RTEMS 6.3
rtl-rap.h File Reference
RTEMS Run-Time Linker ELF Headers. More...
bool rtems_rtl_rap_file_check (rtems_rtl_obj *obj, int fd)
bool rtems_rtl_rap_file_load (rtems_rtl_obj *obj, int fd)
bool rtems_rtl_rap_file_unload (rtems_rtl_obj *obj)
rtems_rtl_loader_format * rtems_rtl_rap_file_sig (void)
◆ rtems_rtl_rap_file_check()
bool rtems_rtl_rap_file_check ( rtems_rtl_obj * obj,
int fd )
The RAP format check handler.
Parameters
objThe object being checked.
fdThe file descriptor.
◆ rtems_rtl_rap_file_load()
bool rtems_rtl_rap_file_load ( rtems_rtl_obj * obj,
int fd )
The RAP format load handler.
Parameters
objThe object to load.
obj->entry = (void*)(uintptr_t) ehdr.e_entry;
◆ rtems_rtl_rap_file_sig()
rtems_rtl_loader_format * rtems_rtl_rap_file_sig ( void )
The RAP format signature handler.
Returns
rtems_rtl_loader_format* The format's signature.
◆ rtems_rtl_rap_file_unload()
bool rtems_rtl_rap_file_unload ( rtems_rtl_obj * obj)
The RAP format unload handler.
Parameters
objThe object to unload.
