RTEMS
6.3
Toggle main menu visibility
bsps
arm
stm32f4
include
bsp
stm32f4xxxx_adc.h
1
2
* Copyright (c) 2014 Chris Nott. All rights reserved.
3
4
* Virtual Logic
5
* 21-25 King St.
6
* Rockdale NSW 2216
7
* Australia
8
* <rtems@vl.com.au>
9
10
* The license and distribution terms for this file may be
11
* found in the file LICENSE in this distribution or at
12
* http://www.rtems.org/license/LICENSE.
13
14
15
#ifndef LIBBSP_ARM_STM32F4_STM32F4XXXX_ADC_H
16
#define LIBBSP_ARM_STM32F4_STM32F4XXXX_ADC_H
17
18
bsp/utility.h
19
20
struct
stm32f4_adc_chan_s
21
uint32_t sr;
// 0x00: Status register
22
#define STM32F4_ADC_SR_OVR BSP_BIT32(5)
// Overrun
23
#define STM32F4_ADC_SR_STRT BSP_BIT32(4)
// Regular channel start flag
24
#define STM32F4_ADC_SR_JSTRT BSP_BIT32(3)
// Injected channel start flag
25
#define STM32F4_ADC_SR_JEOC BSP_BIT32(2)
// Injected channel end of conversion
26
#define STM32F4_ADC_SR_EOC BSP_BIT32(1)
// Regular channel end of conversion
27
#define STM32F4_ADC_SR_AWD BSP_BIT32(0)
// Analog watchdog flag
28
29
uint32_t cr1;
// 0x04: Control register 1
30
#define STM32F4_ADC_CR1_OVRIE BSP_BIT32(26)
// Overrun interrupt enable
31
#define STM32F4_ADC_CR1_RES(val) BSP_FLD32(val, 24, 25)
// Resolution
32
#define STM32F4_ADC_CR1_RES_GET(reg) BSP_FLD32GET(reg, 24, 25)
33
#define STM32F4_ADC_CR1_RES_SET(reg, val) BSP_FLD32SET(reg, val, 24, 25)
34
#define ADC_CR1_RES_12BIT 0
35
#define ADC_CR1_RES_10BIT 1
36
#define ADC_CR1_RES_8BIT 2
37
#define ADC_CR1_RES_6BIT 3
38
#define STM32F4_ADC_CR1_AWDEN BSP_BIT32(23)
// Analog watchdog enable on regular channels
39
#define STM32F4_ADC_CR1_JAWDEN BSP_BIT32(22)
// Analog watchdog enable on injected channels
40
#define STM32F4_ADC_CR1_DISCNUM(val) BSP_FLD32(val, 13, 15)
// Discontinuous mode channel count
41
#define STM32F4_ADC_CR1_DISCNUM_GET(reg) BSP_FLD32GET(reg, 13, 15)
42
#define STM32F4_ADC_CR1_DISCNUM_SET(reg, val) BSP_FLD32SET(reg, val, 13, 15)
43
#define STM32F4_ADC_CR1_JDISCEN BSP_BIT32(12)
// Discontinous mode on injected channels
44
#define STM32F4_ADC_CR1_DISCEN BSP_BIT32(11)
// Discontinous mode on regular channels
45
#define STM32F4_ADC_CR1_JAUTO BSP_BIT32(10)
// Automated injected group conversion
46
#define STM32F4_ADC_CR1_AWDSGL BSP_BIT32(9)
// Enable watchdog on single channel in scan mode
47
#define STM32F4_ADC_CR1_SCAN BSP_BIT32(8)
// Scan mode
48
#define STM32F4_ADC_CR1_JEOCIE BSP_BIT32(7)
// Interrupt enable for injected channels
49
#define STM32F4_ADC_CR1_AWDIE BSP_BIT32(6)
// Analog watchdog interrupt enable
50
#define STM32F4_ADC_CR1_EOCIE BSP_BIT32(5)
// Interrupt enable for EOC
51
#define STM32F4_ADC_CR1_AWDCH(val) BSP_FLD32(val, 0, 4)
