RTEMS
6.3
Toggle main menu visibility
bsps
arm
stm32f4
include
bsp
stm32f4xxxx_tim.h
1
2
* Copyright (c) 2013 Chris Nott. All rights reserved.
3
4
* Virtual Logic
5
* 21-25 King St.
6
* Rockdale NSW 2216
7
* Australia
8
* <rtems@vl.com.au>
9
10
* The license and distribution terms for this file may be
11
* found in the file LICENSE in this distribution or at
12
* http://www.rtems.org/license/LICENSE.
13
14
15
#ifndef LIBBSP_ARM_STM32F4_STM32F4XXXX_TIM_H
16
#define LIBBSP_ARM_STM32F4_STM32F4XXXX_TIM_H
17
18
bsp/utility.h
19
20
struct
stm32f4_tim_s
21
uint16_t cr1;
// Control register 1
22
#define STM32F4_TIMER_CR1_CKD_DIV 0x0300
23
#define STM32F4_TIMER_CR1_CKD_DIV1 0x0000
24
#define STM32F4_TIMER_CR1_CKD_DIV2 0x0100
25
#define STM32F4_TIMER_CR1_CKD_DIV3 0x0200
26
#define STM32F4_TIMER_CR1_ARPE BSP_BIT16(7)
27
#define STM32F4_TIMER_CR1_CMS 0x0060
28
#define STM32F4_TIMER_CR1_CMS_EDGE 0x0000
29
#define STM32F4_TIMER_CR1_CMS_CENTER1 0x0020
30
#define STM32F4_TIMER_CR1_CMS_CENTER2 0x0040
31
#define STM32F4_TIMER_CR1_CMS_CENTER3 0x0060
32
#define STM32F4_TIMER_CR1_DIR BSP_BIT16(4)
33
#define STM32F4_TIMER_CR1_DIR_UP 0x0000
34
#define STM32F4_TIMER_CR1_DIR_DOWN 0x0010
35
#define STM32F4_TIMER_CR1_DIR_OPM 0x0008
36
#define STM32F4_TIMER_CR1_DIR_OPM_CONT 0x0000
37
#define STM32F4_TIMER_CR1_DIR_OPM_STOP 0x0008
38
#define STM32F4_TIMER_CR1_DIR_URS 0x0004
39
#define STM32F4_TIMER_CR1_DIR_UDIS 0x0002
40
#define STM32F4_TIMER_CR1_DIR_UDIS_EN 0x0000
41
#define STM32F4_TIMER_CR1_DIR_UDIS_DIS 0x0002
42
#define STM32F4_TIMER_CR1_CEN 0x0001
43
uint16_t reserved_02;
44
uint16_t cr2;
// Control register 2
45
uint16_t reserved_06;
46
uint16_t smcr;
// Slave mode control register
47
uint16_t reserved_0a;
48
uint16_t dier;
// DMA / interrupt enable register
49
#define STM32F4_TIMER_DIER_TDE BSP_BIT16(14)
// Trigger DMA request enable
50
#define STM32F4_TIMER_DIER_CC4DE BSP_BIT16(12)
// Capture/compare 4 DMA request enable
51
#define STM32F4_TIMER_DIER_CC3DE BSP_BIT16(11)
// Capture/compare 3 DMA request enable
52
#define STM32F4_TIMER_DIER_CC2DE BSP_BIT16(10)
// Capture/compare 2 DMA request enable
53
#define STM32F4_TIMER_DIER_CC1DE BSP_BIT16(9)
// Capture/compare 1 DMA request enable
54
#define STM32F4_TIMER_DIER_UDE BSP_BIT16(8)
// Update DMA request enable
55
#define STM32F4_TIMER_DIER_TIE BSP_BIT16(6)
// Trigger interrupt enable
56
#define STM32F4_TIMER_DIER_CC4IE BSP_BIT16(4)
// Capture/compare 4 interrupt request enable
57
#define STM32F4_TIMER_DIER_CC3IE BSP_BIT16(3)
