RTEMS
6.3
Toggle main menu visibility
bsps
include
grlib
spictrl-regs.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
10
11
12
* Copyright (C) 2021 embedded brains GmbH & Co. KG
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
23
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
24
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
25
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
26
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
27
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
28
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
29
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
30
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
31
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
32
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
33
* POSSIBILITY OF SUCH DAMAGE.
34
35
36
37
* This file is part of the RTEMS quality process and was automatically
38
* generated. If you find something that needs to be fixed or
39
* worded better please post a report or patch to an RTEMS mailing list
40
* or raise a bug report:
41
42
* https://www.rtems.org/bugs.html
43
44
* For information on updating and regenerating please refer to the How-To
45
* section in the Software Requirements Engineering chapter of the
46
* RTEMS Software Engineering manual. The manual is provided as a part of
47
* a release. For development sources please refer to the online
48
* documentation at:
49
50
* https://docs.rtems.org
51
52
53
/* Generated from spec:/dev/grlib/if/spictrl-header */
54
55
#ifndef _GRLIB_SPICTRL_REGS_H
56
#define _GRLIB_SPICTRL_REGS_H
57
58
#include <stdint.h>
59
60
#ifdef __cplusplus
61
extern
"C"
62
#endif
63
64
/* Generated from spec:/dev/grlib/if/spictrl */
65
75
83
84
#define SPICTRL_CAP_SSSZ_SHIFT 24
85
#define SPICTRL_CAP_SSSZ_MASK 0xff000000U
86
#define SPICTRL_CAP_SSSZ_GET( _reg ) \
87
( ( ( _reg ) & SPICTRL_CAP_SSSZ_MASK ) >> \
88
SPICTRL_CAP_SSSZ_SHIFT )
89
#define SPICTRL_CAP_SSSZ_SET( _reg, _val ) \
90
( ( ( _reg ) & ~SPICTRL_CAP_SSSZ_MASK ) | \
91
( ( ( _val ) << SPICTRL_CAP_SSSZ_SHIFT ) & \
92
SPICTRL_CAP_SSSZ_MASK ) )
93
#define SPICTRL_CAP_SSSZ( _val ) \
94
95
96
97
#define SPICTRL_CAP_MAXWLEN_SHIFT 20
98
#define SPICTRL_CAP_MAXWLEN_MASK 0xf00000U
99
#define SPICTRL_CAP_MAXWLEN_GET( _reg ) \
100
( ( ( _reg ) & SPICTRL_CAP_MAXWLEN_MASK ) >> \
101
SPICTRL_CAP_MAXWLEN_SHIFT )
102
#define SPICTRL_CAP_MAXWLEN_SET( _reg, _val ) \
103
( ( ( _reg ) & ~SPICTRL_CAP_MAXWLEN_MASK ) | \
104
( ( ( _val ) << SPICTRL_CAP_MAXWLEN_SHIFT ) & \
105
SPICTRL_CAP_MAXWLEN_MASK ) )