// Analog watchdog channel select bits
52
#define STM32F4_ADC_CR1_AWDCH_GET(reg) BSP_FLD32GET(reg, 0, 4)
53
#define STM32F4_ADC_CR1_AWDCH_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
54
55
uint32_t cr2;
// 0x08: Control register 2
56
#define STM32F4_ADC_CR2_SWSTART BSP_BIT32(30)
// Start conversion of regular channels
57
#define STM32F4_ADC_CR2_EXTEN(val) BSP_FLD32(val, 28, 29)
// External trigger enable for regular channels
58
#define STM32F4_ADC_CR2_EXTEN_GET(reg) BSP_FLD32GET(reg, 28, 29)
59
#define STM32F4_ADC_CR2_EXTEN_SET(reg, val) BSP_FLD32SET(reg, val, 28, 29)
60
#define STM32F4_ADC_CR2_JEXTEN(val) BSP_FLD32(val, 20, 21)
// External trigger enable for injected channels
61
#define STM32F4_ADC_CR2_JEXTEN_GET(reg) BSP_FLD32GET(reg, 20, 21)
62
#define STM32F4_ADC_CR2_JEXTEN_SET(reg, val) BSP_FLD32SET(reg, val, 20, 21)
63
#define ADC_CR2_TRIGGER_DISABLE 0
64
#define ADC_CR2_TRIGGER_RISING 1
65
#define ADC_CR2_TRIGGER_FALLING 2
66
#define ADC_CR2_TRIGGER_BOTH 3
67
#define STM32F4_ADC_CR2_EXTSEL(val) BSP_FLD32(val, 24, 27)
// External event select for regular group
68
#define STM32F4_ADC_CR2_EXTSEL_GET(reg) BSP_FLD32GET(reg, 24, 27)
69
#define STM32F4_ADC_CR2_EXTSEL_SET(reg, val) BSP_FLD32SET(reg, val, 24, 27)
70
#define ADC_CR2_EVT_TIMER1_CC1 0x0
71
#define ADC_CR2_EVT_TIMER1_CC2 0x1
72
#define ADC_CR2_EVT_TIMER1_CC3 0x2
73
#define ADC_CR2_EVT_TIMER2_CC2 0x3
74
#define ADC_CR2_EVT_TIMER2_CC3 0x4
75
#define ADC_CR2_EVT_TIMER2_CC4 0x5
76
#define ADC_CR2_EVT_TIMER2_TRGO 0x6
77
#define ADC_CR2_EVT_TIMER3_CC1 0x7
78
#define ADC_CR2_EVT_TIMER3_TRGO 0x8
79
#define ADC_CR2_EVT_TIMER4_CC1 0x9
80
#define ADC_CR2_EVT_TIMER5_CC1 0xa
81
#define ADC_CR2_EVT_TIMER5_CC2 0xb
82
#define ADC_CR2_EVT_TIMER5_CC3 0xc
83
#define ADC_CR2_EVT_TIMER8_CC1 0xd
84
#define ADC_CR2_EVT_TIMER8_TRGO 0xe
85
#define ADC_CR2_EVT_EXTI_11 0xf
86
#define STM32F4_ADC_CR2_JSWSTART BSP_BIT32(22)
// Start conversion of injected channels
87
#define STM32F4_ADC_CR2_JEXTSEL(val) BSP_FLD32(val, 16, 19)
// External event select for injected group
88
#define STM32F4_ADC_CR2_JEXTSEL_GET(reg) BSP_FLD32GET(reg, 16, 19)
89
#define STM32F4_ADC_CR2_JEXTSEL_SET(reg, val) BSP_FLD32SET(reg, val, 16, 19)
90
#define ADC_CR2_JEVT_TIMER1_CC4 0x0
91
#define ADC_CR2_JEVT_TIMER1_TRGO 0x1
92
#define ADC_CR2_JEVT_TIMER2_CC1 0x2
93
#define ADC_CR2_JEVT_TIMER2_TRGO 0x3
94
#define ADC_CR2_JEVT_TIMER3_CC2 0x4
95
#define ADC_CR2_JEVT_TIMER3_CC4 0x5
96
#define ADC_CR2_JEVT_TIMER4_CC1 0x6
97
#define ADC_CR2_JEVT_TIMER4_CC2 0x7
98
#define ADC_CR2_JEVT_TIMER4_CC3 0x8
99
#define ADC_CR2_JEVT_TIMER4_TRGO 0x9
100
#define ADC_CR2_JEVT_TIMER5_CC4 0xa
101
#define ADC_CR2_JEVT_TIMER5_TRGO 0xb
102
