()
#define __HAL_DBGMCU_UnFreeze_LPTIM5()
#define __HAL_DBGMCU_UnFreeze_RTC()
#define __HAL_DBGMCU_UnFreeze_IWDG1()
#define IS_TICKFREQ(FREQ)
enum  HAL_TickFreqTypeDef { HAL_TICK_FREQ_10HZ = 100U , HAL_TICK_FREQ_100HZ = 10U , HAL_TICK_FREQ_1KHZ = 1U , HAL_TICK_FREQ_DEFAULT = HAL_TICK_FREQ_1KHZ }
HAL_StatusTypeDef HAL_Init (void)
 This function is used to initialize the HAL Library; it must be the first instruction to be executed in the main program (before to call any other HAL function), it performs the following: Configures the SysTick to generate an interrupt each 1 millisecond, which is clocked by the HSI (at this stage, the clock is not yet configured and thus the system is running from the internal HSI at 16 MHz). Set NVIC Group Priority to 4. Calls the HAL_MspInit() callback function defined in user file "stm32h7xx_hal_msp.c" to do the global low level hardware initialization.
HAL_StatusTypeDef HAL_DeInit (void)
 This function de-Initializes common part of the HAL and stops the systick. This function is optional.
__weak void HAL_MspInit (void)
 Initializes the MSP.
__weak void HAL_MspDeInit (void)
 DeInitializes the MSP.
__weak HAL_StatusTypeDef HAL_InitTick (uint32_t TickPriority)
 This function configures the source of the time base. The time source is configured to have 1ms time base with a dedicated Tick interrupt priority.
void HAL_IncTick (void)
 This function is called to increment a global variable "uwTick" used as application time base.
void HAL_Delay (uint32_t Delay)
 This function provides minimum delay (in milliseconds) based on variable incremented.
uint32_t HAL_GetTick (void)
 Provides a tick value in millisecond.
uint32_t HAL_GetTickPrio (void)
 This function returns a tick priority.
HAL_StatusTypeDef HAL_SetTickFreq (HAL_TickFreqTypeDef Freq)
 Set new tick Freq.
HAL_TickFreqTypeDef HAL_GetTickFreq (void)
 Return tick frequency.
void HAL_SuspendTick (void)
 Suspend Tick increment.
void HAL_ResumeTick (void)
 Resume Tick increment.
uint32_t HAL_GetHalVersion (void)
 Returns the HAL revision.
uint32_t HAL_GetREVID (void)
 Returns the device revision identifier.
uint32_t HAL_GetDEVID (void)
 Returns the device identifier.
uint32_t HAL_GetUIDw0 (void)
 Return the first word of the unique device identifier (UID based on 96 bits).
uint32_t HAL_GetUIDw1 (void)
 Return the second word of the unique device identifier (UID based on 96 bits).
uint32_t HAL_GetUIDw2 (void)
 Return the third word of the unique device identifier (UID based on 96 bits).
void HAL_SYSCFG_AnalogSwitchConfig (uint32_t SYSCFG_AnalogSwitch, uint32_t SYSCFG_SwitchState)
 Analog Switch control for dual analog pads.
void HAL_EnableCompensationCell (void)
 Enables the I/O Compensation Cell.
void HAL_DisableCompensationCell (void)
 Power-down the I/O Compensation Cell.
void HAL_SYSCFG_EnableIOSpeedOptimize (void)
 To Enable optimize the I/O speed when the product voltage is low.
void HAL_SYSCFG_DisableIOSpeedOptimize (void)
 To Disable optimize the I/O speed when the product voltage is low.
void HAL_SYSCFG_CompensationCodeSelect (uint32_t SYSCFG_CompCode)
 Code selection for the I/O Compensation cell.
void HAL_SYSCFG_CompensationCodeConfig (uint32_t SYSCFG_PMOSCode, uint32_t SYSCFG_NMOSCode)
void HAL_DBGMCU_EnableDBGSleepMode (void)
 Enable the Debug Module during Domain1/CDomain SLEEP mode.
void HAL_DBGMCU_DisableDBGSleepMode (void)
 Disable the Debug Module during Domain1/CDomain SLEEP mode.
void HAL_DBGMCU_EnableDBGStopMode (void)
 Enable the Debug Module during Domain1/CDomain STOP mode.
void HAL_DBGMCU_DisableDBGStopMode (void)
 Disable the Debug Module during Domain1/CDomain STOP mode.
void HAL_DBGMCU_EnableDBGStandbyMode (void)
 Enable the Debug Module during Domain1/CDomain STANDBY mode.
void HAL_DBGMCU_DisableDBGStandbyMode (void)
 Disable the Debug Module during Domain1/CDomain STANDBY mode.
void HAL_EXTI_EdgeConfig (uint32_t EXTI_Line, uint32_t EXTI_Edge)
 Configure the EXTI input event line edge.
void HAL_EXTI_GenerateSWInterrupt (uint32_t EXTI_Line)
 Generates a Software interrupt on selected EXTI line.
void HAL_EXTI_D1_ClearFlag (uint32_t EXTI_Line)
 Clears the EXTI's line pending flags for Domain D1.
void HAL_EXTI_D1_EventInputConfig (uint32_t EXTI_Line, uint32_t EXTI_Mode, uint32_t EXTI_LineCmd)
 Configure the EXTI input event line for Domain D1.
void HAL_EXTI_D3_EventInputConfig (uint32_t EXTI_Line, uint32_t EXTI_LineCmd, uint32_t EXTI_ClearSrc)
 Configure the EXTI input event line for Domain D3.
void HAL_SetFMCMemorySwappingConfig (uint32_t BankMapConfig)
 Set the FMC Memory Mapping Swapping config.
uint32_t HAL_GetFMCMemorySwappingConfig (void)
 Get FMC Bank mapping mode.
void HAL_SYSCFG_VREFBUF_VoltageScalingConfig (uint32_t VoltageScaling)
 Configure the internal voltage reference buffer voltage scale.
void HAL_SYSCFG_VREFBUF_HighImpedanceConfig (uint32_t Mode)
 Configure the internal voltage reference buffer high impedance mode.
void HAL_SYSCFG_VREFBUF_TrimmingConfig (uint32_t TrimmingValue)
 Tune the Internal Voltage Reference buffer (VREFBUF).
HAL_StatusTypeDef HAL_SYSCFG_EnableVREFBUF (void)
 Enable the Internal Voltage Reference buffer (VREFBUF).
void HAL_SYSCFG_DisableVREFBUF (void)
 Disable the Internal Voltage Reference buffer (VREFBUF).
__IO uint32_t uwTick
uint32_t uwTickPrio
HAL_TickFreqTypeDef uwTickFreq
Author
MCD Application Team
Attention
