RTEMS
6.3
Toggle main menu visibility
bsps
i386
include
bsp
smp-imps.h
1
7
8
9
* Author: Erich Boleyn <erich@uruk.org>
10
* http://www.uruk.org/~erich/
11
12
* Copyright (c) 1997-2011 Erich Boleyn. All rights reserved.
13
14
15
* modification, are permitted provided that the following conditions
16
* are met:
17
* 1. Redistributions of source code must retain the above copyright
18
* notice, this list of conditions and the following disclaimer.
19
* 2. Redistributions in binary form must reproduce the above copyright
20
* notice, this list of conditions and the following disclaimer in the
21
* documentation and/or other materials provided with the distribution.
22
* 3. The name of the author may not be used to endorse or promote products
23
* derived from this software without specific prior written permission.
24
25
* THIS SOFTWARE IS PROVIDED BY THE AUTHOR ``AS IS'' AND ANY EXPRESS OR
26
* IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
27
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
28
* IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT,
29
* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
30
* NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
31
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
32
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
33
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF
34
* THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
35
36
37
38
* Header file implementing Intel MultiProcessor Specification (MPS)
39
* version 1.1 and 1.4 SMP hardware control for Intel Architecture CPUs,
40
* with hooks for running correctly on a standard PC without the hardware.
41
42
* This file was created from information in the Intel MPS version 1.4
43
* document, order number 242016-004, which can be ordered from the
44
* Intel literature center.
45
46
47
48
* This file is based upon code by Eric Boleyn as documented above.
49
* RTEMS support was added and minimal other changes were made.
50
* This should make it easier to compare this file with the original
51
* version.
52
53
* COPYRIGHT (c) 2011.
54
* On-Line Applications Research Corporation (OAR).
55
56
* The license and distribution terms for this file may be
57
* found in the file LICENSE in this distribution or at
58
* http://www.rtems.org/license/LICENSE.
59
60
69
70
#ifndef _SMP_IMPS_H
71
#define _SMP_IMPS_H
72
73
/* make sure "apic.h" is included */
74
#ifndef _APIC_H
75
#error Must include "apic.h" before "smp-imps.h"
76
#endif
/* !_APIC_H */
77
78
79
* Defines used.
80
81
82
#define IMPS_READ(x) (*((volatile unsigned *) (x)))
83
#define IMPS_WRITE(x,y) (*((volatile unsigned *) (x)) = (y))
84
85
#ifdef IMPS_DEBUG
86
#define IMPS_DEBUG_PRINT(x) KERNEL_PRINT(x)
87
#else
/* !IMPS_DEBUG */
88
89
#endif
/* !IMPS_DEBUG */
90
91
#define IMPS_MAX_CPUS APIC_BCAST_ID
92
97
#define IMPS_FPS_SIGNATURE ('_' | ('M'<<8) | ('P'<<16) | ('_'<<24))
98
#define IMPS_FPS_IMCRP_BIT 0x80
99
#define IMPS_FPS_DEFAULT_MAX 7
100
105
#define IMPS_CTH_SIGNATURE ('P' | ('C'<<8) | ('M'<<16) | ('P'<<24))
106
110
#define IMPS_FLAG_ENABLED 1
111
#define IMPS_BCT_PROCESSOR 0
112
#define IMPS_CPUFLAG_BOOT 2
113
#define IMPS_BCT_BUS 1
114
#define IMPS_BCT_IOAPIC 2
115
#define IMPS_BCT_IO_INTERRUPT 3
116
#define IMPS_BCT_LOCAL_INTERRUPT 4
117
#define IMPS_INT_INT 0
118
#define IMPS_INT_NMI 1
119
#define IMPS_INT_SMI 2
120
#define IMPS_INT_EXTINT 3
121
122
123
124
* Typedefs and data item definitions done here.
