RTEMS 6.3
This group contains the SPICTRL interfaces. More...
Topics | |
| Automatic slave select register (ASLVSEL) | |
| This group contains register bit definitions. | |
| Capability register (CAP) | |
| Command register (CMD) | |
| Event register (EVENT) | |
| Mask register (MASK) | |
| Mode register (MODE) | |
| Receive register (RX) | |
| Slave select register (SLVSEL) | |
| Transmit register (TX) | |
Files | |
| file | bsps/include/grlib/spictrl-regs.h |
| This header file defines the SPICTRL register block interface. | |
| struct | spictrl |
| This structure defines the SPICTRL register block memory map. More... | |
Typedefs | |
| typedef struct spictrl | spictrl |
| This structure defines the SPICTRL register block memory map. | |
