.lock_h = rtems_rfs_rtems_lock_by_mt_entry,
.unlock_h = rtems_rfs_rtems_unlock_by_mt_entry,
.eval_path_h = rtems_rfs_rtems_eval_path,
.link_h = rtems_rfs_rtems_link,
.fchmod_h = rtems_rfs_rtems_fchmod,
.mknod_h = rtems_rfs_rtems_mknod,
.chown_h = rtems_rfs_rtems_chown,
.utimens_h = rtems_rfs_rtems_utimens,
.symlink_h = rtems_rfs_rtems_symlink,
.readlink_h = rtems_rfs_rtems_readlink,
.rename_h = rtems_rfs_rtems_rename,
.statvfs_h = rtems_rfs_rtems_statvfs
int rtems_filesystem_default_unmount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition default_unmount.c:41
int rtems_filesystem_default_clonenode(rtems_filesystem_location_info_t *loc)
Definition default_clone.c:42
bool rtems_filesystem_default_are_nodes_equal(const rtems_filesystem_location_info_t *a, const rtems_filesystem_location_info_t *b)
Tests if the node access pointer of one location is equal to the node access pointer of the other loc...
Definition default_are_nodes_equal.c:42
int rtems_filesystem_default_mount(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition default_mount.c:41
void rtems_filesystem_default_freenode(const rtems_filesystem_location_info_t *loc)
Definition default_freenode.c:43
int rtems_rfs_rtems_rmnod(const rtems_filesystem_location_info_t *parent_pathloc, const rtems_filesystem_location_info_t *pathloc)
Definition rtems-rfs-rtems.c:580
void rtems_rfs_rtems_shutdown(rtems_filesystem_mount_table_entry_t *mt_entry)
Definition rtems-rfs-rtems.c:850
RFS file system operations table.