#define ADC_CR2_JEVT_TIMER8_CC2 0xc
103
#define ADC_CR2_JEVT_TIMER8_CC3 0xd
104
#define ADC_CR2_JEVT_TIMER8_CC4 0xe
105
#define ADC_CR2_JEVT_EXTI_15 0xf
106
#define STM32F4_ADC_CR2_ALIGN BSP_BIT32(11)
// Data alignment
107
#define STM32F4_ADC_CR2_ALIGN_RIGHT 0
108
#define STM32F4_ADC_CR2_ALIGN_LEFT STM32F4_ADC_CR2_ALIGN
109
#define STM32F4_ADC_CR2_EOCS BSP_BIT32(10)
// End of conversion selection
110
#define STM32F4_ADC_CR2_DDS BSP_BIT32(9)
// DMA disable selection (single ADC mode)
111
#define STM32F4_ADC_CR2_DMA BSP_BIT32(8)
// DMA access mode (single ADC)
112
#define STM32F4_ADC_CR2_CONT BSP_BIT32(1)
// Continuous conversion
113
#define STM32F4_ADC_CR2_ADON BSP_BIT32(0)
// A/D converter ON
114
115
uint32_t smpr1;
// 0x0C: Sample time register 1
116
#define ADC_SAMPLE_3CYCLE 0
117
#define ADC_SAMPLE_15CYCLE 1
118
#define ADC_SAMPLE_28CYCLE 2
119
#define ADC_SAMPLE_56CYCLE 3
120
#define ADC_SAMPLE_84CYCLE 4
121
#define ADC_SAMPLE_112CYCLE 5
122
#define ADC_SAMPLE_144CYCLE 6
123
#define ADC_SAMPLE_480CYCLE 7
124
#define STM32F4_ADC_SMP18(val) BSP_FLD32(val, 24, 26)
// Channel 18 sampling time selection
125
#define STM32F4_ADC_SMP18_GET(reg) BSP_FLD32GET(reg, 24, 26)
126
#define STM32F4_ADC_SMP18_SET(reg, val) BSP_FLD32SET(reg, val, 24, 26)
127
#define STM32F4_ADC_SMP17(val) BSP_FLD32(val, 21, 23)
// Channel 17 sampling time selection
128
#define STM32F4_ADC_SMP17_GET(reg) BSP_FLD32GET(reg, 21, 23)
129
#define STM32F4_ADC_SMP17_SET(reg, val) BSP_FLD32SET(reg, val, 21, 23)
130
#define STM32F4_ADC_SMP16(val) BSP_FLD32(val, 18, 20)
// Channel 16 sampling time selection
131
#define STM32F4_ADC_SMP16_GET(reg) BSP_FLD32GET(reg, 18, 20)
132
#define STM32F4_ADC_SMP16_SET(reg, val) BSP_FLD32SET(reg, val, 18, 20)
133
#define STM32F4_ADC_SMP15(val) BSP_FLD32(val, 15, 17)
// Channel 15 sampling time selection
134
#define STM32F4_ADC_SMP15_GET(reg) BSP_FLD32GET(reg, 15, 17)
135
#define STM32F4_ADC_SMP15_SET(reg, val) BSP_FLD32SET(reg, val, 15, 17)
136
#define STM32F4_ADC_SMP14(val) BSP_FLD32(val, 12, 14)
// Channel 14 sampling time selection
137
#define STM32F4_ADC_SMP14_GET(reg) BSP_FLD32GET(reg, 12, 14)
138
#define STM32F4_ADC_SMP14_SET(reg, val) BSP_FLD32SET(reg, val, 12, 14)
139
#define STM32F4_ADC_SMP13(val) BSP_FLD32(val, 9, 11)
// Channel 13 sampling time selection
140
#define STM32F4_ADC_SMP13_GET(reg) BSP_FLD32GET(reg, 9, 11)
141
#define STM32F4_ADC_SMP13_SET(reg, val) BSP_FLD32SET(reg, val, 9, 11)
142
#define STM32F4_ADC_SMP12(val) BSP_FLD32(val, 6, 8)
// Channel 12 sampling time selection
143
#define STM32F4_ADC_SMP12_GET(reg) BSP_FLD32GET(reg, 6, 8)
144
#define STM32F4_ADC_SMP12_SET(reg, val) BSP_FLD32SET(reg, val, 6, 8)
145