106
#define SPICTRL_CAP_MAXWLEN( _val ) \
107
108
109
110
#define SPICTRL_CAP_TWEN 0x80000U
111
112
#define SPICTRL_CAP_AMODE 0x40000U
113
114
#define SPICTRL_CAP_ASELA 0x20000U
115
116
#define SPICTRL_CAP_SSEN 0x10000U
117
118
#define SPICTRL_CAP_FDEPTH_SHIFT 8
119
#define SPICTRL_CAP_FDEPTH_MASK 0xff00U
120
#define SPICTRL_CAP_FDEPTH_GET( _reg ) \
121
( ( ( _reg ) & SPICTRL_CAP_FDEPTH_MASK ) >> \
122
SPICTRL_CAP_FDEPTH_SHIFT )
123
#define SPICTRL_CAP_FDEPTH_SET( _reg, _val ) \
124
( ( ( _reg ) & ~SPICTRL_CAP_FDEPTH_MASK ) | \
125
( ( ( _val ) << SPICTRL_CAP_FDEPTH_SHIFT ) & \
126
SPICTRL_CAP_FDEPTH_MASK ) )
127
#define SPICTRL_CAP_FDEPTH( _val ) \
128
129
130
131
#define SPICTRL_CAP_SR 0x80U
132
133
#define SPICTRL_CAP_FT_SHIFT 5
134
#define SPICTRL_CAP_FT_MASK 0x60U
135
#define SPICTRL_CAP_FT_GET( _reg ) \
136
( ( ( _reg ) & SPICTRL_CAP_FT_MASK ) >> \
137
SPICTRL_CAP_FT_SHIFT )
138
#define SPICTRL_CAP_FT_SET( _reg, _val ) \
139
( ( ( _reg ) & ~SPICTRL_CAP_FT_MASK ) | \
140
( ( ( _val ) << SPICTRL_CAP_FT_SHIFT ) & \
141
SPICTRL_CAP_FT_MASK ) )
142
#define SPICTRL_CAP_FT( _val ) \
143
144
145
146
#define SPICTRL_CAP_REV_SHIFT 0
147
#define SPICTRL_CAP_REV_MASK 0x1fU
148
#define SPICTRL_CAP_REV_GET( _reg ) \
149
( ( ( _reg ) & SPICTRL_CAP_REV_MASK ) >> \
150
SPICTRL_CAP_REV_SHIFT )
151
#define SPICTRL_CAP_REV_SET( _reg, _val ) \
152
( ( ( _reg ) & ~SPICTRL_CAP_REV_MASK ) | \
153
( ( ( _val ) << SPICTRL_CAP_REV_SHIFT ) & \
154
SPICTRL_CAP_REV_MASK ) )
155
#define SPICTRL_CAP_REV( _val ) \
156
157
158
160
168
169
#define SPICTRL_MODE_LOOP 0x40000000U
170
171
#define SPICTRL_MODE_CPOL 0x20000000U
172
173
#define SPICTRL_MODE_CPHA 0x10000000U
174
175
#define SPICTRL_MODE_DIV_16 0x8000000U
176
177
#define SPICTRL_MODE_REV 0x4000000U
178
179
#define SPICTRL_MODE_MX 0x2000000U
180
181
#define SPICTRL_MODE_EN 0x1000000U
182
183
#define SPICTRL_MODE_LEN_SHIFT 20
184
#define SPICTRL_MODE_LEN_MASK 0xf00000U
185
#define SPICTRL_MODE_LEN_GET( _reg ) \
186
( ( ( _reg ) & SPICTRL_MODE_LEN_MASK ) >> \
187
SPICTRL_MODE_LEN_SHIFT )
188
#define SPICTRL_MODE_LEN_SET( _reg, _val ) \
189
( ( ( _reg ) & ~SPICTRL_MODE_LEN_MASK ) | \
190
( ( ( _val ) << SPICTRL_MODE_LEN_SHIFT ) & \
191
SPICTRL_MODE_LEN_MASK ) )
192
#define SPICTRL_MODE_LEN( _val ) \
193
194
195
196
#define SPICTRL_MODE_PM_SHIFT 16
197
#define SPICTRL_MODE_PM_MASK 0xf0000U
198
#define SPICTRL_MODE_PM_GET( _reg ) \
199
( ( ( _reg ) & SPICTRL_MODE_PM_MASK ) >> \
200
SPICTRL_MODE_PM_SHIFT )
201
#define SPICTRL_MODE_PM_SET( _reg, _val ) \
202
( ( ( _reg ) & ~SPICTRL_MODE_PM_MASK ) | \