// Capture/compare 3 interrupt request enable
58
#define STM32F4_TIMER_DIER_CC2IE BSP_BIT16(2)
// Capture/compare 2 interrupt request enable
59
#define STM32F4_TIMER_DIER_CC1IE BSP_BIT16(1)
// Capture/compare 1 interrupt request enable
60
#define STM32F4_TIMER_DIER_UIE BSP_BIT16(0)
// Update interrupt request enable
61
62
uint16_t reserved_0e;
63
uint16_t sr;
// Status register
64
#define STM32F4_TIMER_SR_CC4OF BSP_BIT16(12)
// Capture/compare 4 overcapture flag
65
#define STM32F4_TIMER_SR_CC3OF BSP_BIT16(11)
// Capture/compare 3 overcapture flag
66
#define STM32F4_TIMER_SR_CC2OF BSP_BIT16(10)
// Capture/compare 2 overcapture flag
67
#define STM32F4_TIMER_SR_CC1OF BSP_BIT16(9)
// Capture/compare 1 overcapture flag
68
#define STM32F4_TIMER_SR_TIF BSP_BIT16(6)
// Trigger interrupt flag
69
#define STM32F4_TIMER_SR_CC4IF BSP_BIT16(4)
// Capture/compare 4 interrupt flag
70
#define STM32F4_TIMER_SR_CC3IF BSP_BIT16(3)
// Capture/compare 3 interrupt flag
71
#define STM32F4_TIMER_SR_CC2IF BSP_BIT16(2)
// Capture/compare 2 interrupt flag
72
#define STM32F4_TIMER_SR_CC1IF BSP_BIT16(1)
// Capture/compare 1 interrupt flag
73
#define STM32F4_TIMER_SR_UIF BSP_BIT16(0)
// Update interrupt flag
74
uint16_t reserved_12;
75
uint16_t egr;
// Event generation register
76
#define STM32F4_TIMER_EGR_TG BSP_BIT16(6)
// Trigger event
77
#define STM32F4_TIMER_EGR_CC4G BSP_BIT16(4)
// Capture/compare 4 event
78
#define STM32F4_TIMER_EGR_CC3G BSP_BIT16(3)
// Capture/compare 3 generation)
79
#define STM32F4_TIMER_EGR_CC2G BSP_BIT16(2)
// Capture/compare 2 generation)
80
#define STM32F4_TIMER_EGR_CC1G BSP_BIT16(1)
// Capture/compare 1 generation)
81
#define STM32F4_TIMER_EGR_UG BSP_BIT16(0)
// Update event
82
uint16_t reserved_16;
83
uint16_t ccmr1;
// Capture / compare mode register 1
84
#define STM32F4_TIMER_CCMR1_OC2CE BSP_BIT16(15)
// Output compare 2 clear enable
85
#define STM32F4_TIMER_CCMR1_OC2M(val) BSP_FLD16(val, 12, 14)
86
#define STM32F4_TIMER_CCMR1_OC2M_GET(reg) BSP_FLD16GET(reg, 12, 14)
87
#define STM32F4_TIMER_CCMR1_OC2M_SET(reg, val) BSP_FLD16SET(reg, val, 12, 14)
88
#define STM32F4_TIMER_CCMR1_OC2M_FROZEN STM32F4_TIMER_CCMR1_OC2M(0)
89
#define STM32F4_TIMER_CCMR1_OC2M_ACTIVE STM32F4_TIMER_CCMR1_OC2M(1)
90
#define STM32F4_TIMER_CCMR1_OC2M_INACTIVE STM32F4_TIMER_CCMR1_OC2M(2)
91
#define STM32F4_TIMER_CCMR1_OC2M_TOGGLE STM32F4_TIMER_CCMR1_OC2M(3)
92
#define STM32F4_TIMER_CCMR1_OC2M_FORCE_LOW STM32F4_TIMER_CCMR1_OC2M(4)
93
#define STM32F4_TIMER_CCMR1_OC2M_FORCE_HIGH STM32F4_TIMER_CCMR1_OC2M(5)
94
