RTEMS 6.3
| #define | __HAL_SYSCFG_BREAK_AXISRAM_DBL_ECC_LOCK() |
| SYSCFG Break AXIRAM double ECC lock. Enable and lock the connection of AXIRAM double ECC error to TIM1/8/15/16/17 and HRTIMER Break input. | |
| #define | __HAL_SYSCFG_BREAK_ITCM_DBL_ECC_LOCK() |
| SYSCFG Break ITCM double ECC lock. Enable and lock the connection of ITCM double ECC error to TIM1/8/15/16/17 and HRTIMER Break input. | |
| #define | __HAL_SYSCFG_BREAK_DTCM_DBL_ECC_LOCK() |
| SYSCFG Break DTCM double ECC lock. Enable and lock the connection of DTCM double ECC error to TIM1/8/15/16/17 and HRTIMER Break input. | |
| #define | __HAL_SYSCFG_BREAK_SRAM1_DBL_ECC_LOCK() |
| SYSCFG Break SRAM1 double ECC lock. Enable and lock the connection of SRAM1 double ECC error to TIM1/8/15/16/17 and HRTIMER Break input. | |
| #define | __HAL_SYSCFG_BREAK_SRAM2_DBL_ECC_LOCK() |
| SYSCFG Break SRAM2 double ECC lock. Enable and lock the connection of SRAM2 double ECC error to TIM1/8/15/16/17 and HRTIMER Break input. | |
| #define | __HAL_SYSCFG_BREAK_SRAM3_DBL_ECC_LOCK() |
| SYSCFG Break SRAM3 double ECC lock. Enable and lock the connection of SRAM3 double ECC error to TIM1/8/15/16/17 and HRTIMER Break input. | |
| #define | __HAL_SYSCFG_BREAK_SRAM4_DBL_ECC_LOCK() |
| SYSCFG Break SRAM4 double ECC lock. Enable and lock the connection of SRAM4 double ECC error to TIM1/8/15/16/17 and HRTIMER Break input. | |
| #define | __HAL_SYSCFG_BREAK_BKRAM_DBL_ECC_LOCK() |
| SYSCFG Break Backup SRAM double ECC lock. Enable and lock the connection of Backup SRAM double ECC error to TIM1/8/15/16/17 and HRTIMER Break input. | |
| #define | __HAL_SYSCFG_BREAK_CM7_LOCKUP_LOCK() |
| SYSCFG Break Cortex-M7 Lockup lock. Enable and lock the connection of Cortex-M7 LOCKUP output to TIM1/8/15/16/17 and HRTIMER Break input. | |
| #define | __HAL_SYSCFG_BREAK_FLASH_DBL_ECC_LOCK() |
| SYSCFG Break FLASH double ECC lock. Enable and lock the connection of Flash double ECC error connection to TIM1/8/15/16/17 and HRTIMER Break input. | |
| #define | __HAL_SYSCFG_BREAK_PVD_LOCK() |
| SYSCFG Break PVD lock. Enable and lock the PVD connection to Timer1/8/15/16/17 and HRTIMER Break input, as well as the PVDE and PLS[2:0] in the PWR_CR1 register. | |
| #define | __HAL_SYSCFG_FASTMODEPLUS_ENABLE(__FASTMODEPLUS__) |
| Fast-mode Plus driving capability enable/disable macros. | |
| #define | __HAL_SYSCFG_FASTMODEPLUS_DISABLE(__FASTMODEPLUS__) |
| #define __HAL_SYSCFG_BREAK_AXISRAM_DBL_ECC_LOCK | ( | ) |
| #define __HAL_SYSCFG_BREAK_BKRAM_DBL_ECC_LOCK | ( | ) |
| #define __HAL_SYSCFG_BREAK_CM7_LOCKUP_LOCK | ( | ) |
| #define __HAL_SYSCFG_BREAK_DTCM_DBL_ECC_LOCK | ( | ) |
| #define __HAL_SYSCFG_BREAK_FLASH_DBL_ECC_LOCK | ( | ) |
| #define __HAL_SYSCFG_BREAK_ITCM_DBL_ECC_LOCK | ( | ) |
| #define __HAL_SYSCFG_BREAK_PVD_LOCK | ( | ) |
| #define __HAL_SYSCFG_BREAK_SRAM1_DBL_ECC_LOCK | ( | ) |
| #define __HAL_SYSCFG_BREAK_SRAM2_DBL_ECC_LOCK | ( | ) |
| #define __HAL_SYSCFG_BREAK_SRAM3_DBL_ECC_LOCK | ( | ) |
| #define __HAL_SYSCFG_BREAK_SRAM4_DBL_ECC_LOCK | ( | ) |
| #define __HAL_SYSCFG_FASTMODEPLUS_DISABLE | ( | __FASTMODEPLUS__ | ) |
| #define __HAL_SYSCFG_FASTMODEPLUS_ENABLE | ( | __FASTMODEPLUS__ | ) |
| __FASTMODEPLUS__ | This parameter can be a value of :
