RTEMS 6.3
This file contains the common defines and functions prototypes for the stm32h747i_eval_qspi.c driver. More...
#include "stm32h747i_eval_conf.h"#include "stm32h747i_eval_errno.h"#include "../Components/mt25tl01g/mt25tl01g.h"Go to the source code of this file.
| struct | BSP_QSPI_Ctx_t |
| struct | BSP_QSPI_Init_t |
| struct | MX_QSPI_Init_t |
| #define | BSP_QSPI_Info_t MT25TL01G_Info_t |
| #define | BSP_QSPI_Interface_t MT25TL01G_Interface_t |
| #define | BSP_QSPI_Transfer_t MT25TL01G_Transfer_t |
| #define | BSP_QSPI_DualFlash_t MT25TL01G_DualFlash_t |
| #define | BSP_QSPI_ODS_t MT25TL01G_ODS_t |
| #define | QSPI_INSTANCES_NUMBER 1U |
| #define | BSP_QSPI_SPI_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_MODE |
| #define | BSP_QSPI_SPI_1I2O_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_1I2O_MODE |
| #define | BSP_QSPI_SPI_2IO_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_2IO_MODE |
| #define | BSP_QSPI_SPI_1I4O_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_1I4O_MODE |
| #define | BSP_QSPI_SPI_4IO_MODE (BSP_QSPI_Interface_t)MT25TL01G_SPI_4IO_MODE |
| #define | BSP_QSPI_DPI_MODE (BSP_QSPI_Interface_t)MT25TL01G_DPI_MODE |
| #define | BSP_QSPI_QPI_MODE (BSP_QSPI_Interface_t)MT25TL01G_QPI_MODE |
| #define | BSP_QSPI_STR_TRANSFER (BSP_QSPI_Transfer_t)MT25TL01G_STR_TRANSFER |
| #define | BSP_QSPI_DTR_TRANSFER (BSP_QSPI_Transfer_t)MT25TL01G_DTR_TRANSFER |
| #define | BSP_QSPI_DUALFLASH_DISABLE (BSP_QSPI_DualFlash_t)MT25TL01G_DUALFLASH_DISABLE |
| #define | BSP_QSPI_FLASH_ID QSPI_FLASH_ID_1 |
| #define | BSP_QSPI_BLOCK_8K MT25TL01G_SECTOR_4K |
| #define | BSP_QSPI_BLOCK_64K MT25TL01G_BLOCK_32K |
| #define | BSP_QSPI_BLOCK_128K MT25TL01G_BLOCK_64K |
| #define | QSPI_CLK_ENABLE() |
| #define | QSPI_CLK_DISABLE() |
| #define | QSPI_CLK_GPIO_CLK_ENABLE() |
| #define | QSPI_BK1_CS_GPIO_CLK_ENABLE() |
| #define | QSPI_BK1_D0_GPIO_CLK_ENABLE() |
| #define | QSPI_BK1_D1_GPIO_CLK_ENABLE() |
| #define | QSPI_BK1_D2_GPIO_CLK_ENABLE() |
| #define | QSPI_BK1_D3_GPIO_CLK_ENABLE() |
| #define | QSPI_BK2_CS_GPIO_CLK_ENABLE() |
| #define | QSPI_BK2_D0_GPIO_CLK_ENABLE() |
| #define | QSPI_BK2_D1_GPIO_CLK_ENABLE() |
| #define | QSPI_BK2_D2_GPIO_CLK_ENABLE() |
| #define | QSPI_BK2_D3_GPIO_CLK_ENABLE() |
| #define | QSPI_FORCE_RESET() |
| #define | QSPI_RELEASE_RESET() |
| #define | QSPI_CLK_PIN GPIO_PIN_2 |
| #define | QSPI_CLK_GPIO_PORT GPIOB |
| #define | QSPI_BK1_CS_PIN GPIO_PIN_6 |
| #define | QSPI_BK1_CS_GPIO_PORT GPIOG |
| #define | QSPI_BK1_D0_PIN GPIO_PIN_8 |
| #define | QSPI_BK1_D0_GPIO_PORT GPIOF |
| #define | QSPI_BK1_D1_PIN GPIO_PIN_9 |
| #define | QSPI_BK1_D1_GPIO_PORT GPIOF |
| #define | QSPI_BK1_D2_PIN GPIO_PIN_7 |
| #define | QSPI_BK1_D2_GPIO_PORT GPIOF |
| #define | QSPI_BK1_D3_PIN GPIO_PIN_6 |
| #define | QSPI_BK1_D3_GPIO_PORT GPIOF |
| #define | QSPI_BK2_CS_PIN GPIO_PIN_11 |
| #define | QSPI_BK2_CS_GPIO_PORT GPIOC |