#define STM32F4_TIMER_CCMR1_OC2M_PWM1 STM32F4_TIMER_CCMR1_OC2M(6)
95
#define STM32F4_TIMER_CCMR1_OC2M_PWM2 STM32F4_TIMER_CCMR1_OC2M(7)
96
#define STM32F4_TIMER_CCMR1_OC2PE BSP_BIT16(11)
// Output compare 2 preload enable
97
#define STM32F4_TIMER_CCMR1_OC2FE BSP_BIT16(10)
// Output compare 2 fast enable
98
#define STM32F4_TIMER_CCMR1_CC2S(val) BSP_FLD16(val, 8, 9)
99
#define STM32F4_TIMER_CCMR1_CC2S_GET(reg) BSP_FLD16GET(reg, 8, 9)
100
#define STM32F4_TIMER_CCMR1_CC2S_SET(reg, val) BSP_FLD16SET(reg, val, 8, 9)
101
#define STM32F4_TIMER_CCMR1_CC2S_OUTPUT STM32F4_TIMER_CCMR1_OC2S(0)
102
#define STM32F4_TIMER_CCMR1_CC2S_TI2 STM32F4_TIMER_CCMR1_OC2S(1)
103
#define STM32F4_TIMER_CCMR1_CC2S_TI1 STM32F4_TIMER_CCMR1_OC2S(2)
104
#define STM32F4_TIMER_CCMR1_CC2S_TRC STM32F4_TIMER_CCMR1_OC2S(3)
105
#define STM32F4_TIMER_CCMR1_OC1CE BSP_BIT16(7)
// Output compare 1 clear enable
106
#define STM32F4_TIMER_CCMR1_OC1M(val) BSP_FLD16(val, 4, 6)
107
#define STM32F4_TIMER_CCMR1_OC1M_GET(reg) BSP_FLD16GET(reg, 4, 6)
108
#define STM32F4_TIMER_CCMR1_OC1M_SET(reg, val) BSP_FLD16SET(reg, val, 4, 6)
109
#define STM32F4_TIMER_CCMR1_OC1M_FROZEN STM32F4_TIMER_CCMR1_OC1M(0)
110
#define STM32F4_TIMER_CCMR1_OC1M_ACTIVE STM32F4_TIMER_CCMR1_OC1M(1)
111
#define STM32F4_TIMER_CCMR1_OC1M_INACTIVE STM32F4_TIMER_CCMR1_OC1M(2)
112
#define STM32F4_TIMER_CCMR1_OC1M_TOGGLE STM32F4_TIMER_CCMR1_OC1M(3)
113
#define STM32F4_TIMER_CCMR1_OC1M_FORCE_LOW STM32F4_TIMER_CCMR1_OC1M(4)
114
#define STM32F4_TIMER_CCMR1_OC1M_FORCE_HIGH STM32F4_TIMER_CCMR1_OC1M(5)
115
#define STM32F4_TIMER_CCMR1_OC1M_PWM1 STM32F4_TIMER_CCMR1_OC1M(6)
116
#define STM32F4_TIMER_CCMR1_OC1M_PWM2 STM32F4_TIMER_CCMR1_OC1M(7)
117
#define STM32F4_TIMER_CCMR1_OC1PE BSP_BIT16(3)
// Output compare 1 preload enable
118
#define STM32F4_TIMER_CCMR1_OC1FE BSP_BIT16(2)
// Output compare 1 fast enable
119
#define STM32F4_TIMER_CCMR1_CC1S(val) BSP_FLD16(val, 0, 1)
120
#define STM32F4_TIMER_CCMR1_CC1S_GET(reg) BSP_FLD16GET(reg, 0, 1)
121
#define STM32F4_TIMER_CCMR1_CC1S_SET(reg, val) BSP_FLD16SET(reg, val, 0, 1)
122
#define STM32F4_TIMER_CCMR1_CC1S_OUTPUT STM32F4_TIMER_CCMR1_OC1S(0)
123
#define STM32F4_TIMER_CCMR1_CC1S_TI2 STM32F4_TIMER_CCMR1_OC1S(1)
124
#define STM32F4_TIMER_CCMR1_CC1S_TI1 STM32F4_TIMER_CCMR1_OC1S(2)
125
#define STM32F4_TIMER_CCMR1_CC1S_TRC STM32F4_TIMER_CCMR1_OC1S(3)
126
uint16_t reserved_1a;
127
uint16_t ccmr2;
// Capture / compare mode register 2
128
#define STM32F4_TIMER_CCMR2_OC4CE BSP_BIT16(15)
// Output compare 4 clear enable
129