#define STM32F4_ADC_SMP11(val) BSP_FLD32(val, 3, 5)
// Channel 11 sampling time selection
146
#define STM32F4_ADC_SMP11_GET(reg) BSP_FLD32GET(reg, 3, 5)
147
#define STM32F4_ADC_SMP11_SET(reg, val) BSP_FLD32SET(reg, val, 3, 5)
148
#define STM32F4_ADC_SMP10(val) BSP_FLD32(val, 0, 2)
// Channel 10 sampling time selection
149
#define STM32F4_ADC_SMP10_GET(reg) BSP_FLD32GET(reg, 0, 2)
150
#define STM32F4_ADC_SMP10_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
151
152
uint32_t smpr2;
// 0x10: Sample time register 2
153
#define STM32F4_ADC_SMP9(val) BSP_FLD32(val, 27, 29)
// Channel 9 sampling time selection
154
#define STM32F4_ADC_SMP9_GET(reg) BSP_FLD32GET(reg, 27, 29)
155
#define STM32F4_ADC_SMP9_SET(reg, val) BSP_FLD32SET(reg, val, 27, 29)
156
#define STM32F4_ADC_SMP8(val) BSP_FLD32(val, 24, 26)
// Channel 8 sampling time selection
157
#define STM32F4_ADC_SMP8_GET(reg) BSP_FLD32GET(reg, 24, 26)
158
#define STM32F4_ADC_SMP8_SET(reg, val) BSP_FLD32SET(reg, val, 24, 26)
159
#define STM32F4_ADC_SMP7(val) BSP_FLD32(val, 21, 23)
// Channel 7 sampling time selection
160
#define STM32F4_ADC_SMP7_GET(reg) BSP_FLD32GET(reg, 21, 23)
161
#define STM32F4_ADC_SMP7_SET(reg, val) BSP_FLD32SET(reg, val, 21, 23)
162
#define STM32F4_ADC_SMP6(val) BSP_FLD32(val, 18, 20)
// Channel 6 sampling time selection
163
#define STM32F4_ADC_SMP6_GET(reg) BSP_FLD32GET(reg, 18, 20)
164
#define STM32F4_ADC_SMP6_SET(reg, val) BSP_FLD32SET(reg, val, 18, 20)
165
#define STM32F4_ADC_SMP5(val) BSP_FLD32(val, 15, 17)
// Channel 5 sampling time selection
166
#define STM32F4_ADC_SMP5_GET(reg) BSP_FLD32GET(reg, 15, 17)
167
#define STM32F4_ADC_SMP5_SET(reg, val) BSP_FLD32SET(reg, val, 15, 17)
168
#define STM32F4_ADC_SMP4(val) BSP_FLD32(val, 12, 14)
// Channel 4 sampling time selection
169
#define STM32F4_ADC_SMP4_GET(reg) BSP_FLD32GET(reg, 12, 14)
170
#define STM32F4_ADC_SMP4_SET(reg, val) BSP_FLD32SET(reg, val, 12, 14)
171
#define STM32F4_ADC_SMP3(val) BSP_FLD32(val, 9, 11)
// Channel 3 sampling time selection
172
#define STM32F4_ADC_SMP3_GET(reg) BSP_FLD32GET(reg, 9, 11)
173
#define STM32F4_ADC_SMP3_SET(reg, val) BSP_FLD32SET(reg, val, 9, 11)
174
#define STM32F4_ADC_SMP2(val) BSP_FLD32(val, 6, 8)
// Channel 2 sampling time selection
175
#define STM32F4_ADC_SMP2_GET(reg) BSP_FLD32GET(reg, 6, 8)
176
#define STM32F4_ADC_SMP2_SET(reg, val) BSP_FLD32SET(reg, val, 6, 8)
177
#define STM32F4_ADC_SMP1(val) BSP_FLD32(val, 3, 5)
// Channel 1 sampling time selection
178
#define STM32F4_ADC_SMP1_GET(reg) BSP_FLD32GET(reg, 3, 5)
179
#define STM32F4_ADC_SMP1_SET(reg, val) BSP_FLD32SET(reg, val, 3, 5)
180
#define STM32F4_ADC_SMP0(val) BSP_FLD32(val, 0, 2)
// Channel 0 sampling time selection
181
