RTEMS
6.3
Toggle main menu visibility
bsps
arm
stm32f4
include
bsp
stm32f4xxxx_pwr.h
1
2
* Copyright (c) 2013 Chris Nott. All rights reserved.
3
4
* Virtual Logic
5
* 21-25 King St.
6
* Rockdale NSW 2216
7
* Australia
8
* <rtems@vl.com.au>
9
10
* The license and distribution terms for this file may be
11
* found in the file LICENSE in this distribution or at
12
* http://www.rtems.org/license/LICENSE.
13
14
15
#ifndef LIBBSP_ARM_STM32F4_STM32F4XXXX_PWR_H
16
#define LIBBSP_ARM_STM32F4_STM32F4XXXX_PWR_H
17
18
bsp/utility.h
19
20
struct
stm32f4_pwr_s
21
22
uint32_t cr;
// Control register
23
#define STM32F4_PWR_CR_VOS BSP_BIT32(14)
// Regulator scaling output selection
24
#define STM32F4_PWR_CR_FPDS BSP_BIT32(9)
// Flash power-down in stop mode
25
#define STM32F4_PWR_CR_DBP BSP_BIT32(8)
// Disable backup domain write protection
26
#define STM32F4_PWR_CR_PLS BSP_FLD32(val, 5, 7)
// PVD level selection
27
#define STM32F4_PWR_CR_PLS_GET(reg) BSP_FLD32GET(reg, 5, 7)
28
#define STM32F4_PWR_CR_PLS_SET(reg, val) BSP_FLD32SET(reg, val, 5, 7)
29
#define STM32F4_PWR_CR_PVDE BSP_BIT32(4)
// Power voltage detector enable
30
#define STM32F4_PWR_CR_CSBF BSP_BIT32(3)
// Clear standby flag
31
#define STM32F4_PWR_CR_CWUF BSP_BIT32(2)
// Clear wakeup flag
32
#define STM32F4_PWR_CR_PDDS BSP_BIT32(1)
// Power-down deepsleep
33
#define STM32F4_PWR_CR_LPDS BSP_BIT32(0)
// Low-power deepsleep
34
35
uint32_t csr;
// Control / status register
36
#define STM32F4_PWR_CSR_VOSRDY BSP_BIT32(14)
// Regulator voltage scaling output selection ready bit
37
#define STM32F4_PWR_CSR_BRE BSP_BIT32(9)
// Backup domain regulator enable
38
#define STM32F4_PWR_CSR_EWUP BSP_BIT32(8)
// Enable WKUP pin
39
#define STM32F4_PWR_CSR_BRR BSP_BIT32(3)
// Backup regulator ready
40
#define STM32F4_PWR_CSR_PVDO BSP_BIT32(2)
// PVD output
41
#define STM32F4_PWR_CSR_SBF BSP_BIT32(1)
// Standby flag
42
#define STM32F4_PWR_CSR_WUF BSP_BIT32(0)
// Wakeup flag
43
44
__attribute__
((packed));
45
typedef
struct
stm32f4_pwr_s
stm32f4_pwr;
46
47
#endif
/* LIBBSP_ARM_STM32F4_STM32F4XXXX_PWR_H */
utility.h
This header file provides utility macros for BSPs.
__attribute__
Definition
xnandpsu_onfi.h:185
stm32f4_pwr_s
Definition
stm32f4xxxx_pwr.h:20