#define STM32F4_TIMER_CCMR2_OC4M(val) BSP_FLD16(val, 12, 14)
130
#define STM32F4_TIMER_CCMR2_OC4M_GET(reg) BSP_FLD16GET(reg, 12, 14)
131
#define STM32F4_TIMER_CCMR2_OC4M_SET(reg, val) BSP_FLD16SET(reg, val, 12, 14)
132
#define STM32F4_TIMER_CCMR2_OC4M_FROZEN STM32F4_TIMER_CCMR2_OC4M(0)
133
#define STM32F4_TIMER_CCMR2_OC4M_ACTIVE STM32F4_TIMER_CCMR2_OC4M(1)
134
#define STM32F4_TIMER_CCMR2_OC4M_INACTIVE STM32F4_TIMER_CCMR2_OC4M(2)
135
#define STM32F4_TIMER_CCMR2_OC4M_TOGGLE STM32F4_TIMER_CCMR2_OC4M(3)
136
#define STM32F4_TIMER_CCMR2_OC4M_FORCE_LOW STM32F4_TIMER_CCMR2_OC4M(4)
137
#define STM32F4_TIMER_CCMR2_OC4M_FORCE_HIGH STM32F4_TIMER_CCMR2_OC4M(5)
138
#define STM32F4_TIMER_CCMR2_OC4M_PWM1 STM32F4_TIMER_CCMR2_OC4M(6)
139
#define STM32F4_TIMER_CCMR2_OC4M_PWM2 STM32F4_TIMER_CCMR2_OC4M(7)
140
#define STM32F4_TIMER_CCMR2_OC4PE BSP_BIT16(11)
// Output compare 4 preload enable
141
#define STM32F4_TIMER_CCMR2_OC4FE BSP_BIT16(10)
// Output compare 4 fast enable
142
#define STM32F4_TIMER_CCMR2_CC4S(val) BSP_FLD16(val, 8, 9)
143
#define STM32F4_TIMER_CCMR2_CC4S_GET(reg) BSP_FLD16GET(reg, 8, 9)
144
#define STM32F4_TIMER_CCMR2_CC4S_SET(reg, val) BSP_FLD16SET(reg, val, 8, 9)
145
#define STM32F4_TIMER_CCMR2_CC4S_OUTPUT STM32F4_TIMER_CCMR2_OC4S(0)
146
#define STM32F4_TIMER_CCMR2_CC4S_TI2 STM32F4_TIMER_CCMR2_OC4S(1)
147
#define STM32F4_TIMER_CCMR2_CC4S_TI1 STM32F4_TIMER_CCMR2_OC4S(2)
148
#define STM32F4_TIMER_CCMR2_CC4S_TRC STM32F4_TIMER_CCMR2_OC4S(3)
149
#define STM32F4_TIMER_CCMR2_OC3CE BSP_BIT16(7)
// Output compare 3 clear enable
150
#define STM32F4_TIMER_CCMR2_OC3M(val) BSP_FLD16(val, 4, 6)
151
#define STM32F4_TIMER_CCMR2_OC3M_GET(reg) BSP_FLD16GET(reg, 4, 6)
152
#define STM32F4_TIMER_CCMR2_OC3M_SET(reg, val) BSP_FLD16SET(reg, val, 4, 6)
153
#define STM32F4_TIMER_CCMR2_OC3M_FROZEN STM32F4_TIMER_CCMR2_OC3M(0)
154
#define STM32F4_TIMER_CCMR2_OC3M_ACTIVE STM32F4_TIMER_CCMR2_OC3M(1)
155
#define STM32F4_TIMER_CCMR2_OC3M_INACTIVE STM32F4_TIMER_CCMR2_OC3M(2)
156
#define STM32F4_TIMER_CCMR2_OC3M_TOGGLE STM32F4_TIMER_CCMR2_OC3M(3)
157
#define STM32F4_TIMER_CCMR2_OC3M_FORCE_LOW STM32F4_TIMER_CCMR2_OC3M(4)
158
#define STM32F4_TIMER_CCMR2_OC3M_FORCE_HIGH STM32F4_TIMER_CCMR2_OC3M(5)
159
#define STM32F4_TIMER_CCMR2_OC3M_PWM1 STM32F4_TIMER_CCMR2_OC3M(6)
160
#define STM32F4_TIMER_CCMR2_OC3M_PWM2 STM32F4_TIMER_CCMR2_OC3M(7)
161
#define STM32F4_TIMER_CCMR2_OC3PE BSP_BIT16(3)
// Output compare 3 preload enable
162
#define STM32F4_TIMER_CCMR2_OC3FE BSP_BIT16(2)
// Output compare 3 fast enable
163