#define STM32F4_ADC_SMP0_GET(reg) BSP_FLD32GET(reg, 0, 2)
182
#define STM32F4_ADC_SMP0_SET(reg, val) BSP_FLD32SET(reg, val, 0, 2)
183
184
uint32_t jofr[4];
// 0x14-0x20: Injected channel data offset registers
185
#define STM32F4_ADC_JOFFSET(val) BSP_FLD32(val, 0, 11)
// Data offset for injected channel
186
#define STM32F4_ADC_JOFFSET_GET(reg) BSP_FLD32GET(reg, 0, 11)
187
#define STM32F4_ADC_JOFFSET_SET(reg, val) BSP_FLD32SET(reg, val, 0, 11)
188
189
uint32_t htr;
// 0x24: Watchdog higher threshold register
190
#define STM32F4_ADC_HT(val) BSP_FLD32(val, 0, 11)
// Analog watchdog higher threshold
191
#define STM32F4_ADC_HT_GET(reg) BSP_FLD32GET(reg, 0, 11)
192
#define STM32F4_ADC_HT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 11)
193
194
uint32_t ltr;
// 0x28: Watchdog lower threshold register
195
#define STM32F4_ADC_LT(val) BSP_FLD32(val, 0, 11)
// Analog watchdog lower threshold
196
#define STM32F4_ADC_LT_GET(reg) BSP_FLD32GET(reg, 0, 11)
197
#define STM32F4_ADC_LT_SET(reg, val) BSP_FLD32SET(reg, val, 0, 11)
198
199
uint32_t sqr[3];
// 0x2c-0x34: Regular sequence registers
200
#define STM32F4_ADC_SQR_L(val) BSP_FLD32(val, 20, 23)
// Regular channel sequence length
201
#define STM32F4_ADC_SQR_L_GET(reg) BSP_FLD32GET(reg, 20, 23)
202
#define STM32F4_ADC_SQR_L_SET(reg, val) BSP_FLD32SET(reg, val, 20, 23)
203
204
uint32_t jsqr;
// 0x38: Injected sequence register
205
#define STM32F4_ADC_JSQR_JL(val) BSP_FLD32(val, 20, 21)
// Injected sequence length
206
#define STM32F4_ADC_JSQR_JL_GET(reg) BSP_FLD32GET(reg, 20, 21)
207
#define STM32F4_ADC_JSQR_JL_SET(reg, val) BSP_FLD32SET(reg, val, 20, 21)
208
#define STM32F4_ADC_JSQR_JSQ4(val) BSP_FLD32(val, 15, 19)
// 4th conversion in injected sequence
209
#define STM32F4_ADC_JSQR_JSQ4_GET(reg) BSP_FLD32GET(reg, 15, 19)
210
#define STM32F4_ADC_JSQR_JSQ4_SET(reg, val) BSP_FLD32SET(reg, val, 15, 19)
211
#define STM32F4_ADC_JSQR_JSQ3(val) BSP_FLD32(val, 10, 14)
// 3rd conversion in injected sequence
212
#define STM32F4_ADC_JSQR_JSQ3_GET(reg) BSP_FLD32GET(reg, 10, 14)
213
#define STM32F4_ADC_JSQR_JSQ3_SET(reg, val) BSP_FLD32SET(reg, val, 10, 14)
214
#define STM32F4_ADC_JSQR_JSQ2(val) BSP_FLD32(val, 5, 9)
// 2nd conversion in injected sequence
215
#define STM32F4_ADC_JSQR_JSQ2_GET(reg) BSP_FLD32GET(reg, 5, 9)
216
#define STM32F4_ADC_JSQR_JSQ2_SET(reg, val) BSP_FLD32SET(reg, val, 5, 9)
217
#define STM32F4_ADC_JSQR_JSQ1(val) BSP_FLD32(val, 0, 4)
// 1st conversion in injected sequence
218
#define STM32F4_ADC_JSQR_JSQ1_GET(reg) BSP_FLD32GET(reg, 0, 4)
219
#define STM32F4_ADC_JSQR_JSQ1_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
220
221
uint32_t jdr[4];
// 0x3c-0x48: Injected data registers
