RTEMS 6.3
This file includes a standard driver for the MT25TL01G QSPI memory mounted on STM32H747I-EVAL board. More...
#include "stm32h747i_eval_qspi.h"Functions | |
| int32_t | BSP_QSPI_Init (uint32_t Instance, BSP_QSPI_Init_t *Init) |
| Initializes the QSPI interface. | |
| int32_t | BSP_QSPI_DeInit (uint32_t Instance) |
| De-Initializes the QSPI interface. | |
| __weak HAL_StatusTypeDef | MX_QSPI_Init (QSPI_HandleTypeDef *hQspi, MX_QSPI_Init_t *Config) |
| int32_t | BSP_QSPI_Read (uint32_t Instance, uint8_t *pData, uint32_t ReadAddr, uint32_t Size) |
| Reads an amount of data from the QSPI memory. | |
| int32_t | BSP_QSPI_Write (uint32_t Instance, uint8_t *pData, uint32_t WriteAddr, uint32_t Size) |
| Writes an amount of data to the QSPI memory. | |
| int32_t | BSP_QSPI_EraseBlock (uint32_t Instance, uint32_t BlockAddress, BSP_QSPI_Erase_t BlockSize) |
| Erases the specified block of the QSPI memory. MT25TL01G support 4K, 32K, 64K size block erase commands for each Die. i.e 8K, 64K, 128K at BSP level (see BSP_QSPI_Erase_t type definition). | |
| int32_t | BSP_QSPI_EraseChip (uint32_t Instance) |
| Erases the entire QSPI memory. | |
| int32_t | BSP_QSPI_GetStatus (uint32_t Instance) |
| Reads current status of the QSPI memory. If WIP != 0 then return busy. | |
| int32_t | BSP_QSPI_GetInfo (uint32_t Instance, BSP_QSPI_Info_t *pInfo) |
| Return the configuration of the QSPI memory. | |
| int32_t | BSP_QSPI_EnableMemoryMappedMode (uint32_t Instance) |
| Configure the QSPI in memory-mapped mode Only 1 Instance can running MMP mode. And it will lock system at this mode. | |
| int32_t | BSP_QSPI_DisableMemoryMappedMode (uint32_t Instance) |
| Exit form memory-mapped mode Only 1 Instance can running MMP mode. And it will lock system at this mode. | |
| int32_t | BSP_QSPI_ReadID (uint32_t Instance, uint8_t *Id) |
| Get flash ID, 3 Byte Manufacturer ID, Memory type, Memory density. | |
| int32_t | BSP_QSPI_ConfigFlash (uint32_t Instance, BSP_QSPI_Interface_t Mode, BSP_QSPI_Transfer_t Rate) |
| Set Flash to desired Interface mode. And this instance becomes current instance. If current instance running at MMP mode then this function isn't work. Indirect -> Indirect. | |
| QSPI_HandleTypeDef | hqspi |
| BSP_QSPI_Ctx_t | QSPI_Ctx [QSPI_INSTANCES_NUMBER] |
How To use this driver:
- This driver is used to drive the MT25TL01G QSPI external
memory mounted on STM32H747I-EVAL evaluation board.
- This driver need a specific component driver (MT25TL01G) to be included with.
Driver description:
- Initialization steps:
+ Initialize the QPSI external memory using the BSP_QSPI_Init() function. This
function includes the MSP layer hardware resources initialization and the
QSPI interface with the external memory.
STR and DTR transfer rates are supported.
SPI, SPI 2-IO, SPI-4IO and QPI modes are supported
- QSPI memory operations
+ QSPI memory can be accessed with read/write operations once it is
initialized.
Read/write operation can be performed with AHB access using the functions
BSP_QSPI_Read()/BSP_QSPI_Write().
+ The function BSP_QSPI_GetInfo() returns the configuration of the QSPI memory.
(see the QSPI memory data sheet)
+ Perform erase block operation using the function BSP_QSPI_EraseBlock() and by
specifying the block address. You can perform an erase operation of the whole
chip by calling the function BSP_QSPI_EraseChip().
+ The function BSP_QSPI_GetStatus() returns the current status of the QSPI memory.
+ The function BSP_QSPI_EnableMemoryMappedMode enables the QSPI memory mapped mode
+ The function BSP_QSPI_DisableMemoryMappedMode disables the QSPI memory mapped mode
+ The function BSP_QSPI_ConfigFlash() allow to configure the QSPI mode and transfer rate
Note:
Regarding the "Instance" parameter, needed for all functions, it is used to select
an QSPI instance. On the STM32H747I_EVAL board, there's one instance. Then, this
parameter should be 0.
Copyright (c) 2019 STMicroelectronics. All rights reserved.