#define STM32F4_TIMER_CCMR2_CC3S(val) BSP_FLD16(val, 0, 1)
164
#define STM32F4_TIMER_CCMR2_CC3S_GET(reg) BSP_FLD16GET(reg, 0, 1)
165
#define STM32F4_TIMER_CCMR2_CC3S_SET(reg, val) BSP_FLD16SET(reg, val, 0, 1)
166
#define STM32F4_TIMER_CCMR2_CC3S_OUTPUT STM32F4_TIMER_CCMR2_OC3S(0)
167
#define STM32F4_TIMER_CCMR2_CC3S_TI2 STM32F4_TIMER_CCMR2_OC3S(1)
168
#define STM32F4_TIMER_CCMR2_CC3S_TI1 STM32F4_TIMER_CCMR2_OC3S(2)
169
#define STM32F4_TIMER_CCMR2_CC3S_TRC STM32F4_TIMER_CCMR2_OC3S(3)
170
uint16_t reserved_1e;
171
uint16_t ccer;
// Capture / compare enable register
172
#define STM32F4_TIMER_CCER_CC4NP BSP_BIT16(15)
// Capture / compare 4 output polarity
173
#define STM32F4_TIMER_CCER_CC4P BSP_BIT16(13)
174
#define STM32F4_TIMER_CCER_CC4E BSP_BIT16(12)
// Capture / compare 4 output enable
175
#define STM32F4_TIMER_CCER_CC3NP BSP_BIT16(11)
// Capture / compare 3 output polarity
176
#define STM32F4_TIMER_CCER_CC3P BSP_BIT16(9)
177
#define STM32F4_TIMER_CCER_CC3E BSP_BIT16(8)
// Capture / compare 3 output enable
178
#define STM32F4_TIMER_CCER_CC2NP BSP_BIT16(7)
// Capture / compare 2 output polarity
179
#define STM32F4_TIMER_CCER_CC2P BSP_BIT16(5)
180
#define STM32F4_TIMER_CCER_CC2E BSP_BIT16(4)
// Capture / compare 2 output enable
181
#define STM32F4_TIMER_CCER_CC1NP BSP_BIT16(3)
// Capture / compare 1 output polarity
182
#define STM32F4_TIMER_CCER_CC1P BSP_BIT16(1)
183
#define STM32F4_TIMER_CCER_CC1E BSP_BIT16(0)
// Capture / compare 1 output enable
184
uint16_t reserved_22;
185
uint32_t cnt;
// Counter register
186
#define STM32F4_TIMER_DR(val) BSP_FLD32(val, 0, 31)
187
#define STM32F4_TIMER_DR_GET(reg) BSP_FLD32GET(reg, 0, 31)
188
#define STM32F4_TIMER_DR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 31)
189
uint16_t psc;
// Prescalar
190
uint16_t reserved_2a;
191
uint32_t arr;
// Auto-reload register
192
uint16_t rcr;
// Repetition counter register
193
uint16_t rserved_32;
194
uint32_t ccr[4];
// Capture / compare registers
195
uint16_t bdtr;
// Break and dead-time register
196
uint16_t reserved_46;
197
uint16_t dcr;
// DMA control register
198
uint16_t reserved_4a;
199
uint16_t dmar;
// DMA address for full transfer
200
uint16_t reserved_4e;
201
uint16_t or;
// Option register
202
uint16_t reserved_52;
203
__attribute__
((packed));
204
typedef
struct
stm32f4_tim_s
stm32f4_tim;
205
206
#endif
/* LIBBSP_ARM_STM32F4_STM32F4XXXX_TIM_H */
utility.h
This header file provides utility macros for BSPs.
__attribute__
Definition
xnandpsu_onfi.h:185
stm32f4_tim_s
Definition
stm32f4xxxx_tim.h:20
