RTEMS
6.3
Toggle main menu visibility
include
rtl
rtl-obj-fwd.h
1
/* SPDX-License-Identifier: BSD-2-Clause */
2
3
4
* COPYRIGHT (c) 2012 Chris Johns <chrisj@rtems.org>
5
6
7
* modification, are permitted provided that the following conditions
8
* are met:
9
* 1. Redistributions of source code must retain the above copyright
10
* notice, this list of conditions and the following disclaimer.
11
* 2. Redistributions in binary form must reproduce the above copyright
12
* notice, this list of conditions and the following disclaimer in the
13
* documentation and/or other materials provided with the distribution.
14
15
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
16
* AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
17
* IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
18
* ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
19
* LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
20
* CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
21
* SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
22
* INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
23
* CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
24
* ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
25
* POSSIBILITY OF SUCH DAMAGE.
26
34
35
#if !defined (_RTEMS_RTL_OBJ_FWD_H_)
36
#define _RTEMS_RTL_OBJ_FWD_H_
37
38
#ifdef __cplusplus
39
extern
"C"
40
#endif
/* __cplusplus */
41
45
struct
rtems_rtl_obj_sect
46
typedef
struct
rtems_rtl_obj_sect
rtems_rtl_obj_sect
47
51
struct
rtems_rtl_obj_depends
52
typedef
struct
53
57
struct
rtems_rtl_obj
58
typedef
struct
rtems_rtl_obj
rtems_rtl_obj
59
60
#ifdef __cplusplus
61
62
#endif
/* __cplusplus */
63
64
#endif
Definition
rtl-obj.h:169
rtems_rtl_obj_sect
Definition
rtl-obj.h:146
rtems_rtl_obj
Definition
rtl-obj.h:200