222
#define STM32F4_ADC_JDATA(val) BSP_FLD32(val, 0, 15)
// Injected data
223
#define STM32F4_ADC_JDATA_GET(reg) BSP_FLD32GET(reg, 0, 15)
224
#define STM32F4_ADC_JDATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
225
226
uint32_t dr;
// 0x4c: Regular data register
227
#define STM32F4_ADC_DATA(val) BSP_FLD32(val, 0, 15)
// Regular data
228
#define STM32F4_ADC_DATA_GET(reg) BSP_FLD32GET(reg, 0, 15)
229
#define STM32F4_ADC_DATA_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
230
231
__attribute__
((packed));
232
typedef
struct
stm32f4_adc_chan_s
stm32f4_adc_chan;
233
234
struct
stm32f4_adc_com_s
235
uint32_t csr;
// 0x00: Common status register
236
#define STM32F4_ADC_CSR_OVR3 BSP_BIT32(21)
// Overrun flag ADC3
237
#define STM32F4_ADC_CSR_STRT3 BSP_BIT32(20)
// Regular start flag ADC3
238
#define STM32F4_ADC_CSR_JSTRT3 BSP_BIT32(19)
// Injected start flag ADC3
239
#define STM32F4_ADC_CSR_JEOC3 BSP_BIT32(18)
// Injected channel end of conversion flag ADC3
240
#define STM32F4_ADC_CSR_EOC3 BSP_BIT32(17)
// Channel end of conversion flag ADC3
241
#define STM32F4_ADC_CSR_AWD3 BSP_BIT32(16)
// Analog watchdog flag ADC3
242
#define STM32F4_ADC_CSR_OVR2 BSP_BIT32(13)
// Overrun flag ADC2
243
#define STM32F4_ADC_CSR_STRT2 BSP_BIT32(12)
// Regular start flag ADC2
244
#define STM32F4_ADC_CSR_JSTRT2 BSP_BIT32(11)
// Injected start flag ADC2
245
#define STM32F4_ADC_CSR_JEOC2 BSP_BIT32(10)
// Injected channel end of conversion flag ADC2
246
#define STM32F4_ADC_CSR_EOC2 BSP_BIT32(9)
// Channel end of conversion flag ADC2
247
#define STM32F4_ADC_CSR_AWD2 BSP_BIT32(8)
// Analog watchdog flag ADC2
248
#define STM32F4_ADC_CSR_OVR1 BSP_BIT32(5)
// Overrun flag ADC1
249
#define STM32F4_ADC_CSR_STRT1 BSP_BIT32(4)
// Regular start flag ADC1
250
#define STM32F4_ADC_CSR_JSTRT1 BSP_BIT32(3)
// Injected start flag ADC1
251
#define STM32F4_ADC_CSR_JEOC1 BSP_BIT32(2)
// Injected channel end of conversion flag ADC1
252
#define STM32F4_ADC_CSR_EOC1 BSP_BIT32(1)
// Channel end of conversion flag ADC1
253
#define STM32F4_ADC_CSR_AWD1 BSP_BIT32(0)
// Analog watchdog flag ADC1
254
255
uint32_t ccr;
// 0x00: Common control register
256
#define STM32F4_ADC_CCR_TSVREFE BSP_BIT32(23)
// Temp sensor and Vrefint enable
257
#define STM32F4_ADC_CCR_VBATE BSP_BIT32(22)
// Vbat enable
258
#define STM32F4_ADC_CCR_ADCPRE(val) BSP_FLD32(val, 16, 17)
// ADC prescalar
259
#define STM32F4_ADC_CCR_ADCPRE_GET(reg) BSP_FLD32GET(reg, 16, 17)
260
#define STM32F4_ADC_CCR_ADCPRE_SET(reg, val) BSP_FLD32SET(reg, val, 16, 17)
261
#define ADC_ADCPRE_PCLK2_2 0
262
#define ADC_ADCPRE_PCLK2_4 1
263
#define ADC_ADCPRE_PCLK2_6 2
264
#define ADC_ADCPRE_PCLK2_8 3
265