125
126
127
typedef
struct
imps_fps
imps_fps
128
typedef
struct
imps_cth
imps_cth
129
typedef
struct
imps_processor
imps_processor
130
typedef
struct
imps_bus
imps_bus
131
typedef
struct
imps_ioapic
imps_ioapic
132
typedef
struct
imps_interrupt
imps_interrupt
133
134
135
136
* Data structures defined here
137
138
145
struct
imps_fps
146
147
unsigned
sig;
148
imps_cth
*cth_ptr;
149
unsigned
char
length;
150
unsigned
char
spec_rev;
151
unsigned
char
checksum;
152
unsigned
char
feature_info[5];
153
154
161
struct
imps_cth
162
163
unsigned
sig;
164
unsigned
short
base_length;
165
unsigned
char
spec_rev;
166
unsigned
char
checksum;
167
char
oem_id[8];
168
char
prod_id[12];
169
unsigned
oem_table_ptr;
170
unsigned
short
oem_table_size;
171
unsigned
short
entry_count;
172
unsigned
lapic_addr;
173
unsigned
short
extended_length;
174
unsigned
char
extended_checksum;
175
char
reserved[1];
176
177
183
184
struct
imps_processor
185
186
unsigned
char
type
187
unsigned
char
apic_id;
188
unsigned
char
apic_ver;
189
unsigned
char
flags;
190
unsigned
signature;
191
unsigned
features;
192
char
reserved[8];
193
194
195
struct
imps_bus
196
197
unsigned
char
type
198
unsigned
char
id;
199
char
bus_type[6];
200
201
202
struct
imps_ioapic
203
204
unsigned
char
type
205
unsigned
char
id;
206
unsigned
char
ver;
207
unsigned
char
flags;
208
unsigned
addr;
209
210
211
struct
imps_interrupt
212
213
unsigned
char
type
214
unsigned
char
int_type;
215
unsigned
short
flags;
216
unsigned
char
source_bus_id;
217
unsigned
char
source_bus_irq;
218
unsigned
char
dest_apic_id;
219
unsigned
char
dest_apic_intin;
220
221
222
223
* Exported globals here.
224
225
229
extern
unsigned
char
imps_cpu_apic_map
[IMPS_MAX_CPUS];
230
extern
unsigned
char
imps_apic_cpu_map[IMPS_MAX_CPUS];
231
233
extern
char
_binary_appstart_bin_start
234
extern
char
_binary_appstart_bin_size[];
235
237
extern
unsigned
imps_lapic_addr
238
239
240
* Defines that use variables
241
242
#define IMPS_LAPIC_READ(x) (*((volatile unsigned *) (imps_lapic_addr+(x))))
243
#define IMPS_LAPIC_WRITE(x, y) \
244
(*((volatile unsigned *) (imps_lapic_addr+(x))) = (y))
245
246
#endif
/* !_SMP_IMPS_H */
247
imps_cpu_apic_map
unsigned char imps_cpu_apic_map[IMPS_MAX_CPUS]
These map from virtual cpu numbers to APIC id's and back.
Definition
smp-imps.c:198
char _binary_appstart_bin_start[]
base address of application processor reset code at 0x70000
imps_lapic_addr
unsigned imps_lapic_addr
base address of the local apic. Usually 0xFEE00000
Definition
smp-imps.c:202
imps_bus
Definition
smp-imps.h:196
imps_bus::type
unsigned char type
must be 1
Definition
smp-imps.h:197
imps_cth
MP Configuration Table Header (cth).
Definition
smp-imps.h:162
imps_fps
MP Floating Pointer Structure (fps).
Definition
smp-imps.h:146
imps_interrupt
Definition
smp-imps.h:212
imps_interrupt::type
unsigned char type
must be 3 or 4
Definition
smp-imps.h:213
imps_ioapic
Definition
smp-imps.h:203
imps_ioapic::type
unsigned char type
must be 2
Definition
smp-imps.h:204
imps_processor
Base MP Configuration Table Types. They are sorted according to type (i.e. all of type 0 come first,...
Definition
smp-imps.h:185
imps_processor::type
unsigned char type
must be 0
Definition
smp-imps.h:186