| #define | QSPI_BK2_D0_PIN GPIO_PIN_2 |
| #define | QSPI_BK2_D0_GPIO_PORT GPIOH |
| #define | QSPI_BK2_D1_PIN GPIO_PIN_3 |
| #define | QSPI_BK2_D1_GPIO_PORT GPIOH |
| #define | QSPI_BK2_D2_PIN GPIO_PIN_9 |
| #define | QSPI_BK2_D2_GPIO_PORT GPIOG |
| #define | QSPI_BK2_D3_PIN GPIO_PIN_14 |
| #define | QSPI_BK2_D3_GPIO_PORT GPIOG |
| #define | QSPI_FLASH_SIZE 26 |
| #define | QSPI_PAGE_SIZE 256 |
| #define | QSPI_BASE_ADDRESS 0x90000000 |
Enumerations | |
| enum | BSP_QSPI_Erase_t { BSP_QSPI_ERASE_8K = MT25TL01G_ERASE_4K , BSP_QSPI_ERASE_64K = MT25TL01G_ERASE_32K , BSP_QSPI_ERASE_128K = MT25TL01G_ERASE_64K , BSP_QSPI_ERASE_CHIP = MT25TL01G_ERASE_CHIP } |
| enum | BSP_QSPI_Access_t { QSPI_ACCESS_NONE = 0 , QSPI_ACCESS_INDIRECT , QSPI_ACCESS_MMP } |
| int32_t | BSP_QSPI_Init (uint32_t Instance, BSP_QSPI_Init_t *Init) |
| Initializes the QSPI interface. | |
| int32_t | BSP_QSPI_DeInit (uint32_t Instance) |
| De-Initializes the QSPI interface. | |
| int32_t | BSP_QSPI_Read (uint32_t Instance, uint8_t *pData, uint32_t ReadAddr, uint32_t Size) |
| Reads an amount of data from the QSPI memory. | |
| int32_t | BSP_QSPI_Write (uint32_t Instance, uint8_t *pData, uint32_t WriteAddr, uint32_t Size) |
| Writes an amount of data to the QSPI memory. | |
| int32_t | BSP_QSPI_EraseBlock (uint32_t Instance, uint32_t BlockAddress, BSP_QSPI_Erase_t BlockSize) |
| Erases the specified block of the QSPI memory. MT25TL01G support 4K, 32K, 64K size block erase commands for each Die. i.e 8K, 64K, 128K at BSP level (see BSP_QSPI_Erase_t type definition). | |
| int32_t | BSP_QSPI_EraseChip (uint32_t Instance) |
| Erases the entire QSPI memory. | |
| int32_t | BSP_QSPI_GetStatus (uint32_t Instance) |
| Reads current status of the QSPI memory. If WIP != 0 then return busy. | |
| int32_t | BSP_QSPI_GetInfo (uint32_t Instance, BSP_QSPI_Info_t *pInfo) |
| Return the configuration of the QSPI memory. | |
| int32_t | BSP_QSPI_EnableMemoryMappedMode (uint32_t Instance) |
| Configure the QSPI in memory-mapped mode Only 1 Instance can running MMP mode. And it will lock system at this mode. | |
| int32_t | BSP_QSPI_DisableMemoryMappedMode (uint32_t Instance) |
| Exit form memory-mapped mode Only 1 Instance can running MMP mode. And it will lock system at this mode. | |
| int32_t | BSP_QSPI_ReadID (uint32_t Instance, uint8_t *Id) |
| Get flash ID, 3 Byte Manufacturer ID, Memory type, Memory density. | |
| int32_t | BSP_QSPI_ConfigFlash (uint32_t Instance, BSP_QSPI_Interface_t Mode, BSP_QSPI_Transfer_t Rate) |
| Set Flash to desired Interface mode. And this instance becomes current instance. If current instance running at MMP mode then this function isn't work. Indirect -> Indirect. | |
| __weak HAL_StatusTypeDef | MX_QSPI_Init (QSPI_HandleTypeDef *hQspi, MX_QSPI_Init_t *Config) |
| QSPI_HandleTypeDef | hqspi |
| BSP_QSPI_Ctx_t | QSPI_Ctx [] |
Copyright (c) 2019 STMicroelectronics. All rights reserved.