#define STM32F4_ADC_CCR_DMA(val) BSP_FLD32(val, 14, 15)
// DMA access mode for multi ADC
266
#define STM32F4_ADC_CCR_DMA_GET(reg) BSP_FLD32GET(reg, 14, 15)
267
#define STM32F4_ADC_CCR_DMA_SET(reg, val) BSP_FLD32SET(reg, val, 14, 15)
268
#define ADC_DMA_DISABLE 0
269
#define ADC_DMA_MODE1 1
270
#define ADC_DMA_MODE2 2
271
#define ADC_DMA_MODE3 3
272
#define STM32F4_ADC_CCR_DDS BSP_BIT32(13)
273
#define STM32F4_ADC_CCR_DELAY(val) BSP_FLD32(val, 8, 11)
// Delay between sampling phases
274
#define STM32F4_ADC_CCR_DELAY_GET(reg) BSP_FLD32GET(reg, 8, 11)
275
#define STM32F4_ADC_CCR_DELAY_SET(reg, val) BSP_FLD32SET(reg, val, 8, 11)
276
#define ADC_DELAY_5T 0
277
#define ADC_DELAY_6T 1
278
#define ADC_DELAY_7T 2
279
#define ADC_DELAY_8T 3
280
#define ADC_DELAY_9T 4
281
#define ADC_DELAY_10T 5
282
#define ADC_DELAY_11T 6
283
#define ADC_DELAY_12T 7
284
#define ADC_DELAY_13T 8
285
#define ADC_DELAY_14T 9
286
#define ADC_DELAY_15T 10
287
#define ADC_DELAY_16T 11
288
#define ADC_DELAY_17T 12
289
#define ADC_DELAY_18T 13
290
#define ADC_DELAY_19T 14
291
#define ADC_DELAY_20T 15
292
#define STM32F4_ADC_CCR_MULTI(val) BSP_FLD32(val, 0, 4)
// Multi ADC mode
293
#define STM32F4_ADC_CCR_MULTI_GET(reg) BSP_FLD32GET(reg, 0, 4)
294
#define STM32F4_ADC_CCR_MULTI_SET(reg, val) BSP_FLD32SET(reg, val, 0, 4)
295
#define ADC_MULTI_INDEPENDENT 0x00
296
#define ADC_MULTI_DUAL_REG_INJ 0x01
297
#define ADC_MULTI_DUAL_REG_ALT 0x02
298
#define ADC_MULTI_DUAL_INJ 0x05
299
#define ADC_MULTI_DUAL_REG 0x06
300
#define ADC_MULTI_DUAL_INTRL 0x07
301
#define ADC_MULTI_DUAL_ALT_TRIG 0x09
302
#define ADC_MULTI_TRIPLE_REG_INJ 0x11
303
#define ADC_MULTI_TRIPLE_REG_ALT 0x12
304
#define ADC_MULTI_TRIPLE_INJ 0x15
305
#define ADC_MULTI_TRIPLE_REG 0x16
306
#define ADC_MULTI_TRIPLE_INTRL 0x17
307
#define ADC_MULTI_TRIPLE_ALT_TRIG 0x19
308
309
uint32_t cdr;
// 0x00: Common regular data register
310
#define STM32F4_ADC_CDR_DATA2(val) BSP_FLD32(val, 16, 31)
// 2nd data item
311
#define STM32F4_ADC_CDR_DATA2_GET(reg) BSP_FLD32GET(reg, 16, 31)
312
#define STM32F4_ADC_CDR_DATA2_SET(reg, val) BSP_FLD32SET(reg, val, 16, 31)
313
#define STM32F4_ADC_CDR_DATA1(val) BSP_FLD32(val, 0, 15)
// 1st data item
314
#define STM32F4_ADC_CDR_DATA1_GET(reg) BSP_FLD32GET(reg, 0, 15)
315
#define STM32F4_ADC_CDR_DATA1_SET(reg, val) BSP_FLD32SET(reg, val, 0, 15)
316
317
__attribute__
((packed));
318
typedef
struct
stm32f4_adc_com_s
stm32f4_adc_com;
319
320
#endif
/* LIBBSP_ARM_STM32F4_STM32F4XXXX_ADC_H */
utility.h
This header file provides utility macros for BSPs.
__attribute__
Definition
xnandpsu_onfi.h:185
stm32f4_adc_chan_s
Definition
stm32f4xxxx_adc.h:20
stm32f4_adc_com_s
Definition
stm32f4xxxx_adc.h:234
