RTEMS 6.3
smp-imps.h File Reference
Intel MultiProcessor Specification (MPS) version 1.1 and 1.4 SMP hardware control. More...
struct  imps_fps
 MP Floating Pointer Structure (fps). More...
struct  imps_cth
 MP Configuration Table Header (cth). More...
struct  imps_processor
 Base MP Configuration Table Types. They are sorted according to type (i.e. all of type 0 come first, etc.). Look on page 4-6 for the start of the descriptions. More...
struct  imps_bus
struct  imps_ioapic
struct  imps_interrupt
#define IMPS_READ(x)
#define IMPS_WRITE(x, y)
#define IMPS_DEBUG_PRINT(x)
#define IMPS_MAX_CPUS   APIC_BCAST_ID
#define IMPS_FPS_SIGNATURE   ('_' | ('M'<<8) | ('P'<<16) | ('_'<<24))
 This is the value that must be in the "sig" member of the MP Floating Pointer Structure.
#define IMPS_FPS_IMCRP_BIT   0x80
#define IMPS_FPS_DEFAULT_MAX   7
#define IMPS_CTH_SIGNATURE   ('P' | ('C'<<8) | ('M'<<16) | ('P'<<24))
 This is the value that must be in the "sig" member of the MP Configuration Table Header.
#define IMPS_FLAG_ENABLED   1
 These are the "type" values for Base MP Configuration Table entries.
#define IMPS_BCT_PROCESSOR   0
#define IMPS_CPUFLAG_BOOT   2
#define IMPS_BCT_BUS   1
#define IMPS_BCT_IOAPIC   2
#define IMPS_BCT_IO_INTERRUPT   3
#define IMPS_BCT_LOCAL_INTERRUPT   4
#define IMPS_INT_INT   0
#define IMPS_INT_NMI   1
#define IMPS_INT_SMI   2
#define IMPS_INT_EXTINT   3
#define IMPS_LAPIC_READ(x)
#define IMPS_LAPIC_WRITE(x, y)
typedef struct imps_fps imps_fps
 MP floating pointer structure.
typedef struct imps_cth imps_cth
 MP configuration table header.
typedef struct imps_processor imps_processor
typedef struct imps_bus imps_bus
typedef struct imps_ioapic imps_ioapic
typedef struct imps_interrupt imps_interrupt
unsigned char imps_cpu_apic_map [IMPS_MAX_CPUS]
 These map from virtual cpu numbers to APIC id's and back.
unsigned char imps_apic_cpu_map [IMPS_MAX_CPUS]
char _binary_appstart_bin_start []
 base address of application processor reset code at 0x70000
char _binary_appstart_bin_size []
unsigned imps_lapic_addr
 base address of the local apic. Usually 0xFEE00000
◆ IMPS_LAPIC_READ
#define IMPS_LAPIC_READ ( x)
Value:
(*((volatile unsigned *) (imps_lapic_addr+(x))))
Definition smp-imps.c:202
◆ IMPS_LAPIC_WRITE
#define IMPS_LAPIC_WRITE ( x,
y )
Value:
(*((volatile unsigned *) (imps_lapic_addr+(x))) = (y))
◆ IMPS_READ
#define IMPS_READ ( x)
Value:
(*((volatile unsigned *) (x)))
◆ IMPS_WRITE
#define IMPS_WRITE ( x,
y )
Value:
(*((volatile unsigned *) (x)) = (y))
