RTEMS 6.3
rtl-unresolved.h File Reference
RTEMS Run-Time Linker Object File Unresolved Relocations Table. More...
#include <rtems/chain.h>
#include "rtl-obj-fwd.h"
struct  rtems_rtl_unresolv_symbol
struct  rtems_rtl_unresolv_reloc
struct  rtems_rtl_tramp_reloc
struct  rtems_rtl_unresolv_rec
struct  rtems_rtl_unresolv_block
struct  rtems_rtl_unresolved
#define RTEMS_RTL_UNRESOLV_SYM_SEARCH_ARCHIVE   (1 << 0)
#define RTEMS_RTL_UNRESOLV_SYM_HAS_ERROR   (1 << 1)
typedef uint32_t rtems_rtl_word
typedef enum rtems_rtl_unresolved_rtype rtems_rtl_unresolved_rtype
typedef struct rtems_rtl_unresolv_symbol rtems_rtl_unresolv_symbol
typedef struct rtems_rtl_unresolv_reloc rtems_rtl_unresolv_reloc
typedef struct rtems_rtl_tramp_reloc rtems_rtl_tramp_reloc
typedef struct rtems_rtl_unresolv_rec rtems_rtl_unresolv_rec
typedef struct rtems_rtl_unresolv_block rtems_rtl_unresolv_block
typedef struct rtems_rtl_unresolved rtems_rtl_unresolved
typedef bool rtems_rtl_unresolved_iterator(rtems_rtl_unresolv_rec *rec, void *data)
enum  rtems_rtl_unresolved_rtype { rtems_rtl_unresolved_empty = 0 , rtems_rtl_unresolved_symbol = 1 , rtems_rtl_unresolved_reloc = 2 , rtems_rtl_trampoline_reloc = 3 }
bool rtems_rtl_unresolved_table_open (rtems_rtl_unresolved *unresolved, size_t block_records)
void rtems_rtl_unresolved_table_close (rtems_rtl_unresolved *unresolved)
bool rtems_rtl_unresolved_iterate (rtems_rtl_unresolved_iterator iterator, void *data)
bool rtems_rtl_unresolved_add (rtems_rtl_obj *obj, const uint16_t flags, const char *name, const uint16_t sect, const rtems_rtl_word *rel)
void rtems_rtl_unresolved_resolve (void)
bool rtems_rtl_unresolved_remove (rtems_rtl_obj *obj, const char *name, const uint16_t sect, const rtems_rtl_word *rel)
void rtems_rtl_unresolved_set_archive_search (void)
void rtems_rtl_unresolved_dump (void)
The unresolved relocation table holds relocations in a loaded object file which reference unresolved external symbols. The support is needed to allow dependent object files to load. In the case of dependent object files one will have unresolved externals until the dependent object file is also loaded. There is no load order that resolves this.
The unresolved relocation table is a single table used by all object files with unresolved symbols. It made of blocks linked together where blocks are allocated as requiered. The table is always maintained compacted. That is as relocations are resolved and removed the table is compacted. The only pointer in the table is the object file poniter. This is used to identify which object the relocation belongs to. There are no linking or back pointers in the unresolved relocations table. The table is scanned for each object file's relocations. This is not fast but the table should be small and if it happens to grow large you have other more pressing issues to resolve in your application.
The table holds two (2) types of records:
Symbol name strings.
Relocations.
The symbol name a relocation references is held in a specific symbol name string record in the table the relocation record references. The record counts the number of references and the string is removed from the table when the reference count reaches 0. There can be many relocations referencing the symbol. The strings are referenced by a single 16bit unsigned integer which is the count of the string in the table.
The section the relocation is for in the object is the section number. The relocation data is series of machine word sized fields:
Offset in the section.
Relocation info (format specific)
Additional format specific data.
◆ RTEMS_RTL_UNRESOLV_SYM_HAS_ERROR
The symbol load has an error.
◆ RTEMS_RTL_UNRESOLV_SYM_SEARCH_ARCHIVE
Unresolved external symbol flags. Search the archive.
Typedef Documentation
◆ rtems_rtl_tramp_reloc
Trampolines require the relocation records to be held
◆ rtems_rtl_unresolv_block
Unresolved blocks.
◆ rtems_rtl_unresolv_rec
Unresolved externals records.
◆ rtems_rtl_unresolv_reloc
Unresolved externals symbols require the relocation records to be held and referenced.
◆ rtems_rtl_unresolv_symbol
Unresolved externals symbols. The symbols are reference counted and separate from the relocation records because a number of records could reference the same symbol.
The name is extended in the allocator of the record in the unresolved data block. The 10 is a minimum that is added to by joining more than one record.
◆ rtems_rtl_unresolved
Unresolved table holds the names and relocations.
◆ rtems_rtl_unresolved_iterator
The iterator function used to iterate over the unresolved table.
Parameters
recThe current iterator.
dataThe user data.
Return values
trueThe iterator has finished.
falseThe iterator has not finished. Keep iterating.
◆ rtems_rtl_unresolved_rtype
The types of records in the blocks.
◆ rtems_rtl_word
Hack to work around machine size. This needs to be cleaned up to better support 64bit targets.
The records is empty. Must always be 0
The record is a symbol.
The record is a relocation record.
The record is a trampoline relocation record.
◆ rtems_rtl_unresolved_add()
bool rtems_rtl_unresolved_add ( rtems_rtl_obj * obj,
const char * name,
const rtems_rtl_word * rel )
Add a relocation to the list of unresolved relocations.
Parameters
unresolvedThe unresolved symbol table.
objThe object table the symbols are for.
flagsFormat specific flags.
nameThe symbol name the relocation references.
sectThe target section number the relocation references.
relThe format specific relocation data.
Return values
trueThe relocation has been added.
falseThe relocation could not be added.
◆ rtems_rtl_unresolved_dump()
void rtems_rtl_unresolved_dump ( void )
Dump the RTL unresolved data.
◆ rtems_rtl_unresolved_iterate()
bool rtems_rtl_unresolved_iterate ( rtems_rtl_unresolved_iterator iterator,
void * data )
Iterate over the table of unresolved entries.
◆ rtems_rtl_unresolved_remove()
bool rtems_rtl_unresolved_remove ( rtems_rtl_obj * obj,
const char * name,
Remove a relocation from the list of unresolved relocations.
Parameters
esymsThe exported symbol table.
sizeThe size of the table in bytes.
◆ rtems_rtl_unresolved_resolve()
void rtems_rtl_unresolved_resolve ( void )
Resolve the unresolved symbols.
◆ rtems_rtl_unresolved_set_archive_search()
void rtems_rtl_unresolved_set_archive_search ( void )
Set all symbols to be archive searchable. This is done when the available archives have been refreshed and there are new archives to search for.
◆ rtems_rtl_unresolved_table_close()
void rtems_rtl_unresolved_table_close ( rtems_rtl_unresolved * unresolved)
Close the table and erase the blocks.
Parameters
unreolvedClose the unresolved table.
◆ rtems_rtl_unresolved_table_open()
bool rtems_rtl_unresolved_table_open ( rtems_rtl_unresolved * unresolved,
size_t block_records )
Open an unresolved relocation table.
Parameters
unresolvThe unresolved table to open.
block_recordsThe number of records per block allocated.
Return values
trueThe table is open.
falseThe unresolved relocation table could not created. The RTL error has the error.