203
( ( ( _val ) << SPICTRL_MODE_PM_SHIFT ) & \
204
SPICTRL_MODE_PM_MASK ) )
205
#define SPICTRL_MODE_PM( _val ) \
206
207
208
209
#define SPICTRL_MODE_TWEN 0x8000U
210
211
#define SPICTRL_MODE_ASEL 0x4000U
212
213
#define SPICTRL_MODE_FACT 0x2000U
214
215
#define SPICTRL_MODE_OD 0x1000U
216
217
#define SPICTRL_MODE_CG_SHIFT 7
218
#define SPICTRL_MODE_CG_MASK 0xf80U
219
#define SPICTRL_MODE_CG_GET( _reg ) \
220
( ( ( _reg ) & SPICTRL_MODE_CG_MASK ) >> \
221
SPICTRL_MODE_CG_SHIFT )
222
#define SPICTRL_MODE_CG_SET( _reg, _val ) \
223
( ( ( _reg ) & ~SPICTRL_MODE_CG_MASK ) | \
224
( ( ( _val ) << SPICTRL_MODE_CG_SHIFT ) & \
225
SPICTRL_MODE_CG_MASK ) )
226
#define SPICTRL_MODE_CG( _val ) \
227
228
229
230
#define SPICTRL_MODE_ASELDEL_SHIFT 5
231
#define SPICTRL_MODE_ASELDEL_MASK 0x60U
232
#define SPICTRL_MODE_ASELDEL_GET( _reg ) \
233
( ( ( _reg ) & SPICTRL_MODE_ASELDEL_MASK ) >> \
234
SPICTRL_MODE_ASELDEL_SHIFT )
235
#define SPICTRL_MODE_ASELDEL_SET( _reg, _val ) \
236
( ( ( _reg ) & ~SPICTRL_MODE_ASELDEL_MASK ) | \
237
( ( ( _val ) << SPICTRL_MODE_ASELDEL_SHIFT ) & \
238
SPICTRL_MODE_ASELDEL_MASK ) )
239
#define SPICTRL_MODE_ASELDEL( _val ) \
240
241
242
243
#define SPICTRL_MODE_TAC 0x10U
244
245
#define SPICTRL_MODE_TTO 0x8U
246
247
#define SPICTRL_MODE_IGSEL 0x4U
248
249
#define SPICTRL_MODE_CITE 0x2U
250
252
260
261
#define SPICTRL_EVENT_TIP 0x80000000U
262
263
#define SPICTRL_EVENT_LT 0x4000U
264
265
#define SPICTRL_EVENT_OV 0x1000U
266
267
#define SPICTRL_EVENT_UN 0x800U
268
269
#define SPICTRL_EVENT_MME 0x400U
270
271
#define SPICTRL_EVENT_NE 0x200U
272
273
#define SPICTRL_EVENT_NF 0x100U
274
276
284
285
#define SPICTRL_MASK_TIPE 0x80000000U
286
287
#define SPICTRL_MASK_LTE 0x4000U
288
289
#define SPICTRL_MASK_OVE 0x1000U
290
291
#define SPICTRL_MASK_UNE 0x800U
292
293
#define SPICTRL_MASK_MMEE 0x400U
294
295
#define SPICTRL_MASK_NEEE 0x200U
296
297
#define SPICTRL_MASK_NFE 0x100U
298
300
308
309
#define SPICTRL_CMD_LST 0x400000U
310
312
320
321
#define SPICTRL_TX_TDATA_SHIFT 0
322
#define SPICTRL_TX_TDATA_MASK 0xffffffffU
323
#define SPICTRL_TX_TDATA_GET( _reg ) \
324
( ( ( _reg ) & SPICTRL_TX_TDATA_MASK ) >> \
325
SPICTRL_TX_TDATA_SHIFT )
326
#define SPICTRL_TX_TDATA_SET( _reg, _val ) \
327
( ( ( _reg ) & ~SPICTRL_TX_TDATA_MASK ) | \
328
( ( ( _val ) << SPICTRL_TX_TDATA_SHIFT ) & \
329
SPICTRL_TX_TDATA_MASK ) )
330
#define SPICTRL_TX_TDATA( _val ) \
331
332
333
335
343
344
#define SPICTRL_RX_RDATA_SHIFT 0
345
#define SPICTRL_RX_RDATA_MASK 0xffffffffU
346
#define SPICTRL_RX_RDATA_GET( _reg ) \
