RTEMS
6.3
Toggle main menu visibility
bsps
arm
lpc24xx
include
bsp
ssp.h
1
6
7
8
* SPDX-License-Identifier: BSD-2-Clause
9
10
* Copyright (C) 2008, 2019 embedded brains GmbH & Co. KG
11
12
13
* modification, are permitted provided that the following conditions
14
* are met:
15
* 1. Redistributions of source code must retain the above copyright
16
* notice, this list of conditions and the following disclaimer.
17
* 2. Redistributions in binary form must reproduce the above copyright
18
* notice, this list of conditions and the following disclaimer in the
19
* documentation and/or other materials provided with the distribution.
20
21
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
22
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
23
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
24
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
25
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
26
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
27
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
28
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
29
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
30
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
31
* POSSIBILITY OF SUCH DAMAGE.
32
33
34
#ifndef LIBBSP_ARM_LPC24XX_SSP_H
35
#define LIBBSP_ARM_LPC24XX_SSP_H
36
37
#ifdef __cplusplus
38
extern
"C"
39
#endif
/* __cplusplus */
40
48
49
#define LPC24XX_SSP_0_BUS_PATH "/dev/ssp-0"
50
51
#define LPC24XX_SSP_1_BUS_PATH "/dev/ssp-1"
52
53
#define LPC24XX_SSP_2_BUS_PATH "/dev/ssp-2"
54
55
int
lpc24xx_register_ssp_0(
void
56
57
int
lpc24xx_register_ssp_1(
void
58
59
int
lpc24xx_register_ssp_2(
void
60
62
63
#ifdef __cplusplus
64
65
#endif
/* __cplusplus */
66
67
#endif
/* LIBBSP_ARM_LPC24XX_SSP_H */
