RTEMS
6.3
Toggle main menu visibility
bsps
arm
stm32f4
include
bsp
stm32_i2c.h
1
6
7
8
* Copyright (c) 2013 Christian Mauderer. All rights reserved.
9
10
* The license and distribution terms for this file may be
11
* found in the file LICENSE in this distribution or at
12
* http://www.rtems.org/license/LICENSE.
13
14
15
#ifndef LIBBSP_ARM_STM32F4_STM32_I2C_H
16
#define LIBBSP_ARM_STM32F4_STM32_I2C_H
17
18
bsp/utility.h
19
26
27
typedef
struct
28
uint32_t cr1;
29
#define STM32F4_I2C_CR1_SWRST BSP_BIT32(15)
30
#define STM32F4_I2C_CR1_ALERT BSP_BIT32(13)
31
#define STM32F4_I2C_CR1_PEC BSP_BIT32(12)
32
#define STM32F4_I2C_CR1_POS BSP_BIT32(11)
33
#define STM32F4_I2C_CR1_ACK BSP_BIT32(10)
34
#define STM32F4_I2C_CR1_STOP BSP_BIT32(9)
35
#define STM32F4_I2C_CR1_START BSP_BIT32(8)
36
#define STM32F4_I2C_CR1_NOSTRETCH BSP_BIT32(7)
37
#define STM32F4_I2C_CR1_ENGC BSP_BIT32(6)
38
#define STM32F4_I2C_CR1_ENPEC BSP_BIT32(5)
39
#define STM32F4_I2C_CR1_ENARP BSP_BIT32(4)
40
#define STM32F4_I2C_CR1_SMBTYPE BSP_BIT32(3)
41
#define STM32F4_I2C_CR1_SMBUS BSP_BIT32(1)
42
#define STM32F4_I2C_CR1_PE BSP_BIT32(0)
43
uint32_t cr2;
44
#define STM32F4_I2C_CR2_LAST BSP_BIT32(12)
45
#define STM32F4_I2C_CR2_DMAEN BSP_BIT32(11)
46
#define STM32F4_I2C_CR2_ITBUFEN BSP_BIT32(10)
47
#define STM32F4_I2C_CR2_ITEVTEN BSP_BIT32(9)
48
#define STM32F4_I2C_CR2_ITERREN BSP_BIT32(8)
49
#define STM32F4_I2C_CR2_FREQ(val) BSP_FLD32(val, 0, 5)
50
#define STM32F4_I2C_CR2_FREQ_GET(reg) BSP_FLD32GET(reg, 0, 5)
51
#define STM32F4_I2C_CR2_FREQ_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
52
uint32_t oar1;
53
#define STM32F4_I2C_OAR1_ADDMODE BSP_BIT32(15)
54
#define STM32F4_I2C_OAR1_ADD(val) BSP_FLD32(val, 0, 9)
55
#define STM32F4_I2C_OAR1_ADD_GET(reg) BSP_FLD32GET(reg, 0, 9)
56
#define STM32F4_I2C_OAR1_ADD_SET(reg, val) BSP_FLD32SET(reg, val, 0, 9)
57
uint32_t oar2;
58
#define STM32F4_I2C_OAR2_ADD2(val) BSP_FLD32(val, 1, 7)
59
#define STM32F4_I2C_OAR2_ADD2_GET(reg) BSP_FLD32GET(reg, 1, 7)
60
#define STM32F4_I2C_OAR2_ADD2_SET(reg, val) BSP_FLD32SET(reg, val, 1, 7)
61
#define STM32F4_I2C_OAR2_ENDUAL BSP_BIT32(0)
62
uint32_t dr;
63
#define STM32F4_I2C_DR(val) BSP_FLD32(val, 0, 7)
64
#define STM32F4_I2C_DR_GET(reg) BSP_FLD32GET(reg, 0, 7)
65
#define STM32F4_I2C_DR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 7)
66
uint32_t sr1;
67
#define STM32F4_I2C_SR1_SMBALERT BSP_BIT32(15)
68
#define STM32F4_I2C_SR1_TIMEOUT BSP_BIT32(14)
69
#define STM32F4_I2C_SR1_PECERR BSP_BIT32(12)
70
#define STM32F4_I2C_SR1_OVR BSP_BIT32(11)
71
#define STM32F4_I2C_SR1_AF BSP_BIT32(10)
72
#define STM32F4_I2C_SR1_ARLO BSP_BIT32(9)
73
#define STM32F4_I2C_SR1_BERR BSP_BIT32(8)
74
#define STM32F4_I2C_SR1_TxE BSP_BIT32(7)
75
#define STM32F4_I2C_SR1_RxNE BSP_BIT32(6)
76
#define STM32F4_I2C_SR1_STOPF BSP_BIT32(4)
77
#define STM32F4_I2C_SR1_ADD10 BSP_BIT32(3)
78
#define STM32F4_I2C_SR1_BTF BSP_BIT32(2)
79
#define STM32F4_I2C_SR1_ADDR BSP_BIT32(1)
80
#define STM32F4_I2C_SR1_SB BSP_BIT32(0)
81
uint32_t sr2;
82
#define STM32F4_I2C_SR2_PEC(val) BSP_FLD32(val, 8, 15)
83
#define STM32F4_I2C_SR2_PEC_GET(reg) BSP_FLD32GET(reg, 8, 15)
84
#define STM32F4_I2C_SR2_PEC_SET(reg, val) BSP_FLD32SET(reg, val, 8, 15)
85
#define STM32F4_I2C_SR2_DUALF BSP_BIT32(7)
86
#define STM32F4_I2C_SR2_SMBHOST BSP_BIT32(6)
87
#define STM32F4_I2C_SR2_SMBDEFAULT BSP_BIT32(5)
88
#define STM32F4_I2C_SR2_GENCALL BSP_BIT32(4)
89
#define STM32F4_I2C_SR2_TRA BSP_BIT32(2)
90
#define STM32F4_I2C_SR2_BUSY BSP_BIT32(1)
91
#define STM32F4_I2C_SR2_MSL BSP_BIT32(0)
92
uint32_t ccr;
93
#define STM32F4_I2C_CCR_FS BSP_BIT32(15)
94
#define STM32F4_I2C_CCR_DUTY BSP_BIT32(14)
95
#define STM32F4_I2C_CCR_CCR(val) BSP_FLD32(val, 0, 11)
96
#define STM32F4_I2C_CCR_CCR_GET(reg) BSP_FLD32GET(reg, 0, 11)
97
#define STM32F4_I2C_CCR_CCR_SET(reg, val) BSP_FLD32SET(reg, val, 0, 11)
98
#define STM32F4_I2C_CCR_CCR_MAX STM32F4_I2C_CCR_CCR_GET(BSP_MSK32(0, 11))
99
uint32_t trise;
100
#define STM32F4_I2C_TRISE(val) BSP_FLD32(val, 0, 5)
101
#define STM32F4_I2C_TRISE_GET(reg) BSP_FLD32GET(reg, 0, 5)
102
#define STM32F4_I2C_TRISE_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
103
stm32f4_i2c
104
106
107
#endif
/* LIBBSP_ARM_STM32F4_STM32_I2C_H */
utility.h
This header file provides utility macros for BSPs.
stm32f4_i2c
Definition
stm32_i2c.h:27