347
( ( ( _reg ) & SPICTRL_RX_RDATA_MASK ) >> \
348
SPICTRL_RX_RDATA_SHIFT )
349
#define SPICTRL_RX_RDATA_SET( _reg, _val ) \
350
( ( ( _reg ) & ~SPICTRL_RX_RDATA_MASK ) | \
351
( ( ( _val ) << SPICTRL_RX_RDATA_SHIFT ) & \
352
SPICTRL_RX_RDATA_MASK ) )
353
#define SPICTRL_RX_RDATA( _val ) \
354
355
356
358
366
367
#define SPICTRL_SLVSEL_SLVSEL_SHIFT 0
368
#define SPICTRL_SLVSEL_SLVSEL_MASK 0x3U
369
#define SPICTRL_SLVSEL_SLVSEL_GET( _reg ) \
370
( ( ( _reg ) & SPICTRL_SLVSEL_SLVSEL_MASK ) >> \
371
SPICTRL_SLVSEL_SLVSEL_SHIFT )
372
#define SPICTRL_SLVSEL_SLVSEL_SET( _reg, _val ) \
373
( ( ( _reg ) & ~SPICTRL_SLVSEL_SLVSEL_MASK ) | \
374
( ( ( _val ) << SPICTRL_SLVSEL_SLVSEL_SHIFT ) & \
375
SPICTRL_SLVSEL_SLVSEL_MASK ) )
376
#define SPICTRL_SLVSEL_SLVSEL( _val ) \
377
378
379
381
390
391
#define SPICTRL_ASLVSEL_ASLVSEL_SHIFT 0
392
#define SPICTRL_ASLVSEL_ASLVSEL_MASK 0x3U
393
#define SPICTRL_ASLVSEL_ASLVSEL_GET( _reg ) \
394
( ( ( _reg ) & SPICTRL_ASLVSEL_ASLVSEL_MASK ) >> \
395
SPICTRL_ASLVSEL_ASLVSEL_SHIFT )
396
#define SPICTRL_ASLVSEL_ASLVSEL_SET( _reg, _val ) \
397
( ( ( _reg ) & ~SPICTRL_ASLVSEL_ASLVSEL_MASK ) | \
398
( ( ( _val ) << SPICTRL_ASLVSEL_ASLVSEL_SHIFT ) & \
399
SPICTRL_ASLVSEL_ASLVSEL_MASK ) )
400
#define SPICTRL_ASLVSEL_ASLVSEL( _val ) \
401
402
403
405
409
typedef
struct
spictrl
413
uint32_t
cap
414
415
uint32_t reserved_4_20[ 7 ];
416
420
uint32_t
mode
421
425
uint32_t
event
426
430
uint32_t
mask
431
435
uint32_t
cmd
436
440
uint32_t
tx
441
445
uint32_t
rx
446
450
uint32_t
slvsel
451
455
uint32_t
aslvsel
456
spictrl
457
459
460
#ifdef __cplusplus
461
462
#endif
463
464
#endif
/* _GRLIB_SPICTRL_REGS_H */
spictrl
This structure defines the SPICTRL register block memory map.
Definition
spictrl-regs.h:409
spictrl::slvsel
uint32_t slvsel
See Slave select register (SLVSEL).
Definition
spictrl-regs.h:450
spictrl::rx
uint32_t rx
See Receive register (RX).
Definition
spictrl-regs.h:445
spictrl::aslvsel
uint32_t aslvsel
See Automatic slave select register (ASLVSEL).
Definition
spictrl-regs.h:455
spictrl::event
uint32_t event
See Event register (EVENT).
Definition
spictrl-regs.h:425
spictrl::cap
uint32_t cap
See Capability register (CAP).
Definition
spictrl-regs.h:413
spictrl::mode
uint32_t mode
See Mode register (MODE).
Definition
spictrl-regs.h:420
spictrl::cmd
uint32_t cmd
See Command register (CMD).
Definition
spictrl-regs.h:435
spictrl::tx
uint32_t tx
See Transmit register (TX).
Definition
spictrl-regs.h:440
spictrl::mask
uint32_t mask
See Mask register (MASK).
Definition
spictrl-regs.h:430
